Code implementation for classifying colors according to the RGB range
Hi!
I am interested in making a device that knows how to classify colors and for that I use the TCS3200 module. I see tables like the ones I will attach below and I assume that the RGB values I will get from the TCS3200 will not be exactly as in the table but similar to them for the obvious reason that each object has a slightly different shade (purple a little darker, purple A little brighter, etc...).
My question is, is it possible to define a range of values for each particular color?
If there is a way how can it be implemented in code?
Guess there are quite a few people here who have come across this question...
You could calculate a 'distance' between the readings and each of the named colors to find the closest.
size_t FindNearestColor( int R, int G, int B)
  size_t nearestIndex = 0;
  uint32_t nearestDistance = 255 * 255 * 255;
  for (size_t i = 0; i < NumberOfNamedColors; i++)
    uint32_t deltaR = NamedColor[i].red - R;
    uint32_t deltaG = NamedColor[i].green - G;
    uint32_t deltaB = NamedColor[i].blue - B;
    uint32_t distance = (deltaR * deltaR)
       + (deltaG * deltaG) + (deltaB * deltaB);
    // Actual distance is sqrt(distance) but we are only
    // comparing them so the extra sqrt() doesn't change
    // anything.
    if (distance < nearestDistance)
      nearestDistance = distance;
      nearestIndex = i;
  return nearestIndex;
Thank you! Very nice idea! :sunglasses:
?Why was this value chosen in order to subtract from it the read value of the RGB values
I was in a hurry. I should have used "3 * (255ul*255ul)" which is the largest possible distance. The distance between black (0,0,0) and white (255,255,255).
!Now I understand! Thank you
