code for acs712 current sensor
hi guys.. i have developed a project where i am using acs712 current sensor to measure current of home appliances i.e ac load connected to 230v AC mains.when i dont connect any load its showing 0.18 amps. when i connect a 15W bulb it shows 0.31 amps but its fluctuating from 0.26 Amp to 0.31 amp. also when i connect a bigger load like a soldering iron it doesnt show any significant change in current. please help me with the code.
your help would be much appreciated.
below is the code:
const float acsOut =A0;
int acsSensitivity =66;
float voltage =0;
float vRms=0;
float ampRms=0;
float voltage =getVpp();
vRms =(voltage/2.0)*0.707;
ampRms =(vRms*1000)/acsSensitivity;
Serial.println("amps Rms");
Serial.println(ampRms);
float getVpp()
float result;
int readValue;
int maxValue=0;
int minValue=1024;
uint32_t start_time=millis();
while((millis()-start_time < 1000))
    readValue =analogRead(acsOut);
    if(readValue > maxValue)
       maxValue=readValue;
    if(readValue < minValue)
       minValue=readValue;
result=((maxValue-minValue)*5.0)/1024.0;
return result;
Test your circuit by writing a simple code to read the sensor and output the analogue value to the serial monitor.
Once you have proven the basic read works, add the rest.
Weedpharma
HI
I am currently facing a similar problem. How did you solve it?
If you have similar problems, you might made the same errors in the setup. Post a wiring diagram of your setup and post your code. The OP's code does read maxima/minima values which usually don't make sense.
pylon:
It does if you want to read AC current.
OP did use a 30Amp sensor (the 66mV/A).
That, and the 10-bit A/D of an Arduino, will give a resolution of about 20watt per A/D step.
Too course to detect a 15watt lightbulb.
Leo..
P.S. The ACS712, and the boards they are mounted on, are not designed for 230volt mains.
A (clip-on) current transformer is much safer.
Leo..
But, the data sheets of ACS712 has provided the following information which indicates that there is ensured/tested isolation between the 230V hot circuit and the low voltage side!
The datasheet also mentions a max working voltage of 184volt peak (~128volt AC).
AFAIK 230volt AC requires 4kV test isolation.
There is also the ACS758.
Leo..
