I bought a coin acceptor from ebay, KAI-638C and Im trying to make it work. I found a code at Instructables but somehow it doesn't count right. When I insert a coin the arduino registers 1-3coins instead of just the one inserted coin. So I guess it's gotta do something about the signals from the acceptor. I have no oscilloscope to see what kind of signal it outputs. I've tried to experiment with different delays(I know delays are not recommended in interrupts. but hey, Im desperate) but no luck so far.
The acceptor and the arduino share the same ground.
Maybe you guys have any thoughts or suggestions I could try because I'm all out of ideas?
const int coinInt = 0;
//Attach coinInt to Interrupt Pin 0 (Digital Pin 2). Pin 3 = Interrpt Pin 1.
volatile float coinsValue = 0.00;
//Set the coinsValue to a Volatile float
//Volatile as this variable changes any time the Interrupt is triggered
int coinsChange = 0;
//A Coin has been inserted flag
//Start Serial Communication
attachInterrupt(coinInt, coinInserted, RISING);
//If coinInt goes HIGH (a Pulse), call the coinInserted function
//An attachInterrupt will always trigger, even if your using delays
void coinInserted()
//The function that is called every time it recieves a pulse
coinsValue = coinsValue + 0.05;
//As we set the Pulse to represent 5p or 5c we add this to the coinsValue
coinsChange = 1;
//Flag that there has been a coin inserted
if(coinsChange == 1)
//Check if a coin has been Inserted
coinsChange = 0;
//unflag that a coin has been inserted
Serial.print("Credit: £");
Serial.println(coinsValue);
//Print the Value of coins inserted
allanhurst:
There are adjustments on this device for sensitivity - have you tried them?
regards
Allan.
Yes, but I believe that only adjusts the sensitivity for the acceptor and has nothing to do with the signal output?
What really bothers me is that the arduino interprets the signal different every time. If it always would count one coin as three or two coins it wouldn't be a problem. But now its hard to count the coins accurately.
For something like this, I don't think that an interrupt is necessary. If there are really multiple pulses per coin for whatever reason, by changing to polling you could use a 'millis()'-based delay for debounce, so that after a coin is detected, your code doesn't look for another coin until that delay period has elapsed. It only needs to be slightly less than the time between multiple coins that are inserted very quickly. Something in the neighbourhood of 50ms to 100ms.
You could also use an interrupt and do similar, but I don't see a need, as long as your 'loop()' is reasonably fast, without blocking delays.
Then set the coin mechanism's pulse length to the minimum pulse length, (30mS).
3 triggering TIMER SWITCH of Pulse Duration ,
Long : 100 ms
Default : 50 ms
Short : 30 ms
Edit: And don't use 'delay()' in interrupt service routines. It won't work.
From the 'attachInterrupt()' reference:-
Inside the attached function, delay() won't work and the value returned by millis() will not increment.
