You need to have your variables global if you want the ability to pass/change the variables from function to function.
Or use local variables if only that function needs them.
Also, have all the work done in your ReadDS3231 function. Just use loop to call functions and time events.
Like so for global variables:
#include <DS3231.h> //RTC
#include <Wire.h> //OBA
#include <LCD.h> //LCD
#include <LiquidCrystal_I2C.h> //LCD
#define I2C_ADDR 0x27 // Define I2C Address where the PCF8574A is
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
int n = 1;
LiquidCrystal_I2C lcd(I2C_ADDR, En_pin, Rw_pin, Rs_pin, D4_pin, D5_pin, D6_pin, D7_pin);
//RTC
DS3231 Clock;
bool Century = false;
bool h12;
bool PM;
byte ADay, AHour, AMinute, ASecond, ABits;
bool ADy, A12h, Apm;
//These are now global and can be seen/used/changed by any function you want
int second, minute, hour, date, month, year, temperature;
// LED IS ON I/O 12
pinMode (12, OUTPUT);
digitalWrite(12, LOW);;
// Start the I2C interface
Wire.begin();
lcd.begin (16, 2);
// Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
lcd.setBacklight(HIGH);
lcd.home (); // go home
// Start the serial interface
// CODE TO CHECK TIME AND LIGHT UP THE LED
void ReadDS3231()
second = Clock.getSecond();
minute = Clock.getMinute();
hour = Clock.getHour(h12, PM);
date = Clock.getDate();
month = Clock.getMonth(Century);
year = Clock.getYear();
temperature = Clock.getTemperature();
// Code from loop moved here
Serial.println(hour);
if (hour == 12) {
digitalWrite(12, HIGH);
lcd.setCursor ( 0, 0 ); // kolona 0, linija 1
lcd.print(date, DEC);
lcd.setCursor ( 2, 0 );
lcd.print('.');
lcd.setCursor ( 3, 0 );
lcd.print(month, DEC);
lcd.setCursor ( 5, 0 );
lcd.print('.');
lcd.setCursor ( 6, 0 );
lcd.print("20");
lcd.setCursor ( 8, 0 );
lcd.print(year, DEC);
lcd.setCursor ( 0, 1 );
lcd.print(second, DEC);
lcd.setCursor ( 2, 1 );
lcd.print(':');
lcd.setCursor ( 3, 1 );
lcd.print(minute, DEC);
lcd.setCursor ( 5, 1 );
lcd.print(':');
lcd.setCursor ( 6, 1 );
lcd.print(hour, DEC);
lcd.setCursor ( 11, 1 );
lcd.print("T=");
lcd.setCursor ( 13, 1 );
lcd.print(temperature);
lcd.setCursor ( 15, 1 );
lcd.print("C");
ReadDS3231();
And for local variables:
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
int n = 1;
//RTC
DS3231 Clock;
bool h12;
bool PM;
// LED IS ON I/O 12
Wire.begin();
lcd.begin (16, 2);
void ReadDS3231()
//These are now local and can only be seen/used/changed by this function
if (hour == 12) {
lcd.print('.');
lcd.print('.');
lcd.print("20");
lcd.print(':');
lcd.print(':');
lcd.print("T=");
lcd.print("C");
ReadDS3231();
This is the simple explanation for using global or local.
