Hello,
I am looking for a way to communicate the Arduino Mega as Slave and a PLC as a Master over RS232 or RS485.
Any suggestion is appreciated.
Regards.
Hello,
Regards.
For the hardware I would get yourself a 5V RS485 module (MAX485 chip). Something like one of these:
As for code, I've tinkered with this library out of curiosity a while back:
If you are experimenting, then I would also suggest getting hold of an RS485-USB dongle like this one:
Thanks, finally i figured out using this cable rs485 usb cable
I succeed communication between arduino max485 and modbus slave software that runs in windows. Next stet is direclty to a PLC.
Is there any compatibility issue with brands like siemens, allen bradley, idec etc?
Or doesn't matter?
Thank you for any help you can provide.
I'm not a PLC expert or even novice, but if it supports Modbus then it should adhere to the Modbus specs. I would have thought that the Modbus world would be designed with interoperability as standard, but maybe there could be some quirks.
Finally i figured out. Thank you!
