After I updated IDE to 2.3.4, I get the error to compile my project.
Then, I delete 2.3.4 since I'm using ZIP version and back to 2.3.3.
I encountered same error.
So, I deleted all local setting in my Windows user folder including hidden folder and
delete IDE 2.3.3 and back to 2.3.4.
Also, I tried to compile "Blink" example instead.
So far, I found, (To compile "Blink" example now)
With Arduino Uno, Arduino Nano, I can compile with no problem.
With Arduino Nano Every, Arduino Uno R4 Minima, I encounter the error.
Since I need to use R4 Minima now, I have to solve the problem.
I tried to use previous versions of "Arduino AVR boards" or "Arduino megaAVR boards" or "Arduino Uno R4 Boards", but it doesn't help.
Now I'm completely stacked.
Is there any other idea?
Did you also clear the cache?
- IDE 2.3.4 :
C:\Users\bugge\AppData\Local\arduino - IDE 2.3.3 :
C:\Users\bugge\AppData\Local\Temp\arduino.
Yes, I deleted them also.
Hi @TNakamura. I'm going to ask you to provide the full verbose output from a compilation.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
- Open the Blink sketch in Arduino IDE.
- Select the UNO R4 Minima board from the Arduino IDE menu.
- Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open. - Check the box next to "Show verbose output during: ☐ compile" in the "Preferences" dialog.
- Click the "OK" button.
The "Preferences" dialog will close. - Select Sketch > Verify/Compile from the Arduino IDE menus.
- Wait for the compilation to fail.
- You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
- Open a forum reply here by clicking the "Reply" button.
- Click the
<CODE/>icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
- Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
This will paste the compilation output into the code block. - Move the cursor outside of the code block markup before you add any additional text to your reply.
- Click the "Reply" button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
Click here for attachment instructions
- Open any text editor program.
- Paste the copied output into the text editor.
- Save the file in
.txtformat. - Open a forum reply here by clicking the "Reply" button.
- Click the "Upload" icon (
) on the post composer toolbar:
The "Open" dialog will open. - Select the
.txtfile you saved from the "Open" dialog. - Click the "Open" button.
The dialog will close. - Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
Here it is. (There's some sentence in Japanese, but let me leave it as it is, since I think it should not be a matter.)
FQBN: arduino:renesas_uno:minima
Using board 'minima' from platform in folder: C:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2
Using core 'arduino' from platform in folder: C:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2
Detecting libraries used...
C:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DARDUINO_UNOR4_MINIMA -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\TNakamura\AppData\Local\arduino\sketches\FC740CF5A752C048DC2523C9570FF7C7/sketch_dec25a.ino" -DARDUINO_MINIMA -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\variants\MINIMA/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/tinyusb -IC:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/deprecated -IC:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/deprecated-avr-comp -IC:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino -IC:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\variants\MINIMA -iprefixC:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2 @C:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\variants\MINIMA/includes.txt C:\Users\TNakamura\AppData\Local\arduino\sketches\FC740CF5A752C048DC2523C9570FF7C7\sketch\sketch_dec25a.ino.cpp -o nul
Generating function prototypes...
C:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DARDUINO_UNOR4_MINIMA -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\TNakamura\AppData\Local\arduino\sketches\FC740CF5A752C048DC2523C9570FF7C7/sketch_dec25a.ino" -DARDUINO_MINIMA -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\variants\MINIMA/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/tinyusb -IC:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/deprecated -IC:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/deprecated-avr-comp -IC:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino -IC:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\variants\MINIMA -iprefixC:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2 @C:\Users\TNakamura\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\variants\MINIMA/includes.txt C:\Users\TNakamura\AppData\Local\arduino\sketches\FC740CF5A752C048DC2523C9570FF7C7\sketch\sketch_dec25a.ino.cpp -o C:\Users\TNakamura\AppData\Local\Temp\3008174454\sketch_merged.cpp
C:\Users\TNakamura\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\TNakamura\AppData\Local\Temp\3008174454\sketch_merged.cpp
スケッチをコンパイルしています...
"C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DARDUINO_UNOR4_MINIMA -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7/sketch_dec25a.ino\"" -DARDUINO_MINIMA -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/tinyusb" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/api/deprecated" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA" "-iprefixC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2" "@C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA/includes.txt" "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7\\sketch\\sketch_dec25a.ino.cpp" -o "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7\\sketch\\sketch_dec25a.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DARDUINO_UNOR4_MINIMA -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7/sketch_dec25a.ino\"" -DARDUINO_MINIMA -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/tinyusb" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/api/deprecated" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA" "-iprefixC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2" "@C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA/includes.txt" "C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA\\variant.cpp" -o "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7\\core\\variant.cpp.o"
"C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -c -w -Os -g3 -nostdlib -DF_CPU=48000000 -DARDUINO_UNOR4_MINIMA -MMD -std=gnu11 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 -DARDUINO_MINIMA -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/tinyusb" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/api/deprecated" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA" "-iprefixC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2" "@C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA/includes.txt" -o "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7\\core\\tmp_gen_c_files\\pin_data.c.o" "C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA\\tmp_gen_c_files\\pin_data.c"
"C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -c -w -Os -g3 -nostdlib -DF_CPU=48000000 -DARDUINO_UNOR4_MINIMA -MMD -std=gnu11 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 -DARDUINO_MINIMA -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/tinyusb" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/api/deprecated" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA" "-iprefixC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2" "@C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA/includes.txt" -o "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7\\core\\tmp_gen_c_files\\common_data.c.o" "C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA\\tmp_gen_c_files\\common_data.c"
"C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -c -w -Os -g3 -nostdlib -DF_CPU=48000000 -DARDUINO_UNOR4_MINIMA -MMD -std=gnu11 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 -DARDUINO_MINIMA -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/tinyusb" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/api/deprecated" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\cores\\arduino" "-IC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA" "-iprefixC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2" "@C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA/includes.txt" -o "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7\\core\\tmp_gen_c_files\\main.c.o" "C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA\\tmp_gen_c_files\\main.c"
Using precompiled core: C:\Users\TNakamura\AppData\Local\arduino\cores\arduino_renesas_uno_minima_2b7169679b73c6439d2128d1044148f6\core.a
Linking everything together...
"C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -Wl,--gc-sections --specs=nosys.specs -w -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -o "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7/sketch_dec25a.ino.elf" "-LC:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7" "-LC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA" "-TC:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA/fsp.ld" "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7\\sketch\\sketch_dec25a.ino.cpp.o" "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7\\core\\tmp_gen_c_files\\common_data.c.o" "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7\\core\\tmp_gen_c_files\\main.c.o" "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7\\core\\tmp_gen_c_files\\pin_data.c.o" "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7\\core\\variant.cpp.o" -Wl,--whole-archive -Wl,--start-group "C:\\Users\\TNakamura\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.2\\variants\\MINIMA/libs/libfsp.a" "C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7/..\\..\\cores\\arduino_renesas_uno_minima_2b7169679b73c6439d2128d1044148f6\\core.a" -Wl,--no-whole-archive --specs=nano.specs -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group "-Wl,-Map,C:\\Users\\TNakamura\\AppData\\Local\\arduino\\sketches\\FC740CF5A752C048DC2523C9570FF7C7/sketch_dec25a.ino.map"
collect2.exe: error: ld returned 5 exit status
exit status 1
Compilation error: exit status 1
