I suspect it might be a memory overflow of somekind but I'm really not sure
Here is my code:
#include <Adafruit_GFX.h>
#include <ClickEncoder.h>
#include <TimerOne.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// Variables
const int rotarySpeed = 4;
int itemsNum = 7;
const int mainNum = 7;
String mainMenu[7] = {"PAUSE", "MOTOR_1", "MOTOR_2", "MOTOR_3", "MOTOR_4", "UNIT", "RESET"};
const int unitNum = 3;
//String asd = "asd";
//String unitMenu[3] = {"RPM", "STEP/MIN", "MILILITER/MIN"};
const int motorNum = 4;
String motorMenu[4] = {"SPEED", "STOP", "START", "BACK"};
String menuItems[7];
int selectedItem = 0;
int selectedPos = 0;
boolean paused = false;
ClickEncoder *encoder;
int16_t last, value;
void timerIsr() {
encoder->service();
memcpy(menuItems, mainMenu, sizeof(mainMenu));
encoder = new ClickEncoder(3, 2, 4);
encoder->setAccelerationEnabled(false);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
Timer1.initialize(1000);
Timer1.attachInterrupt(timerIsr);
last = encoder->getValue();
ClickEncoder::Button b = encoder->getButton();
if (b != ClickEncoder::Open) {
switch (b) {
case ClickEncoder::Clicked:
buttonPressed();
value += encoder->getValue();
if (round(value / rotarySpeed) % itemsNum < 0) {
selectedItem = itemsNum + (value / rotarySpeed % itemsNum);
selectedItem = round(value / rotarySpeed) % itemsNum;
if (value / rotarySpeed > last) {
//down
last = value / rotarySpeed;
if (selectedPos == 0) {
selectedPos = 1;
} else if (selectedPos == 1) {
selectedPos = 2;
} else if (value / rotarySpeed < last) {
//up
if (selectedPos == 2) {
selectedPos = 1;
selectedPos = 0;
drawMenu();
Serial.print(selectedItem);
Serial.print(", ");
Serial.print(selectedPos);
Serial.print(", ");
Serial.print(value);
Serial.print(", ");
Serial.print((value / rotarySpeed) % itemsNum);
delay(10);
void buttonPressed() {
if (true) {
switch (selectedItem) {
case 0:
paused = true;
case 1:
memcpy(menuItems, motorMenu, sizeof(motorMenu));
itemsNum = motorNum;
selectedPos = 0;
case 2:
selectedPos = 0;
case 3:
selectedPos = 0;
case 4:
selectedPos = 0;
case 5:
//memcpy(menuItems, unitMenu, sizeof(unitMenu));
//itemsNum = unitNum;
selectedPos = 0;
case 6:
//reset
void drawMenu() {
display.setTextColor(BLACK, WHITE);
display.setCursor(0, 0);
display.setTextSize(2);
display.print("MENU");
display.setTextSize(1);
display.setCursor(0, 16);
display.print(menuItems[selectedItem]);
display.setTextColor(WHITE, BLACK);
display.setCursor(0, 32);
display.print(menuItems[(selectedItem + 1) % itemsNum]);
display.setCursor(0, 48);
display.print(menuItems[(selectedItem + 2) % itemsNum]);
if (selectedItem == 0) {
display.print(menuItems[itemsNum - 1]);
display.print(menuItems[selectedItem - 1]);
if (selectedItem <= 1) {
display.print(menuItems[itemsNum + (selectedItem - 2) % itemsNum]);
display.print(menuItems[selectedItem - 2]);
display.display();
If I uncomment the line: String unitMenu[3] = {"RPM", "STEP/MIN", "MILILITER/MIN"}; the code stops working completely but if I only uncomment the line above it a strange glitch appears in the bottom right corner of the screen. (Picture attached)
The purpose of this code is a small menu navigatable by a rotary encoder.
