communication between 2 Arduino Mega
it's my first time making a serial communication between 2 Arduinos, and I have a problem>
I'm sending an integer "550", to check. but in the receiver, shows "535348".
my code is this..
sending Mega
    int val5=550;
    Serial.print(val5);
the receiver Mega
    int incomingByte;
    //Serial1.begin(9600);
    if (Serial.available()) {
    incomingByte = Serial.read();
    Serial.print(incomingByte);
as you can see, I'm only sending 550, each time I press Reset. I have checked with putty, and is sending the integer in the COM port of the sender. but the value that I receive in the receiver port is the one that I mentioned. I have tried with Serial.write, assigning the integer as other type of numbers....(byte, long...etc)
I think that its just a beginner's mistake....
please help me if you know what is happening.
thank you!
Serial.print is sending a string "550". Is that what you expect?
well, I was expecting to send a number, an integer...also I tried the same with Serial.write, without changing anything in the receiver code. but I still have the same problem.
This is what you are sending.
535348
53 = '5'
53 = '5'
48 = '0'
ohh I see... so it's sending digit by digit in binary and reading in the same way.
how can I fix this? do I have to make a loop to save digit by digit in a vector?
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example.
I think your receiving Mega should receive on (say) Serial1 and send to the Serial Monitor using Serial.
At the moment I am using this program on a Mega to receive data and pass it on to the Serial Monitor
// Example 3 - Receive with start- and end-markers
const byte numChars = 32;
char receivedChars[numChars];
boolean newData = false;
    Serial.println("<Mega is ready>");
    recvWithStartEndMarkers();
    showNewData();
void recvWithStartEndMarkers() {
    static boolean recvInProgress = false;
    static byte ndx = 0;
    char startMarker = '<';
    char endMarker = '>';
    char rc;
    while (Serial1.available() > 0 && newData == false) {
        rc = Serial1.read();
        if (recvInProgress == true) {
            if (rc != endMarker) {
                receivedChars[ndx] = rc;
                ndx++;
                if (ndx >= numChars) {
                    ndx = numChars - 1;
            else {
                receivedChars[ndx] = '\0'; // terminate the string
                ndx = 0;
                newData = true;
        else if (rc == startMarker) {
            recvInProgress = true;
void showNewData() {
    if (newData == true) {
        Serial.print("This just in ... ");
        Serial.println(receivedChars);
        newData = false;
...R
