I'm a beginner in electronics and I ask me is it possible with the Arduino UNO R3 to combine WiFi and Ultraschall - HC-SR04 module.
The idea behind this is, to send me a signal over wifi, when the HC-SR04 have something. Additional question is the power settings: is it possible to turn on the sensor every 30 sec to save power?
Theoretically: yes. It depends on what hardware you're planning to use for the WiFi functionality but usually it should work.
Yes, but it doesn't make sense as the UNO it using to much power itself to keep it running on batteries for a longer time period. Use a slighter board like the Pro Mini or in your case (as you plan to use WiFi) an ESP8266 based board without an Arduino (you can still use the Arduino IDE to program it).
