Hello
basically i'm trying to convert two chars received from an XBee.
so i have char[0] and char[1]
say this gives me 2 and 3.
I need to combine them into an int which makes 23.
any suggestions?
Thanks in advance
Hello
any suggestions?
Thanks in advance
Assuming that your char array holds the ASCII values of the 2 digits :
int theInt = ( 10 * (char[0] - '0' ) ) + char[1] - '0';
You could use:
int number = 10*(char[0] - '0') + char[1] - '0';
(given that char[0] == '2', and not 2 (uint8_t))
Or if the array is null-terminated (i.e. char[2] == '\0'):
int number = atoi(char);
Pieter
Thanks for the reply's!
code is working now
