I'm a bit stuck here.
There are cables in my house for a home alarm, and I can't use them for a lan/ethernet.
I want to communicate with a few other Arduinos.
I can connect one cable to another to get and finally for example to the garage. It's only 6 meters away, but it's 20 meters (or more) cable to get there.
The maximum distance is about 15 meters, and the maximum cable length could be 30 meters.
There are a number of different cables, sometimes with 3, or 4 or 6 wires.
The cables are sometimes running along power cables or phone lines.
So I need to protect against spikes, and I need a checksum to prevent false data.
The data is only short commands, or temperature readings and so.
With serial TTL-leve RX and TX, I need some collision detect, and I need 3 wires. But this is the most simple solution.
With 1-wire, I'm stuck with a fixed timing.
With I2C, I need to write something that is about 4kbit/s or less, and need 3 wires.
With 2.4GHz wireless, I doubt if they can do 15 meters indoors, and I have to find out how that works (never used it before).
Using 433MHz would be possible. But the home alarm is at 433MHz and I don't want to interfere with that.
Graynomad:
I assume the Ethernet is not for talking to the slaves? It could be but that drives the cost up a lot.
Thanks for your answers.
Ethernet is only for the master. I have a webserver running with the website on SD card. It can show data from the Arduino and I can send commands to it. With a wifi-tablet to control it, is so much fun, that I want to control all Arduinos via that webserver.
