Hello,
I am sending sensor data (temperature and humidity) from one RFM69HCW to another RFM69HCW. I am a new to automation and have cobbled together code that somewhat works, but the temperature data is sometimes being received as humidity data, and I believe this is a programming error on the receiver end on my part.
Hardware: I’m using an AHT20 temp/humidity sensor connected to an Arduino Uno, connected to an RFM69HCW (Adafruit version). This RFM69HCW transmits a signal to an identical RFM69HCW which is connected to an ESP32 which then sends the data to the IOT website ‘Blynk’.
Issue: The temperature data is sometimes (not always) received as the humidity data. I am sending the temperature as a float with 4 bytes, and the humidity as an integer with 2 bytes. This is how I am separating them on the receiving end as temperature or humidity, based on how many bytes they are. I know in Arduino Uno an ‘int’ is 2 bytes, and in the ESP32 it is 4 bytes, but I believe it is still incoming as 2 bytes? - the program seems to label them as 2 and 4 bytes in the Serial Monitor.
This originally seemed the simplest way to send two different variables and separate them -per my novice experience. Any help is appreciated.
Tx Serial Monitor:
GH Temperature and Humidity
⸮⸮⸮⸮⸮Ʌ⸮⸮ɕ⸮and Humidity found
Feather RFM69 TX Test!
RFM69 radio init OK!
RFM69 radio @915 MHz
Temperature: 75.18 degrees F
Humidity: 50.13% rH
Sending Temp: 75.18 Sending Humidity: 50 Temperature: 75.28 degrees F
Humidity: 50.40% rH
Sending Temp: 75.28 Sending Humidity: 50 Temperature: 75.39 degrees F
Humidity: 50.69% rH
Sending Temp: 75.39 Sending Humidity: 51 Temperature: 75.51 degrees F
Humidity: 50.33% rH
Rx Serial Monitor:
Note: It seems like the temp is getting converted to 2 byte, getting into the past the ‘if (len ==2) statement, and then converted back to a float.
As you can see below, sometimes the real humidity (where it says 32 on Serial Monitor) does make it through. Before I added delays it used to say the correct humidity much more often, but every 4 or so entries it would still post the temp as the humidity.
Feather RFM69 RX Test!
.WiFi connected
test1 Receive failed
Test4 test1 Receive failed
Test4 test1 test2 test3 Received Temp [4]: 76.15
RSSI: -31
Test4 test1 test2 test3 Received humidity [2]: 76.00
RSSI: -31
Test4 test1 test2 test3 Received Temp [4]: 76.14
RSSI: -32
RSSI: -31
Test4 test1 test2 test3 Received humidity [2]: 32.00
RSSI: -31
Test4 test1 test2 test3 Received Temp [4]: 76.13
RSSI: -30
RSSI: -30
Test4 test1 test2 test3 Received Temp [4]: 76.11
RSSI: -30
Rx Serial Monitor w/ line : short transData2 = *((float *)buf);
Line in rx code replaces 'float transData2 = *((float *)buf);', converts transData2 to 2 byte integer.
.WiFi connected
Test4 test1 test2 test3 Received humidity [2]: 0
RSSI: -44
Test4 test1 test2 test3 Received Temp [4]: 75.04
RSSI: -37
Test4 test1 test2 test3 Received humidity [2]: 75
RSSI: -39
Test4 test1 test2 test3 Received Temp [4]: 75.03
RSSI: -39
RSSI: -35
RSSI: -38
Test4 test1 test2 test3 Received Temp [4]: 74.96
RSSI: -38
Test4 test1 test2 test3 Received humidity [2]: 74
RSSI: -38
Test4 test1 test2 test3 Received Temp [4]: 74.94
RSSI: -35
TX Code:
// rf69 demo tx rx.pde
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messageing client
// with the RH_RF69 class. RH_RF69 class does not provide for addressing or
// reliability, so you should only use RH_RF69 if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example rf69_server.
// Demonstrates the use of AES encryption, setting the frequency and modem
// configuration
//Uses RADIOHEAD library and code
#include <SPI.h>
#include <RH_RF69.h>
//Sensor setup
#include <Adafruit_AHTX0.h>
Adafruit_AHTX0 aht;
int i = 0;
/************ Radio Setup ***************/
// Change to 434.0 or other frequency, must match RX's freq!
#define RF69_FREQ 915.0
//#if defined (Arduino Uno) //Arduino Uno input by Calder
#define RFM69_CS 4
#define RFM69_INT 3
#define RFM69_RST 2
#define LED 13
//#endif
// Singleton instance of the radio driver
RH_RF69 rf69(RFM69_CS, RFM69_INT);
int16_t packetnum = 0; // packet counter, we increment per xmission
//Sensor Setup
// pinMode(9, OUTPUT); //pins for LED and Noise Buzzer
//pinMode(8, OUTPUT);
Serial.begin(9600); // baude rate
Serial.println("GH Temperature and Humidity");
if (! aht.begin()) {
Serial.println("Could not find AHT? Check wiring");
while (1) delay(10);
Serial.println("GH Temperature and Humidity found");
//Radio setup
//while (!Serial) { delay(1); } // wait until serial console is open, remove if not tethered to computer
pinMode(LED, OUTPUT);
pinMode(RFM69_RST, OUTPUT);
digitalWrite(RFM69_RST, LOW);
Serial.println("Feather RFM69 TX Test!");
// manual reset
digitalWrite(RFM69_RST, HIGH);
delay(10);
delay(10);
if (!rf69.init())
Serial.println("RFM69 radio init failed");
while (1);
Serial.println("RFM69 radio init OK!");
// Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)
// No encryption
if (!rf69.setFrequency(RF69_FREQ))
Serial.println("setFrequency failed");
// If you are using a high power RF69 eg RFM69HW, you *must* set a Tx power with the
// ishighpowermodule flag set like this:
rf69.setTxPower(20, true); // range from 14-20 for power, 2nd arg must be true for 69HCW
//If RSSI on receiver is low, can lower the power to save energy
// The encryption key has to be the same as the one in the server
uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
rf69.setEncryptionKey(key);
Serial.print("RFM69 radio @"); Serial.print((int)RF69_FREQ); Serial.println(" MHz");
//Sensor
sensors_event_t humidity, temp;
aht.getEvent(&humidity, &temp);// populate temp and humidity objects with fresh data
float t = temp.temperature * (9.0 / 5) + 32; //converting Celsius to Farenheit
float h = humidity.relative_humidity;
//Serial.print("Temperature: "); Serial.print(temp.temperature); Serial.println(" degrees C");
Serial.print("Temperature: "); Serial.print(t); Serial.println(" degrees F");
Serial.print("Humidity: "); Serial.print(humidity.relative_humidity); Serial.println("% rH");
delay(2000);
//Radio
delay(2000); // Wait 1 second between transmits, could also 'sleep' here!
String tempString = String(t); //converting temp float to string for radio transmission
//char radiopacket[20] = "Hoop temp: " + tempString; //radiopacket[20] means there are 20 characters available in the transmission
char radiopacket[30] = "tempString"; //Char is character, has to have quotations
itoa(packetnum++, radiopacket+13, 10);
Serial.print("Sending first ");
Serial.println(radiopacket);
//Temp
float val = t; // a variable
float* pVal = &val; // a pointer to the variable
float anotherVal = *pVal; // dereference the pointer to the first variable, and assign the value to a new variable. "anotherVal" now has the value 't'
//*pVal = 2.718; // "val" now has the value 2.718, but "anotherVal" still has the value 3.1412
//Humidity
float val2 = h; // a variable
float* pVal2 = &val2; // a pointer to the variable
float anotherVal2 = *pVal2; // dereference the pointer to the first variable, and assign the value to a new variable. "anotherVal" now has the value 't'
int int2 = round(anotherVal2);
////Serial.print(int2); //display rounded temperature
////Serial.print(" rounded ");
// Send a message!
//rf69.send((uint8_t *)radiopacket, strlen(radiopacket)); //uint8_t is a byte type
//////////rf69.send((uint8_t *)(&anotherVal, &int2), sizeof(anotherVal + int2));
rf69.send((uint8_t *)(&anotherVal), sizeof(anotherVal)); //sending temp, sizeof is bytes
Serial.print("Sending Temp: ");
Serial.print(anotherVal);
Serial.print(" ");
rf69.waitPacketSent(); //waits for previous transmission to finish -CB
delay (8000);
//When have two sends, becomes 0.00 on other end, maybe b/c of buffering or something?
rf69.send((uint8_t *)(&int2), sizeof(int2)); //sending humidity
Serial.print("Sending Humidity: ");
Serial.print(int2);
Serial.print(" ");
delay(2000);
RX Code:
// configuration
#define BLYNK_TEMPLATE_ID "TMPLKcy5ZwCr"
#define BLYNK_DEVICE_NAME "ESP32"
#define BLYNK_AUTH_TOKEN "2CqomTcy2HZE3ML9HgPRn4B_mQqzdDtv"
#define DataDisplay // Disable to display raw data received & errors of data length (added from other code)
#include <SPI.h>
///////#include "RFM69X.h" //added from https://homeautomation.proboards.com/thread/600/wifi-rfm69-mqtt-network?page=1&scrollTo=4466
////////////SPIClass SPI1(VSPI); //from forum
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_AHTX0.h> //for alarm
int i = 0; //for alarm
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "2CqomTcy2HZE3ML9HgPRn4B_mQqzdDtv";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "Prince";
char pass[] = "Pr1nc3H0us3!";
//LCD SETUP
// include the library code:
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 34, en = 35, d4 = 26, d5 = 27, d6 = 14, d7 = 12;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
//#define FREQUENCY RF69_915MHZ
#define RFM69_CS 5
#define RFM69_INT 15 //when switched to 13 got errors
#define RFM69_RST 2
#define LED 33 //when switched to 33 it fixed everything (was 18, earlier 12)
// commenting out b/c causing esptool errors
//pinMode(22, OUTPUT); //pin for LED (working) (22 works) (17, 21 does not work)
pinMode(22, OUTPUT); //pin for noise maker pin (can't be 21,17
//LCD Setup
// set up the LCD's number of columns and rows:
////////////////////lcd.begin(16, 2);
//Serial.begin(115200);
Serial.println("Feather RFM69 RX Test!");
// manual reset
delay(10);
delay(10);
if (!rf69.init())
while (1);
// No encryption
if (!rf69.setFrequency(RF69_FREQ)) {
//Wifi code copy pasted
WiFi.begin(ssid, pass);
int wifi_ctr = 0;
Serial.print(".");
Serial.println("WiFi connected");
Blynk.begin(auth, ssid, pass);
//Alarm
Serial.print ("test1 ");
delay(10);
//noTone(32); //no noise for buzzer if temp normal (removed b/c was resetting to void setup(), originally added b/c was not buzzer was not shutting off after loop
if (rf69.available())
// Should be a message for us now
Serial.print ("test2 ");
uint8_t buf[RH_RF69_MAX_MESSAGE_LEN]; //Creates array using buf of the amount of units there are in the string
//////////float receivedData[2] = {0}; //added new
//////////uint8_t buflen = sizeof(receivedData); //added new
uint8_t len = sizeof(buf); //len = length of string (or # of bytes of variable)
if (rf69.recv(buf, &len))
Serial.print ("test3 ");
//////float hhtemp = *((float *)buf);
//////float hhhumid = *((float *)buf);
///////// float transData = *((float *)buf); //data can be temp(4 length) or humidity(2 length)
if (len == 4) { //if length is 3 or more (for temp) then:
if (!len) return;
float transData1 = *((float *)buf);
buf[len] = 0; // zero out remaining string, if don't may get a lot of weird symbols afterward
Serial.print("Received Temp [");
Serial.print(len); //length of message received
Serial.print("]: ");
Serial.println(transData1);
Serial.print("RSSI: "); //RSSI is like the signal strength
Serial.println(rf69.lastRssi(), DEC);
Serial.print(" ");
//Send temp data to Blynk website
Blynk.run();
float val = transData1;
Blynk.virtualWrite(V0, val);
//Buzzer Temp Alarm Siren
if (transData1 > 75) //If temp above 75 F, then buzzer siren goes off
for (i = 700; i < 800; i++)
tone(22, i); //buzzer pin
//digitalWrite(0, HIGH); //LED pin(change to esp32 pin for buzzer)
delay(15);
for (i = 800; i > 700; i--)
//digitalWrite(0, LOW); //LED pin (change to esp32 pin for buzzer)
delay(15);
delay(4000);
//Print temp to LCD screen
lcd.setCursor(0, 0); //set cursor to top of scrreen
lcd.print("Your HH is ");
lcd.setCursor(0, 1); //set cursor to bottom of screen
lcd.print(hhtemp); //printing temp
lcd.print(" F ");
//if (len == 2){ //just one '=' puts value of 2 into len
else if (len == 2) //just one '=' puts value of 2 into len
if (!len) return;
buf[len] = 0;
Serial.print("Received humidity [");
Serial.println(transData2);
Serial.print(" ");
//Send humidity data to Blynk website
Blynk.run();
float val2 = transData2;
Blynk.virtualWrite(V1, val2);
//////////// int hhhumid = *((int *)buf);
///////////// Serial.print(hhhumid);
///////////////lcd.print(hhhumid);
////////////////lcd.print("% RH");
delay(4000);
Serial.println("Receive failed");
// set radio to use less power
// it will wake up the next time send() or sendWithRetry() is called
//rf69.sleep(); ///removing to test if doens't work on ESP32 (tried and made it so wouldn't receive anything)
Serial.print ("Test4 ");
Setup Diagram for the ESP32:
(ignore LED, and buzzer is now connected to gpio pin 22, not 32).
ESP32 Pin Diagram:
