So I am making a code where I have a LED dimmer with 2 buttons. This part I have figured out.
Now what I need help with, is adding a code that detects how long the buttons are pressed.
When the button that turns the brightnes down is pushed for <1 second it won't dim the LED but make it blink by turning off for a short amount of time. So the button will only dim the LED if it's pressed for >1 sec.
The same with the button that turns the brightnes up, but this one will blink with the max brightnes for a short amount of time if the button press is <1sec. Making this dim the brightnes up if the press is >1 sec
Here's my code:
const int brightnessUp = 4;
const int brightnessDown = 2;
const int ledPin = 3;
const int maxBrightness = 12;
int brightness = maxBrightness;
int interval=1;
pinMode(ledPin, OUTPUT);
pinMode(brightnessUp, INPUT);
pinMode(brightnessDown, INPUT);
void loop(){
if (digitalRead(brightnessUp) == HIGH && brightness < maxBrightness){
brightness = brightness + interval;
Serial.println(brightness);
if (digitalRead(brightnessDown) == HIGH && brightness > 0){
brightness = brightness - interval;
delay(100);
analogWrite(ledPin, map(brightness, 0, maxBrightness, 0, 255));
Thanks for any help!
