Code to control robotic hand
I built a robotic hand as shown at GitHub - pollen-robotics/AmazingHand: Code and model to control the AH!
I use Arduino Mega to control the robotic hand. I may have made a mistake when writing the code.
When I enter a number to close the fingers, the fingers should close and don’t open. How can I fix the problem?
#include <SCServo.h>
SCSCL sc;
int ID_1 = 11;
int ID_2 = 12;
int ID_3 = 13;
int ID_4 = 14;
int ID_5 = 15;
int ID_6 = 16;
int ID_7 = 17;
int ID_8 = 18;
int MiddlePos_1 = 511;
int MiddlePos_2 = 511;
int MiddlePos_3 = 511;
int MiddlePos_4 = 511;
int MiddlePos_5 = 511;
int MiddlePos_6 = 511;
int MiddlePos_7 = 511;
int MiddlePos_8 = 511;
  Serial1.begin(1000000);
  sc.pSerial = &Serial1;
  Serial.println("1. Finger1 Open");
  Serial.println("2. Finger1 Close");
  Serial.println("3. Finger2 Open");
  Serial.println("4. Finger2 Close");
  Serial.println("5. Finger3 Open");
  Serial.println("6. Finger3 Close");
  Serial.println("7. Finger4 Open");
  Serial.println("8. Finger4 Close");
  Serial.println("9. All Fingers Open");
  Serial.println("0. All Fingers Close");
  int menuChoice = Serial.parseInt();
  Serial.println("Which Finger do you want to open or close? ");
  switch (menuChoice) {
    case 0:
      Serial.println("All Fingers are open  ");
      sc.RegWritePos(ID_1, MiddlePos_1-300, 0, 500); //Servo 1
      sc.RegWritePos(ID_2, MiddlePos_2+300, 0, 500); //Servo 2
      sc.RegWritePos(ID_3, MiddlePos_3-300, 0, 500); //Servo 1
      sc.RegWritePos(ID_4, MiddlePos_4+300, 0, 500); //Servo 2
      sc.RegWritePos(ID_5, MiddlePos_5-300, 0, 500); //Servo 1
      sc.RegWritePos(ID_6, MiddlePos_6+300, 0, 500); //Servo 2
      sc.RegWritePos(ID_7, MiddlePos_7-300, 0, 500); //Servo 1
      sc.RegWritePos(ID_8, MiddlePos_8+300, 0, 500); //Servo 2
      sc.RegWriteAction();
    case 1:
      Serial.println("All Fingers are closed  ");
      sc.RegWritePos(ID_1, MiddlePos_1+300, 0, 500); //Servo 1
      sc.RegWritePos(ID_2, MiddlePos_2-300, 0, 500); //Servo 2
      sc.RegWritePos(ID_3, MiddlePos_3+300, 0, 500); //Servo 1
      sc.RegWritePos(ID_4, MiddlePos_4-300, 0, 500); //Servo 2
      sc.RegWritePos(ID_5, MiddlePos_5+300, 0, 500); //Servo 1
      sc.RegWritePos(ID_6, MiddlePos_6-300, 0, 500); //Servo 2
      sc.RegWritePos(ID_7, MiddlePos_7+300, 0, 500); //Servo 1
      sc.RegWritePos(ID_8, MiddlePos_8-300, 0, 500); //Servo 2
    case 2:
      Serial.println("Finger1 is open  ");
    case 3:
      Serial.println("Finger1 is closed  ");
    case 4:
      Serial.println("Finger2 is open  ");
    case 5:
      Serial.println("Finger2 is closed  ");
    case 6:
      Serial.println("Finger3 is open  ");
    case 7:
      Serial.println("Finger3 is closed  ");
    case 8:
      Serial.println("Finger4 is open  ");
    case 9:
      Serial.println("Finger4 is closed  ");
    //default:
    //  Serial.println("Please choose a valid selection");
not sure without knowing what SCServo does. does it need to be initialized?
are the IDs the servo pin #s? can you test the servos using the servo library?
looking at the code again, seeing that all the MiddlePos values are the same, all the RegWritePos() values are the identical.
shouldn't they be different values depending on the desired finger position?
Yes, but I'd just add one more comment: the OP should definitely start learning how to use arrays instead of that sequence of variables! It makes the code much more compact, readable, and easily editable.
but arrays won't help without understanding that the correct values are
The servos are controlled by serial bus servo driver board shown at Bus Servo Adapter (A) - Waveshare Wiki. I ran the code shown below and it worked.
SCSCL sc;
int ID_1 = 11;
int ID_2 = 12;
int ID_3 = 13;
int ID_4 = 14;
int ID_5 = 15;
int ID_6 = 16;
int ID_7 = 17;
int ID_8 = 18;
Something may be wrong with the switch(case) loop
why not duplicate that code with different values that gets called after a 2 sec delay: delay (2000);
maybe just start your case at 1, parseInt() returns 0 when it times out..
thinking that’s why they always open again..
good luck.. ~q
and possibly set the Serail monitor to "no line ending"
I had to change the case numbers from 0-9 to 1-10.
What about int inByte = Serial.read(); ?
read() returns the ASCII value of the character it receives. the value of '0' is 48. the value of the linefeed char, '\n' is 10.
you can do which will translate the ASCII values of digits to integer values from 0-9'
yes, probably better to not use parseInt at all..
maybe something like..
int GetInt() {
  static byte buff[10];
  static int inCount = 0;
  int result = -1;
  while (Serial.available()) {
    byte b = Serial.read();
    if (b != 10) {
      if (inCount < sizeof(buff)) {
        if (isdigit(b)) {
          buff[inCount] = b;
          inCount++;
        inCount = 0;
        memset(buff, 0, sizeof(buff));
      if (inCount > 0) {
        result = atoi(buff);
      inCount = 0;
  return result;
good luck.. ~q
Serial.readBytesUntil() does that
void loop ()
    if (Serial.available ())  {
        char buf [90];
        int n   = Serial.readBytesUntil ('\n', buf, sizeof(buf)-1);
        buf [n] = '\0';
        Serial.println (atoi (buf));
void setup ()
    Serial.begin (9600);
shorter..
still see a possible timeout..
either way all good.. ~q
how can there be a timeout if your looking for a specific termination char?
that character never arrives..
hardly unlikely but possible..
~q
Sure, but, as I said, "it makes the code much more compact, readable, and easily editable."
Therefore, any kind of debugging will be easier and faster...
