Code doesn't run when arduino is reset
My project consists of two arduino nanos, they communicate via 433mhz radio transmitter and receivers. The purpose of the first one is to send a signal to the second to start its code, and the second sends back an acknowledgment, then the second arduino starts the loop.
The second arduino is connected to:
  • mpu6050 accelerometer/gyro
  • bmp 180 barometer
  • micro sd card module
  • rf transmitter and receiver
  • 3 servo (powered by 4 AAA batteries)
  • 1 relay
  • power supply (9v battery)
    The wiring scheme is close enough to this drawing:
The components initialize and all seem to work well.
I encounter this problem:
When powering on the arduino with a switch, it all seem to work well, and it correctly does its routine of sending the acknowledgment, reading from sensors and writing datas to the sd card. When it is already powered on, and I reset it, it doesn't work well anymore: the code stops executing or gets stuck after about two loops (and having already sent the ack). When the line vw_send((uint8_t *)buff, bufflen); is taken away from the code (the line that sends the acknowledgment), the code fuctions normally even after a reset of the board.
I tried debugging using a Serial.println("something") to see where the code stopped, but it was unconsistent, meaning the codded stopped at different positions, depending on where I placed one more or one less line of code (suggesting that the problem is depending by timing).
So it seems to me that the problem might be one of these:
  • some inductance is causing some component or the arduino to fail when reset, since the components are soldered without any regard towards interference between eachothers (2 decoupling capacitors are placed between the arduino and the power supply)
  • The reset button perhaps isn't the same as powering the board off and on, and skips something that in my case causes a bug
  • There's an incompatibility with some libraries, as I encountered many
your reset button resets the Nano but not the other components. May be they are in some unstable state. Do you have a reset pin on the Radio module? if so, may be worth toggling it in the setup to start from a clean slate.
Please share it.
How do you reset it? With the reset button or through software?
This suggests a memory related issue is creating the problem. The line as quoted seems a little sketchy, hence the request to share the actual code.
There isn't a button, but I can try to find a command that resets the modules and place it before their initialization.
It has something to do with reset, this should be close enough to solve your problem. Posting an annotated schematic would be much better then a wiring diagram. What happened did you pen run out of ink, the wires change colors?
I reset via a button on the arduino
Here is the code:
#include <BMP180I2C.h>
#include <SD.h>
#include "Wire.h"
#include <ServoTimer2.h>
#include <VirtualWire.h>
#define BMP180_I2C_ADDRESS 0x77
#define MPU6050_I2C_ADDRESS 0x68
BMP180I2C bmp180(BMP180_I2C_ADDRESS);
File myFile;
ServoTimer2 S1;  // create servo objects
ServoTimer2 S2;
ServoTimer2 S3;
float gyro[3];
float acc[3];
uint8_t buff[1] = {255};
uint8_t bufflen = sizeof(buff);
uint32_t pressure = 0;
#define l1_s1 14.5//14.5; //length of servo attach
#define l2_s1 26.26//30; //bar length
#define l3_s1 36.5//37; // distance from pin to bar on the 3d printed part
#define Cx_s1 27.91//31.608; //x distance between servo wheel and mount pin
#define Cy_s1 -20.665//-22.165; // y distance
float m_to_s1(float a){ //motor angle to servo angle function
  a = a*PI/180;
  //float l1_s1 = 14.5;//14.5; //length of servo attach
  //float l2_s1 = 26.26;//30; //bar length
  //float l3_s1 = 36.5;//37; // distance from pin to bar on the 3d printed part
  //float Cx_s1 = 27.91;//31.608; //x distance between servo wheel and mount pin
  //float Cy_s1 = -20.665;//-22.165; // y distance
  float px = Cx_s1 + l3_s1*cos(a);
  float py = Cy_s1 + l3_s1*sin(a);
  float d = sqrt(pow(px,2)+pow(py,2));
  float x1 = (pow(l1_s1,2) + pow(d,2) - pow(l2_s1,2)) / (2*d);
  float y1 = sqrt(pow(l1_s1,2) - pow(x1,2));
  float ang = atan2(py,px);
  float x2 = x1*cos(ang)-y1*sin(ang);
  float y2 = x1*sin(ang)+y1*cos(ang);
  return (89 - 83.3102 + atan2(y2,x2)/PI*180); //before was 92
  //return (93 - 83.62104236706482 + atan2(y2,x2)/PI*180); //offset: (93 experimental, 83.62.. calculated)
#define l1_s2 10.5//14.5;
#define l2_s2 25.12//33.5;
#define l3_s2 30.5//32.5;
#define Cx_s2 -26.759//-30.565;
#define Cy_s2 -31.335//-35.335;
float m_to_s2(float a){
  a = a*PI/180;
  //float l1_s2 = 10.5;//14.5;
  //float l2_s2 = 25.12;//33.5;
  //float l3_s2 = 30.5;//32.5;
  //float Cx_s2 = -26.759;//-30.565;
  //float Cy_s2 = -31.335;//-35.335;
  float px = Cx_s2 + l3_s2*cos(a);
  float py = Cy_s2 + l3_s2*sin(a);
  float x1 = -(pow(l1_s2,2) + pow(d,2) - pow(l2_s2,2)) / (2*d);
  float y1 = sqrt(pow(l1_s2,2) - pow(x1,2));
  float x2 = x1*cos(ang)+y1*sin(ang);
  float y2 = x1*sin(ang)-y1*cos(ang);
  return (43-71.3867+atan2(y2,x2)/PI*180); //old offset was 39 degrees, before switching from servo to servotimer2
  //return (85 - 93.3514140156806 + atan2(y2,x2)/PI*180);
float pr_to_alt(uint32_t pr){
  return (44330 * (1 - pow(pr/100800.0,1/5.255))); //put here today's pressure
float g_err0;
float g_err1;
float g_err2;
float a_err0;
float a_err1;
float a_err2;
uint8_t init_err = 0;
unsigned long tic=micros();
unsigned long toc;
unsigned long t0=millis();
unsigned long initial_time;
void get_gyro() {
  Wire.beginTransmission(MPU6050_I2C_ADDRESS);
  Wire.write(0x43); // Gyro data first register address 0x43
  Wire.endTransmission(false);
  Wire.requestFrom(MPU6050_I2C_ADDRESS, 6, true); // Read 4 registers total, each axis value is stored in 2 registers
  gyro[0] = (Wire.read() << 8 | Wire.read()) / 131.0; // For a 250deg/s range we have to divide first the raw value by 131.0, according to the datasheet
  gyro[1] = (Wire.read() << 8 | Wire.read()) / 131.0;
  gyro[2] = (Wire.read() << 8 | Wire.read()) / 131.0;
  gyro[0] -= g_err0;//correct gyro
  gyro[1] -= g_err1;
  gyro[2] -= g_err2;
void get_acc() {
  Wire.write(0x3B); // Accellerometer data first register address 0x43
  acc[0] = (Wire.read() << 8 | Wire.read()) / 4096.0; // 4096 from datasheet
  acc[1] = (Wire.read() << 8 | Wire.read()) / 4096.0;
  acc[2] = (Wire.read() << 8 | Wire.read()) / 4096.0;
  acc[0] -= a_err0;//correct accelerometer
  acc[1] -= a_err1;
  acc[2] -= a_err2;
  S1.attach(8); //outer
  S2.attach(9); //inner
  pinMode(7,OUTPUT);//Relee
  pinMode(13,OUTPUT);
  S3.attach(10);//Chute
  S1.write(map(m_to_s1(90),0,180,600,2400));
  S2.write(map(m_to_s2(90),0,180,600,2400));
  S3.write(map(25,0,180,600,2400));
  //while(1);//used for servo calibration
  if (!SD.begin(6)) {
    init_err += 1;
  vw_set_ptt_pin(A1);
  vw_set_tx_pin(3);
  vw_set_rx_pin(4);
  vw_setup(2000);
  vw_rx_start();
  Wire.begin();
  Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
  //Wire.setWireTimeout(3000, true); //timeout value in uSec
  while (!Serial);
  Wire.beginTransmission(MPU6050_I2C_ADDRESS);       // Start communication with MPU6050 // MPU=0x68
  Wire.write(0x6B);                  // Talk to the register 6B
  Wire.write(0x00);                  // Make reset - place a 0 into the 6B register
  Wire.endTransmission(true);        //end the transmission
  // Configure Accelerometer Sensitivity - Full Scale Range (default +/- 2g)
  Wire.write(0x1C);                  //Talk to the ACCEL_CONFIG register (1C hex)
  Wire.write(0x10);                  //Set the register bits as 00010000 (+/- 8g full scale range)
  if (!bmp180.begin()) {
    init_err += 2;
  bmp180.resetToDefaults();
  bmp180.setSamplingMode(BMP180MI::MODE_UHR);
  digitalWrite(7,LOW);
  while (buff[0]==255){ //waiting for signal
    vw_get_message(buff, &bufflen);
  vw_rx_stop();
  //delay(500);
  t0 = millis();
  tic = micros();
  bmp180.measureTemperature();
  if (SD.exists(F("l.txt"))) SD.remove(F("l.txt"));
  myFile = SD.open(F("l.txt"), FILE_WRITE);
  //myFile.println(F("time\telaps\taction\ta1\ta2\tangle0\tangle1\tangle2\tgyro0\tgyro1\tgyro2\tacc0\tacc1\tacc2\taltitude"));
  initial_time = millis();
  //Serial.println("start");
// ===                    MAIN PROGRAM LOOP                     ===
float a1,a2;
float d1,d2;
float i1,i2;
unsigned long elaps;
float es[3];
float acc_angles[3];
float pe1,pe2,pe3;
float Kp = -1.5;
float Ki = -1;
float Kd = -0.15;
float alt = 0;
float prev_alt;
unsigned long chute_elaps; //checks how much time has passed after the last check_apogee()
uint8_t state = 0b00000010; //[bmp_var first bit, first_time_entering_action second bit]
//bmp_var tells whether to check temperature or pressure measurement
//first time entering action indicates if it's the first time entering a certain if{} statement or some other loop
uint8_t action;
int nloops = 0;
float acc_sum[3];
  //Serial.print(action);
  //Serial.print("\t");
  Serial.println(millis()-t0);
  toc=tic;
  tic = micros();
  elaps = tic-toc; //elapsed time in microseconds
  get_gyro();//gets raw gyro data
  get_acc();//gets raw acc
  get_gyro_angles();
  //get_acc_angles();
  //Serial.println("");
  bmp180_routine();
  if (action==0) { //still
    if (state & 2){ //if second bit is 1
      buff[0] = init_err;
      state ^= 0b10; //swaps second bit back to zero
    if (millis()-t0>5000) {
      //Serial.println("debug");
      pe1 = es[0];
      pe2 = es[1];
      pe3 = es[2];
      prev_alt=alt; //initialize prev_alt
      action=1;
      buff[0] = 1; //buff[0] will contain action
      state ^= 0b10;
      t0=millis();
  if (action==1) { //calibration of mpu, right before launch
    nloops++;
    acc_sum[0] += acc[0];
    acc_sum[1] += acc[1];
    acc_sum[2] += acc[2];
      int dh = millis()-t0;
      g_err0 += (es[0]-pe1)/dh*1000;
      g_err1 += (es[1]-pe2)/dh*1000;
      g_err2 += (es[2]-pe3)/dh*1000;
      a_err0 = acc_sum[0] / nloops;
      a_err1 = acc_sum[1] / nloops - 1;
      a_err2 = acc_sum[2] / nloops;
      es[0]=0;
      es[1]=0;
      es[2]=0;
      i1=0;
      i2=0;
      d1=0;
      d2=0;
      action=2;
      buff[0] = 2;
      state ^= 0b10;
      t0=millis();
      //myFile = SD.open(F("l.txt"), FILE_WRITE);
  if (action==2) {//flight
      digitalWrite(7,HIGH); //LAUNCH
      chute_elaps = millis();
    PIDloop();
    update_servo();
    print_data();
    /*if (millis()-t0>2000) {
      if (millis() - chute_elaps > 500) {
        chute_elaps=millis();
        if (check_apogee()) {
          S3.write(map(170,0,180,600,2400));
          action = 3;
          buff[0] = 3;
          state ^= 0b10;
          t0 = millis();
          myFile.flush();
    if (millis()-t0>10000) { //for test
      action = 3;
      buff[0] = 3;
      state ^= 0b10;
      t0 = millis();
      myFile.flush();
  if (action==3) {//parachute descent
    PIDloop();
    update_servo();
    print_data();
    if (millis()-t0>25000) { //landing after x seconds
      action=4;
      buff[0] = 4;
      state ^= 0b10;
      t0=millis();
  if (action==4) {//close file, still
      myFile.close();
bool check_apogee() {
  if ((alt-prev_alt)<-1.2) {
    return 1;
  else {
    prev_alt = alt;
    return 0;
void bmp180_routine() {
  if  ( (state & 1) == 0) { //reads first bit of state
    if (bmp180.hasValue()) {
      bmp180.getTemperature();
      bmp180.measurePressure();
      state ^= 1; //uses XOR to switch the last bit of state to 1; old was bmp_var = 1;
  else {
      pressure = bmp180.getPressure();
      //alt = weight*alt + (1-weight)*pr_to_alt(pressure) ;//- zero_alt; //relative altitude to starting pos
      alt = pr_to_alt(pressure) ;
      state ^= 1; //swaps last bit of state
void PIDloop() {
  i1 += elaps*(es[0])/1000000;
  i2 += elaps*(es[2])/1000000;
  d1 = gyro[0];
  d2 = gyro[2];
  a1 = 90 + Kp*(es[0]) +Kd*d1 +Ki*i1;
  a2 = 90 + Kp*(es[2]) +Kd*d2 +Ki*i2;
  //bounds
  if (a1>95) a1=95;
  if (a1<85) a1=85;
  if (a2>95) a2=95;
  if (a2<85) a2=85;
  if (Ki*i1>10) i1=10/Ki;
  if (Ki*i1<-10) i1=-10/Ki;
  if (Ki*i2>10) i2=10/Ki;
  if (Ki*i2<-10) i2=-10/Ki;
void update_servo() {
  //update servo position
  S1.write(map(m_to_s1(a1),0,180,600,2400));
  S2.write(map(m_to_s2(a2),0,180,600,2400));
void get_gyro_angles() {
  es[0] += (elaps*(gyro[0]))/1000000;
  es[1] += (elaps*(gyro[1]))/1000000;//roll
  es[2] += (elaps*(gyro[2]))/1000000;
void get_acc_angles() {
  acc_angles[0] = - RAD_TO_DEG * atan2(sqrt(pow(acc[1],2) + pow(acc[0],2)),acc[2]) + 90;
  acc_angles[1] = 0;
  acc_angles[2] = (RAD_TO_DEG * atan2(sqrt(pow(acc[1],2) + pow(acc[2],2)),acc[0]) -90 );
void print_data() {
  myFile.print(millis()-initial_time);
  myFile.print("\t");
  myFile.print(elaps);
  myFile.print("\t");
  myFile.print(action);
  myFile.print("\t");
  myFile.print(a1);
  myFile.print("\t");
  myFile.print(a2);
  myFile.print("\t");
  myFile.print(es[0]);
  myFile.print("\t");
  myFile.print(es[1]);
  myFile.print("\t");
  myFile.print(es[2]);
  myFile.print("\t");
  myFile.print(gyro[0]);
  myFile.print("\t");
  myFile.print(gyro[1]);
  myFile.print("\t");
  myFile.print(gyro[2]);
  myFile.print("\t");
  myFile.print(acc[0]);
  myFile.print("\t");
  myFile.print(acc[1]);
  myFile.print("\t");
  myFile.print(acc[2]);
  myFile.print("\t");
  myFile.println(alt,2);
And here's the code of the other arduino, that sends the first signal:
//#include <RH_ASK.h>
//#include <SPI.h>
//RH_ASK mod(2000, 7, 6 , A1);
uint8_t buff[1]={0};
uint8_t bufflen = 1;
long int t0;
#define r 3
#define g 5
#define b 11
  vw_set_ptt_pin(A1);
  vw_set_tx_pin(6);
  vw_set_rx_pin(7);
  vw_setup(2000);
  pinMode(r,OUTPUT);
  pinMode(g,OUTPUT);
  pinMode(b,OUTPUT);
  analogWrite(r,255);
  analogWrite(g,0);
  analogWrite(b,0);
  pinMode(13,OUTPUT);
  //if (!mod.init()){
  //  Serial.println("module init failed");
  //if (!ric.init()){
   // Serial.println("receiver init failed");
  vw_rx_start();
  Serial.println("\nmodule init success");
  //while(Serial.available() == 0) {}
  Serial.println("packet transmitted");
  delay(100);
  //vw_wait_tx();
  t0 = millis();
  //digitalWrite(13, buff[0]);
  //mod.send((uint8_t *)buff, bufflen);
  //mod.send((uint8_t *)start, 1);
  //mod.waitPacketSent();
  //buff[0] = !buff[0];
  /*if (!mod.recv(buff, &bufflen)){
    Serial.println("pacchetto non ricevuto");
  else{
    digitalWrite(5, buff[0]);
  //if (mod.recv(buff, &bufflen)) {
  if (vw_get_message(buff, &bufflen)) {
    Serial.print((millis()-t0)/1000.0,3);
    Serial.print("\tsec\t");
    switch (buff[0]) {
      case (0) :
        analogWrite(r,0);
        analogWrite(g,255);
        analogWrite(b,0);
        Serial.println("ack");
      case (1) :
        analogWrite(r,0);
        analogWrite(g,255);
        analogWrite(b,255);
        Serial.println("calibration");
      case (2) :
        analogWrite(r,0);
        analogWrite(g,0);
        analogWrite(b,255);
        Serial.println("launch");
      case (3) :
        analogWrite(r,255);
        analogWrite(g,255);
        analogWrite(b,255);
        Serial.println("chute");
      /*case (10) :
        analogWrite(r,0);
        analogWrite(g,0);
        analogWrite(b,0);
      case (11) :
        analogWrite(r,0);
        analogWrite(g,0);
        analogWrite(b,0);
      case (12) :
        analogWrite(r,0);
        analogWrite(g,0);
        analogWrite(b,0);
      case (13) :
        analogWrite(r,0);
        analogWrite(g,0);
        analogWrite(b,0);
      break;*/
  //delay(500);
red wires arer jumping wires. I did it so it was easier for me to solder with a scheme in front of me
Strip out everything related to the sensors, leaving just the RF24 related code. Run the device with just that, plugging random values for the wireless transmission data. See if the problem persists.
In other words: reduce the code to the bare minimum that reproduces the problem, so it becomes easier to solve.
I'm with @gilshultz in that "close enough" is never good enough for a schematic. It's either representative of the real circuit, or it isn't.
may be add a transistor to drive the power of the module
it's not that bad, very C style.
In C++ you probably would write
vw_send(static_cast<uint8_t *>(buff), bufflen);
( If buff a pointer type (e.g., char* ), static_cast is appropriate. of course ideally buf would hold uint8_t data and be of the right type already)
I understand and in principle it can work fine. The sketchy part is that this reeks of potential issues with a buffer that's dynamically sized (at least in part of the code) and part of the code addressing this array out of bounds. It's not just that line - it's the context in which it occurs, including OP's apparent level of skill which is also evidenced from the question they ask.
I see lots of problems. You need to look at each of the datasheets for the components you use, note there major characteristics, then draw an annotated schematic of how you plan on wiring it, not a wiring diagram. Be sure each device is properly interfaced to the Arduino.
To be honest I am amazed it works and has not become a crispy critter. This may help:
Gil's Crispy Critter Rules, they apply to processor hardware:
Rule #1. A Power Supply the Arduino is NOT!
Rule #2. Never Connect Anything Inductive (motor, speaker) to an Arduino!
Rule #3 Don't connecting or disconnecting wires with power on.
Rule #4 Do not apply power to any pin unless you know what you are doing.
Rule #5 Do not exceed maximum Voltages.
Rule #6 Many Arduinos will not power a transmitter.
Rule #7 Take a break and check the wiring before powering the project.
LaryD's Corollary's
Coro #1 when first starting out, add a 220R resistor in series with both Input and Output pins.
Coro #2 buy a DMM (Digital Multi-meter) to measure voltages, currents and resistance.
Violating these rules tends to make crispy critters out of Arduinos.
Hint: It is best to keep the wires under 25cm/10" for good performance.
I did look at their data sheets to make sure I wasn’t connecting anything to the wrong pin or voltage, and the components are working.
I tested the transmitter with both its own 9V alimentation and the 5v Arduino alimentation, and for my purposes they both work fine range-wise
What are the wrong things you see?
I agree that playing with pointers and buffers can be catchy in general for beginners.
OP is using virtual wire and probably borrowed the cast idea from examples
also he limited his risk with a 1 byte buffer
and correctly using only buff[0] throughout the code.
(someone more seasoned would not have used an array and just a uint8_t)
Yes i did. I didn't use the newer library Radiohead because I found some incompatibilities with SD.h when debugging, and virtualwire is lighter memory wise.
you are right the array is not needed, a uint8_t would be just as fine, I'll look into it better and modify
At this point the only thing left is to advice you to read the Arduino Cookbook cover to cover then re-read the sections appurtenant to your project.
You need some basic understanding of electronics, while you are waiting for the cookbook to arrive follow several tutorials on basic electronics and of course Ohm's law.
We know what you posted was a wiring diagram, since you have a schema post that and save all of us a lot of valuable time.
@rsmls I followed your advice and stripped out everything but the RF related code. It worked fine even after resets. Then I added back bit by bit parts of code, and the problem happened again when adding the I2C protocol code, needed for the mpu6050 and bmp180. I think the bug was related to the wire.h clock, because i fixed it by adding the line Wire.setWireTimeout(3000, true); //timeout value in uSec after the line Wire.setClock(400000);. So now, with this line added, the code runs well EVEN AFTER a reset of the Arduino.
Something weird keeps happening: I'm Serial.printing the current elapsed time from a certain action in milliseconds, and when the timer resets, this gets printed:
immagine
(values in ms, going from 10 seconds back to 0)
Note 1: At the same time of the timer reset, the rf transmitter sends a message to the other Arduino, and removing the line vw_send would also have the effect of the code not locking up (if no timeout was set).
My bet is that the rf transmitter causes interference with the Serial communication and some other components, altering what characters should get printed, and locking up the code
So it might be that adding the WireTimeout line fixes the problem, but for the wrong reason
Note 2: slowing down the Serial baud to 9600 suppresses (meaning that less chars get corrupted in average) the problem showed above.
THANK YOU FOR YOUR TIME!
For reference, this is the debug code with everything stripped out apart for what was needed (also changed buff[1] to just be a uint8_t)
#include "Wire.h"
uint8_t buff = 255;
unsigned long t0 = 0;
uint8_t action = 0;
uint8_t state = 0b00000010; //second bit used for loops, first used for bmp180 protocol, absent in this sketch
float gyro[3];
  vw_set_ptt_pin(A1);
  vw_set_tx_pin(3);
  vw_set_rx_pin(4);
  vw_setup(2000);
  vw_rx_start();
  Wire.begin();
  while (!Serial);
  while (buff==255){ //waiting for signal
    vw_get_message(&buff, &bufflen);
  vw_rx_stop();
  t0 = millis();
  get_gyro();
      buff = 0;
      vw_send(&buff, bufflen);
      action=1;
      buff = 1; //buff[0] will contain action
      state ^= 0b10;
      t0=millis();
  if (action==1) { //still
      buff = 1;
      action=2;
      buff = 2; //buff[0] will contain action
      state ^= 0b10;
      t0=millis();
    if (action==2) { //still
      buff = 2;
      action=3;
      buff = 3; //buff[0] will contain action
      state ^= 0b10;
      t0=millis();
void get_gyro() {
  //gyro[0] -= g_err0;//correct gyro
  //gyro[1] -= g_err1;
  //gyro[2] -= g_err2;
