Code help please?
Here's the code I tried to add to the earlier post.
/*  ReadThreeRc
 *  modified by Duane Degn
 *  Original notes below.
// MultiChannels
// rcarduino.blogspot.com
// A simple approach for reading three RC Channels using pin change interrupts
// See related posts -
// http://rcarduino.blogspot.co.uk/2012/01/how-to-read-rc-receiver-with.html
// http://rcarduino.blogspot.co.uk/2012/03/need-more-interrupts-to-read-more.html
// http://rcarduino.blogspot.co.uk/2012/01/can-i-control-more-than-x-servos-with.html
// include the pinchangeint library - see the links in the related topics section above for details
#include <PinChangeInt.h>
#include <Servo.h>
// Assign your channel in pins
#define THROTTLE_IN_PIN 8
#define STEERING_IN_PIN 9
#define AUX_IN_PIN 10
// Assign your channel out pins
#define THROTTLE_OUT_PIN 5
#define STEERING_OUT_PIN 6
#define AUX_OUT_PIN 7
// Servo objects generate the signals expected by Electronic Speed Controllers and Servos
// We will use the objects to output the signals we read in
// this example code provides a straight pass through of the signal with no custom processing
Servo servoThrottle;
Servo servoSteering;
Servo servoAux;
// These bit flags are set in bUpdateFlagsShared to indicate which
// channels have new signals
#define THROTTLE_FLAG 1
#define STEERING_FLAG 2
#define AUX_FLAG 4
// holds the update flags defined above
volatile uint8_t bUpdateFlagsShared;
// shared variables are updated by the ISR and read by loop.
// In loop we immediatley take local copies so that the ISR can keep ownership of the
// shared ones. To access these in loop
// we first turn interrupts off with noInterrupts
// we take a copy to use in loop and the turn interrupts back on
// as quickly as possible, this ensures that we are always able to receive new signals
volatile uint16_t unThrottleInShared;
volatile uint16_t unSteeringInShared;
volatile uint16_t unAuxInShared;
// These are used to record the rising edge of a pulse in the calcInput functions
// They do not need to be volatile as they are only used in the ISR. If we wanted
// to refer to these in loop and the ISR then they would need to be declared volatile
uint32_t ulThrottleStart;
uint32_t ulSteeringStart;
uint32_t ulAuxStart;
unsigned long loopCount = 0;
unsigned long channelCount[3];
unsigned long previousCount[] = {0, 0, 0};
unsigned long nowTime;
unsigned long lastTime;
const unsigned long TWENTY_MS = 20;
uint16_t pulseLength[3];
  Serial.println("multiChannels");
  // attach servo objects, these will generate the correct
  // pulses for driving Electronic speed controllers, servos or other devices
  // designed to interface directly with RC Receivers
  servoThrottle.attach(THROTTLE_OUT_PIN);
  servoSteering.attach(STEERING_OUT_PIN);
  servoAux.attach(AUX_OUT_PIN);
  // using the PinChangeInt library, attach the interrupts
  // used to read the channels
  PCintPort::attachInterrupt(THROTTLE_IN_PIN, calcThrottle,CHANGE);
  PCintPort::attachInterrupt(STEERING_IN_PIN, calcSteering,CHANGE);
  PCintPort::attachInterrupt(AUX_IN_PIN, calcAux,CHANGE);
  lastTime = millis();
  // create local variables to hold a local copies of the channel inputs
  // these are declared static so that thier values will be retained
  // between calls to loop.
  static uint16_t unThrottleIn;
  static uint16_t unSteeringIn;
  static uint16_t unAuxIn;
  // local copy of update flags
  static uint8_t bUpdateFlags;
  loopCount++;
  if (loopCount == 1000000)
    loopCount = 0;
    nowTime = millis();
    pulseLength[0] = unThrottleInShared;
    pulseLength[1] = unSteeringInShared;
    pulseLength[2] = unAuxInShared;
    //Serial.println("----------------------------------------------");
    Serial.print("time since last = ");
    Serial.print(nowTime - lastTime,DEC);
    Serial.print(" ms, expected new count = ");
    Serial.print((nowTime - lastTime) / TWENTY_MS, DEC);
    lastTime = nowTime;
    for (byte i=0; i < 3; i++)
      Serial.print(", [");
      Serial.print(i,DEC);
      Serial.print("] total = ");
      Serial.print(channelCount[i],DEC);
      Serial.print(", new = ");
      Serial.print(channelCount[i] - previousCount[i],DEC);
      Serial.print(", pulse = ");
      Serial.print(pulseLength[i],DEC);
      previousCount[i] = channelCount[i];
    Serial.println();
  // check shared update flags to see if any channels have a new signal
  if(bUpdateFlagsShared)
    noInterrupts(); // turn interrupts off quickly while we take local copies of the shared variables
    // take a local copy of which channels were updated in case we need to use this in the rest of loop
    bUpdateFlags = bUpdateFlagsShared;
    // in the current code, the shared values are always populated
    // so we could copy them without testing the flags
    // however in the future this could change, so lets
    // only copy when the flags tell us we can.
    if(bUpdateFlags & THROTTLE_FLAG)
      unThrottleIn = unThrottleInShared;
    if(bUpdateFlags & STEERING_FLAG)
      unSteeringIn = unSteeringInShared;
    if(bUpdateFlags & AUX_FLAG)
      unAuxIn = unAuxInShared;
    // clear shared copy of updated flags as we have already taken the updates
    // we still have a local copy if we need to use it in bUpdateFlags
    bUpdateFlagsShared = 0;
    interrupts(); // we have local copies of the inputs, so now we can turn interrupts back on
    // as soon as interrupts are back on, we can no longer use the shared copies, the interrupt
    // service routines own these and could update them at any time. During the update, the
    // shared copies may contain junk. Luckily we have our local copies to work with :-)
  // do any processing from here onwards
  // only use the local values unAuxIn, unThrottleIn and unSteeringIn, the shared
  // variables unAuxInShared, unThrottleInShared, unSteeringInShared are always owned by
  // the interrupt routines and should not be used in loop
  // the following code provides simple pass through
  // this is a good initial test, the Arduino will pass through
  // receiver input as if the Arduino is not there.
  // This should be used to confirm the circuit and power
  // before attempting any custom processing in a project.
  // we are checking to see if the channel value has changed, this is indicated
  // by the flags. For the simple pass through we don't really need this check,
  // but for a more complex project where a new signal requires significant processing
  // this allows us to only calculate new values when we have new inputs, rather than
  // on every cycle.
    channelCount[0]++;
    if(servoThrottle.readMicroseconds() != unThrottleIn)
      servoThrottle.writeMicroseconds(unThrottleIn);
    channelCount[1]++;
    if(servoSteering.readMicroseconds() != unSteeringIn)
      servoSteering.writeMicroseconds(unSteeringIn);
    channelCount[2]++;
    if(servoAux.readMicroseconds() != unAuxIn)
      servoAux.writeMicroseconds(unAuxIn);
  bUpdateFlags = 0;
// simple interrupt service routine
void calcThrottle()
  // if the pin is high, its a rising edge of the signal pulse, so lets record its value
  if(digitalRead(THROTTLE_IN_PIN) == HIGH)
    ulThrottleStart = micros();
    // else it must be a falling edge, so lets get the time and subtract the time of the rising edge
    // this gives use the time between the rising and falling edges i.e. the pulse duration.
    unThrottleInShared = (uint16_t)(micros() - ulThrottleStart);
    // use set the throttle flag to indicate that a new throttle signal has been received
    bUpdateFlagsShared |= THROTTLE_FLAG;
void calcSteering()
  if(digitalRead(STEERING_IN_PIN) == HIGH)
    ulSteeringStart = micros();
    unSteeringInShared = (uint16_t)(micros() - ulSteeringStart);
    bUpdateFlagsShared |= STEERING_FLAG;
void calcAux()
  if(digitalRead(AUX_IN_PIN) == HIGH)
    ulAuxStart = micros();
    unAuxInShared = (uint16_t)(micros() - ulAuxStart);
    bUpdateFlagsShared |= AUX_FLAG;
