Hi, I found a library that allows a teensy to comunicate with an sbus receiver. I need to pass the data received (an array of integers) to another board with I2C. I can see things happening on the board connected to the SBUS receiver but nothing on the board that's supposed to receive the array of data via I2C. Hope that makes sense.
I've also other i2c devices connected to the same bus (don't know if that can cause problems).
Here are the 2 programs:
Transmitter:
#include <Wire.h>
/* SBUS object, reading SBUS */
bfs::SbusRx sbus_rx(&Serial2);
bfs::SbusData data;
const int channelNumber = 16;
int channels[channelNumber];
/* Serial to display data */
while (!Serial);
sbus_rx.Begin();
Wire.begin();
void loop () {
if (sbus_rx.Read()) {
/* Grab the received data */
data = sbus_rx.data();
/* Display the received data */
for (int8_t i = 0; i < data.NUM_CH; i++) {
channels[i] = data.ch[i];
Serial.print(data.ch[i]);
Serial.print("\t");
Wire.beginTransmission(8);
for(int i = 0; i < channelNumber; i++){
Wire.write(channels[i]);
Wire.endTransmission();
Receiver:
<#include<Wire.h>
int receiverChannels[channelNumber];
Wire.begin(8);
Wire.onReceive(receiveEvent);
while(!Serial);
void receiveEvent(int byteCount){
if(Wire.available()){
byte b = 0;
b = Wire.read();
receiverChannels[i] = b;
Serial.print(receiverChannels[i]); Serial.print(" ");
There are not pullup resistors. The i2c is working and has being tested with other devices connect to the same bus. The SBUS data are changing according to the rc
void loop () {
Serial.print("\t");
You are sending the data over I2C continuously, every time loop() executes, instead of once after it is received from the sbus.
#include <Wire.h>
Wire.begin(8);
while(!Serial);
byte b = 0;
b = Wire.read();
receiveEvent() is an interrupt handler, you really should not be printing inside that function. Also, if you use the receiverChannels array outside the receiveEvent() function, it should be declared volatile.
As to my previous comment, Wire.write() only sends a single byte, an int is two bytes (on most arduino's), so you are only sending the first byte of the number, anything over 255, or negative, will not be sent correctly.
