I have an ATTiny85 which I program using a sparkfun programmer (https://www.sparkfun.com/products/11801) and the ATTiny Board Manager I am using is: https://raw.githubusercontent.com/damellis/attiny/ide-1.6.x-boards-manager/package_damellis_attiny_index.json
Below is my code, I am having trouble getting the interrupt to work when I ground Pin 2.
I have tested the LED does work outside of the interrupt (inside the loop). Any suggestions are welcome.
#include "Arduino.h"
#define interruptPin 2
const int led = 3;
bool lastState = 0;
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(interruptPin, pulseIsr, CHANGE);
pinMode(led, OUTPUT);
void pulseIsr() {
if (!lastState) {
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
lastState = 1;
else {
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
lastState = 0;
attachInterrupt does not take a pin number as the first argument but the interrupt number. You use digitalPinToInterrupt to convert; see attachInterrupt() - Arduino Reference.
I'm not familiar with the ATTiny85 nor with the boards package that you use, but I think that you can give that a try.
I was way off.
Here is how to set up an interrupt on the ATTiny85 using the Arduino IDE (this example uses digital pin 4 (pin 3 on the chip):
const byte interruptPin = 4;
const byte led = 3;
bool lastState = false;
ISR (PCINT0_vect) // this is the Interrupt Service Routine
if (!lastState) {
lastState = true;
else {
lastState = false;
pinMode(interruptPin, INPUT_PULLUP); // set to input with an internal pullup resistor (HIGH when switch is open)
// interrupts
PCMSK |= bit (PCINT4); // want pin D4 / pin 3
GIFR |= bit (PCIF); // clear any outstanding interrupts
GIMSK |= bit (PCIE); // enable pin change interrupts
