Hello sir,
Please give me source code for smart phone controlled 2WD robot car
Hello sir,
The idea with this Forum is that YOU write the code and if you run into problems we will try to help.
...R
Go to the Gigs and Collaboration section of the forum if you want your code written for you.
Tom... ![]()
Here you go:
//MOTOR DRIVER Connection
const int motorA1 = 5; // IN1 of MD
const int motorA2 = 6; // IN2 of MD
const int motorB1 = 10; // IN3 of MD
const int motorB2 = 9; // IN4 of MD
//Bluetooth (HC-05) State pin on pin 2 of Arduino
const int BTState = 2;
int i=0;
int j=0;
int state;
int vSpeed=200; // Default speed, from 0 to 255
// Set pins as outputs:
pinMode(motorA1, OUTPUT);
pinMode(motorA2, OUTPUT);
pinMode(motorB1, OUTPUT);
pinMode(motorB2, OUTPUT);
pinMode(BTState, INPUT);
// Initialize serial communication at 9600 bits per second:
//Stop car when connection lost or bluetooth disconnected
if(digitalRead(BTState)==LOW) { state='S'; }
//Save income data to variable 'state'
if(Serial.available() > 0){
state = Serial.read();
//Change speed if state is equal from 0 to 4. Values must be from 0 to 255 (PWM)
if (state == '0'){
vSpeed=0;}
else if (state == '1'){
vSpeed=100;}
else if (state == '2'){
vSpeed=180;}
else if (state == '3'){
vSpeed=200;}
else if (state == '4'){
vSpeed=255;}
/***********************Forward****************************/
//If state is equal with letter 'F', car will go forward!
if (state == 'F') {
analogWrite(motorA1, vSpeed); analogWrite(motorA2, 0);
analogWrite(motorB1, 0); analogWrite(motorB2, vSpeed);
/**********************Forward Left************************/
//If state is equal with letter 'G', car will go forward left
else if (state == 'G') {
analogWrite(motorB1, vSpeed); analogWrite(motorB2, 0);
/**********************Forward Right************************/
//If state is equal with letter 'I', car will go forward right
else if (state == 'I') {
analogWrite(motorA1, 0); analogWrite(motorA2, vSpeed);
/***********************Backward****************************/
//If state is equal with letter 'B', car will go backward
else if (state == 'B') {
/**********************Backward Left************************/
//If state is equal with letter 'H', car will go backward left
else if (state == 'H') {
/**********************Backward Right************************/
//If state is equal with letter 'J', car will go backward right
else if (state == 'J') {
/***************************Left*****************************/
//If state is equal with letter 'L', wheels will turn left
else if (state == 'L') {
analogWrite(motorA1, 200); analogWrite(motorA2, 0);
analogWrite(motorB1, 0); analogWrite(motorB2, 0);
/***************************Right*****************************/
//If state is equal with letter 'R', wheels will turn right
else if (state == 'R') {
analogWrite(motorA1, 0); analogWrite(motorA2, 0);
analogWrite(motorB1, 0); analogWrite(motorB2, 200);
/************************Stop*****************************/
//If state is equal with letter 'S', stop the car
else if (state == 'S'){
