Coming from C#, How would u do an infinite loop?
Hello, i want to send some keys to my computer as a infinite loop, its for work purpose
lets say key "1"
i have arduino mini micro, i have c# background, i just need some tips
i have a button, i want to turn on and off the loop with this button, how my code should start or atleast where i should start
in c# its pretty easy, but this is all new to me. any help is welcome, thanks.
#define EVER ;;
for (EVER) {
  // Your infinite loop is right here
have a read thru Arduino buttons
As a matter of interest how would you do it in C# ?
UKHeliBob:
using while, and using a variable to turn if on and off
While(1) {
// Infinite loop here
That works even if you don't come from c#
while(1) {
[Edit]
TheMemberFormerlyKnownAsAWOL:
It works if you spell it "while"
++Karma; // AWOL! Thank you for spotting my silly mistake :slight_smile:
PerryBebbington:
While(1) {
kokih:
Please post an actual example
The C# compiler will transform both
while (true) {
and
for(;;) {
into
  :label
  goto label;
(as far as I remember)
Not far from C/C++
here is an example which loops
  1. waits for switch 1 to be pressed
  2. display message
  3. waits for switch 2 to be pressed
  4. displays message
    while(digitalRead(sw1Pin));
    Serial.println("Sw1 pressed ");
    while(digitalRead(sw2Pin));
    Serial.println("Sw2 pressed ");
The Arduino system already has an infinite loop as standard. It is the loop() function.
...R
I'd make the empty loop much more obvious visually here:
// is clearer like this:
Its wise to make all the structure and indentation clear and visually consistent in code, you
may have to read it again some day! In this case a semicolon at the end of an if or a while
can cause huge confusion (witness many threads here!), so its best to always avoid doing it.
an alternative could be
    while(digitalRead(sw1Pin)) __asm__("nop");
Contributors to this Thread might like to reflect on the number of times that it has to be explained to newbies NOT to use blocking code such as WHILE, FOR and delay()
...R
Robin2:
sure but that's not the question being asked :slight_smile:
And actually re-reading the ask, it's not an infinite loop that OP wants, it's really pseudo code like
while (button is pressed)
  send '1'
ideally we would let the loop spin and thus it would be
 if (button is pressed) send '1'
which would be non blocking
J-M-L:
Exactly my point.
...R
something along the lines of
// blink LED when switch pressed
    if(!digitalRead(sw1Pin)) {
       digitalWrite(LED1, !digitalRead(LED1));
which inverts the LED when the switch is pressed
horace:
that's blocking the loop for half a second (forever in µc time) !
a non-blocking version?
    static unsigned long int time = millis();
    if(!digitalRead(sw1Pin) && (millis()-time > 500)) {
       time = millis();
horace:
      time = millis();
Noooo....
You are setting time to millis() every time around loop, millis()-time will never be greater than 500.
Also, I suggest it is good practice to take this out of loop and put into it's own function instead off cluttering loop up with lots of code, which just gets confusing.
[Edit]
Ignore this!!! See posts below :slight_smile:
