combine two codes GSM and BBLUETOOTH Module HELP
#define REMOTEXY_MODE__HARDSERIAL
#include <RemoteXY.h>
#define REMOTEXY_SERIAL Serial
#define REMOTEXY_SERIAL_SPEED 9600
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
{ 255, 1, 0, 0, 0, 20, 0, 8, 13, 0,
2, 0, 25, 19, 53, 22, 2, 26, 31, 31,
79, 78, 0, 79, 70, 70, 0
struct {
uint8_t switch_1;
uint8_t connect_flag;
} RemoteXY;
#pragma pack(pop)
#define PIN_SWITCH_1 13
RemoteXY_Init ();
pinMode (PIN_SWITCH_1, OUTPUT);
RemoteXY_Handler ();
digitalWrite(PIN_SWITCH_1, (RemoteXY.switch_1 == 0) ? LOW : HIGH);
#include <SoftwareSerial.h>
SoftwareSerial SIM900(7, 8);
String incomingData;
String message = "";
int relay_pin = 2;
SIM900.begin(19200);
pinMode(relay_pin, OUTPUT);
digitalWrite(relay_pin, HIGH);
SIM900.print("AT+CMGF=1\r");
delay(100);
SIM900.print("AT+CNMI=2,2,0,0,0\r");
delay(100);
receive_message();
if (incomingData.indexOf("off") >= 0)
digitalWrite(relay_pin, LOW);
message = "Motor is turned off";
send_message(message);
if (incomingData.indexOf("on") >= 0)
message = "Motor is turned on";
off
void receive_message()
if (SIM900.available() > 0)
incomingData = SIM900.readString();
Serial.print(incomingData);
delay(10);
void send_message(String message)
SIM900.println("AT+CMGF=1");
delay(100);
SIM900.println("AT+CMGS="+639355830460"");
delay(100);
SIM900.println(message);
delay(100);
SIM900.println((char)26);
delay(100);
SIM900.println();
The cented text
has to be the
worst way in, like, ever
to display
a
sketch.
Rather use tags:
[code] sketch goes here [/code]
You have piss-poorly posted code A that does something. You have piss-poorly posted code B that does something. You have some completely unspecified requirements for a new program.
You can't realistically expect anyone to tell you how to write the new program.
karma++ for inventive posting though
Does this help?
  setupA();
  setupB();
  loopA();
  loopB();
struct
  uint8_t switch_1;
} RemoteXY;
#pragma pack(pop)
void setupA()
  RemoteXY_Init ();
void loopA()
int relay_pin = 2;
void setupB()
  delay(100);
  delay(100);
void loopB()
  receive_message();
    delay(10);
  delay(100);
  SIM900.println("AT+CMGS=\"+639355830460\"");
  delay(100);
  delay(100);
  delay(100);
  SIM900.println();
