I need help combining multiple codes
Codes:
modified on Sep 28, 2020
Modified by MohammedDamirchi from Arduino Examples
Home
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// print out the value you read:
Serial.println(sensorValue);
delay(20);
#include <LiquidCrystal.h>
int sensorValue;
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
void setup(){ lcd.begin(16, 2);
Serial.begin(9600); // sets the serial port to 9600
void loop(){sensorValue = analogRead(0); // read analog input pin 0
Serial.print("AirQua=");
Serial.print(sensorValue, DEC); // prints the value read
Serial.println(" PPM");
lcd.setCursor(0,0);
lcd.print("ArQ=");
lcd.print(sensorValue,DEC);
lcd.print(" PPM");
lcd.println(" ");
lcd.print(" ");
delay(100); // wait 100ms for next reading
#include <dht11.h>
#define DHT11PIN 4
dht11 DHT11;
int chk = DHT11.read(DHT11PIN);
Serial.print("Humidity (%): ");
Serial.println((float)DHT11.humidity, 2);
Serial.print("Temperature (C): ");
Serial.println((float)DHT11.temperature, 2);
delay(2000);
Home
delay(20);
Home
delay(20);
- #include <Wire.h>
#include <AHT10.h> //See the library download
link below!
AHT10Class AHT10;
Wire.begin();
if
(AHT10.begin(eAHT10Address_Low))
Serial.println("Init AHT10 Success!");
Serial.println("Init AHT10 Failed!");
Serial.println("//Arduino & AHT10//");
Serial.println("Quick Test – Serial Monitor");
Serial.println(String("") + "Humidity(%RH):\t\t" +
AHT10.GetHumidity() + "%");
Serial.println(String("") + "Temperature(℃):\t"
- AHT10.GetTemperature() + "℃");
Serial.println(String("") + "Dewpoint(℃):\t\t"
AHT10.GetDewPoint() + "℃");
#include <SoftwareSerial.h>
SoftwareSerial pmsSerial(2, 3);
// our debugging output
// sensor baud rate is 9600
pmsSerial.begin(9600);
struct pms5003data {
uint16_t framelen;
uint16_t pm10_standard, pm25_standard, pm100_standard;
uint16_t pm10_env, pm25_env, pm100_env;
uint16_t particles_03um, particles_05um, particles_10um, particles_25um, particles_50um, particles_100um;
uint16_t unused;
uint16_t checksum;
struct pms5003data data;
if (readPMSdata(&pmsSerial)) {
// reading data was successful!
Serial.println("---------------------------------------");
Serial.println("Concentration Units (standard)");
Serial.print("PM 1.0: "); Serial.print(data.pm10_standard);
Serial.print("\t\tPM 2.5: "); Serial.print(data.pm25_standard);
Serial.print("\t\tPM 10: "); Serial.println(data.pm100_standard);
Serial.println("Concentration Units (environmental)");
Serial.print("PM 1.0: "); Serial.print(data.pm10_env);
Serial.print("\t\tPM 2.5: "); Serial.print(data.pm25_env);
Serial.print("\t\tPM 10: "); Serial.println(data.pm100_env);
Serial.print("Particles > 0.3um / 0.1L air:"); Serial.println(data.particles_03um);
Serial.print("Particles > 0.5um / 0.1L air:"); Serial.println(data.particles_05um);
Serial.print("Particles > 1.0um / 0.1L air:"); Serial.println(data.particles_10um);
Serial.print("Particles > 2.5um / 0.1L air:"); Serial.println(data.particles_25um);
Serial.print("Particles > 5.0um / 0.1L air:"); Serial.println(data.particles_50um);
Serial.print("Particles > 10.0 um / 0.1L air:"); Serial.println(data.particles_100um);
boolean readPMSdata(Stream *s) {
if (! s->available()) {
return false;
// Read a byte at a time until we get to the special '0x42' start-byte
if (s->peek() != 0x42) {
s->read();
return false;
// Now read all 32 bytes
if (s->available() < 32) {
return false;
uint8_t buffer[32];
uint16_t sum = 0;
s->readBytes(buffer, 32);
// get checksum ready
for (uint8_t i=0; i<30; i++) {
sum += buffer[i];
/* debugging
for (uint8_t i=2; i<32; i++) {
Serial.print("0x"); Serial.print(buffer[i], HEX); Serial.print(", ");
// The data comes in endian'd, this solves it so it works on all platforms
uint16_t buffer_u16[15];
for (uint8_t i=0; i<15; i++) {
buffer_u16[i] = buffer[2 + i2 + 1];
buffer_u16[i] += (buffer[2 + i2] << 8);
// put it into a nice struct ![]()
memcpy((void *)&data, (void *)buffer_u16, 30);
if (sum != data.checksum) {
Serial.println("Checksum failure");
return false;
// success!
return true;
const int pinPM25 = 7;
const int pinPM1 = 8;
const unsigned long sampleTime = 5000; // mSec -> 5..30 sec
float calc_low_ratio(float lowPulse) {
return lowPulse / sampleTime * 100.0; // low ratio in %
float calc_c_mgm3(float lowPulse) {
float r = calc_low_ratio(lowPulse);
float c_mgm3 = 0.00258425 * pow(r, 2) + 0.0858521 * r - 0.01345549;
return max(0, c_mgm3);
float calc_c_pcs283ml(float lowPulse) {
float c_pcs283ml = 625 * r;
return min(c_pcs283ml, 12500);
pinMode(pinPM25, INPUT);
pinMode(pinPM1, INPUT);
Serial.println("Warming up...");
// delay(60000); // 1 minute warm-up
static unsigned long t_start = millis();
static float lowPM = 0;
lowPM += pulseIn(pinPM25, LOW) / 1000.0; // >2.5µm (PM2.5)
//lowPM += pulseIn(pinPM1, LOW) / 1000.0; // >1µm (PM1)
if ((millis() - t_start) >= sampleTime) {
Serial.print("low_% PM : ");
Serial.println(calc_low_ratio(lowPM));
Serial.print("c_mgm3 PM : ");
Serial.println(calc_c_mgm3(lowPM));
Serial.print("c_pcs283ml PM: ");
Serial.println(calc_c_pcs283ml(lowPM));
lowPM = 0;
t_start = millis();
Please help
