So i'm running into a little problem here.
I've to connect the potentiometer with the button and a led.
The Led turns on when pressing the button, and the LED should turn of when the potentiometer is at percentage 50.
What happens for me, is that it does work but only when I press the button again.
const int BUTTONLEFT = 9;
const int YELLOWLED = 7;
const int POTPIN = A0;
int LastButtonLeft = HIGH;
int val = 0;
pinMode(BUTTONLEFT, INPUT_PULLUP);
pinMode (POTPIN, INPUT_PULLUP);
pinMode(YELLOWLED, OUTPUT);
int val = analogRead(POTPIN);
float percentage = map(val, 0, 1023, 0, 100);
int ButtonLeftState;
ButtonLeftState = digitalRead(BUTTONLEFT);
if (ButtonLeftState != LastButtonLeft) { // debounce the input button
delay(50);
if (ButtonLeftState == LOW) {
digitalWrite (YELLOWLED, HIGH);
if (percentage <= 50) {
} else if (percentage >= 50) {
digitalWrite (YELLOWLED, LOW);
LastButtonLeft = ButtonLeftState;
The map() function returns an integer. Having a float is useless.
You don't need this line. INPUT_PULLUP does not make sense for an analog.
You should not read the button again after you determine it has changed.
delay(50);
ButtonLeftState = digitalRead(BUTTONLEFT); // *** remove this line ***
This conditional is ambiguous. You should remove the '=' from one of the conditions:
Sadly, it still makes me run into the same problem...
So post your latest code. There's no point us trying to guess what you might have changed.
Steve
It is working just like you programmed it. You are only checking the potentiometer when the button is pressed so the LED will only change when the button is pressed.
Do you want the LED to turn on when the button is pressed? Do you want the LED to turn off when the percentage is greater than 50 or less than 50?
So,
The led needs to turn on when the button is pressed, no matter the state of the potpin.
When the led is on, the potpin should turn it off again when it is greater then 50
Just move the analog check outside of the button check.
int val = 0;
pinMode(POTPIN, INPUT);
int percentage = map(val, 0, 1023, 0, 100);
if (percentage >= 50 && digitalRead(YELLOWLED) == HIGH) {
Serial.println("LED off");
Serial.println("LED on");
delay(50);
