Code for variance in SetPoint
I have an adjustable setpoint that controls a relay based on the input from a DS18B20.
What code would enable a variance around a desired SetPoint of 0.5 deg C.
Example:
I adjust the set point to 45 deg C. Though to stop the relay switching on/off erratically around that temperature I'd like to have a variance of 0.5 deg C either side of the SetPoint. So the relay switches on at 44.5 and off at 45.5.
Would I use if else statements or is there another way?
Thanks
Yes.
   if(temp > SetPoint-0.5 && temp < SetPoint+0.5)
      // temp is within 1/2 a degree of the setpoint
mack85n:
The term you're looking for is Hysteresis.
const float variance = 0.5; //degrees C, plus or minus
float setpoint = 45.0;
  //set up things here, make output pins outputs...
  float temp = readTemperatureC();
  if(temp > setpoint + variance)  {
    Serial.println("Relay on!");
    relayOn();
  if(temp < setpoint - variance) {
    Serial.println("Relay OFF");
    relayOff();
Thanks,
There looks to be a few ways to achieve the hysteresis I'm looking for.
