Hello all,
I have been playing around with the DMXserial library.
I have built the comms circuit, and tested it completely and I am sure its correct.
http://www.mathertel.de/Arduino/DMXShield.aspx
My simple testing routine however fails to produce any results.
// Change DMX_USE_PORT1 in DMXSerial.avr.h if using serial1 on a Mega
#include <DMXSerial.h>
#define DMXdirectionOUT 18
DMXSerial.init(DMXController);
pinMode (DMXdirectionOUT, OUTPUT);
digitalWrite(DMXdirectionOUT, LOW); // (Switch to transmit)
DMXSerial.write(1, 255);
delayMicroseconds(2000); // wait a little bit
} // loop
Now this uses serial0 I believe. In the DMXSerial_avr.h file, it specifies that you can change:
// For using the serial port 1 on a Arduino MEGA 2560 board, enable the following DMX_USE_PORT1 definition.
// #define DMX_USE_PORT1
I am using a Pro Micro on pins 0 and 1.
Are these pins Serial0 or Serial1? What is the USB programming serial? Does it share with pins 0 and 1?
It doesn't work with the statement above anyway.
Any clues? Clearly I am doing something stupid.
