I use macOS Sonoma 14.1.2 with Arduino V 2.3.4 error with message below after verifying code:
bash: line 1: cp: command not found
exit status 127
Compilation error: exit status 127
I think the problem system variable is not set. Using cp command with terminal has no problem.
Thank you
Nott
Topic moved from IDE 1.x to IDE 2.x
sonofcy
3
Show the complete verbose error log in code tags.
Thank you, the problem was solved by adding compiler path to system variable path.
sonofcy
5
Sorry, now that I drive a Mac I forget about the executable path.
system
Closed
6
