Hello,
am trying to do bit access to IO pins on arduino pro mini 16MHz, 5V (atmega328p)
It looks like Arduino IDE ignores the second half of code and removes it away due optimization.
No signal is measured on pins EN, RS by oscilloscope. I am able to find the arduiono output .elf file and run it in simulator in Microchip studio to be able to see the actual disassembly code.
Aim: I try this bit access because of am trying a someone else's C code to drive 1x16 LCD OLED display (raystar REC001601BYPP5N00100)
#include <inttypes.h>
#include "Arduino.h"
// program for testing LCD display
// PB0 LCD_RS
// PB1 LCD_RW
// PB2 LCD_EN
// PD0 LCD_D0
// PD1 LCD_D1
// PD2 LCD_D2
// PD3 LCD_D3
// PD4 LCD_D4
// PD5 LCD_D5
// PD6 LCD_D6
// PD7 LCD_D7
inline void sendByte(uint8_t c)
PORTD = c;
inline void lcd_rs_hi( void)
PORTB |= _BV(PB0);
inline void lcd_rs_low( void)
PORTB &= ~_BV(PB0);
inline void lcd_rw_hi( void)
PORTB |= _BV(PB1);
inline void lcd_rw_low( void)
PORTB &= ~_BV(PB1);
inline void lcd_en_hi( void)
PORTB |= _BV(PB2);
inline void lcd_en_low( void)
PORTB &= ~_BV(PB2);
inline void lcd_init_ports( void)
PORTD = 0;
PORTB &= ~(0x07);
DDRD |= 0xFF; // 0b1111'1111
DDRB |= 0x07; // 0b0000'0111
/* local function to generate some delay */
void delay_short(uint8_t cnt) {
uint8_t i;
for (i = 0; i < cnt; i++) {
asm volatile("nop\n");
/* local function to generate ms delay */
void delay_long(uint8_t cnt) {
uint8_t i, j;
for (j = 0; j < cnt; j++) {
for (i = 0; i < 2000; i++) {
/* Function to send the command to LCD */
void Lcd_CmdWrite(char cmd) {
sendByte(cmd); //Send the Command
lcd_rs_low(); // Send LOW pulse on RS pin for selecting Command register
lcd_rw_low(); // Send LOW pulse on RW pin for Write operation
lcd_en_hi(); // Generate a High-to-low pulse on EN pin
delay_long(1); // 1ms
lcd_en_low();
delay_long(10); // 10ms
/* Function to send the data to LCD */
void Lcd_DataWrite(char dat) {
sendByte(dat); //Send the data
lcd_rs_hi(); // Send LOW pulse on RS pin for selecting Command register
lcd_en_low();
// config
lcd_init_ports();
delay_long(500); // 500ms
while (1) {
Lcd_CmdWrite(0x38); // Function set, N=1, F=0, FT1=0, FT2=0
Lcd_CmdWrite(0x0E); // Display ON/OFF, D=1, C=1, B=0
Lcd_CmdWrite(0x01); // Display Clear
Lcd_CmdWrite(0x02); // Display Return Home
Lcd_CmdWrite(0x04); // Entry mode set I/D=0, SH=0
Lcd_DataWrite('H');
Lcd_DataWrite('e');
Lcd_DataWrite('l');
Lcd_DataWrite('l');
Lcd_DataWrite('o');
Lcd_DataWrite(' ');
Lcd_DataWrite('w');
Lcd_DataWrite('o');
Lcd_DataWrite('r');
Lcd_DataWrite('l');
Lcd_DataWrite('d');
delay_long(5000); // 5000ms
