Communication between Raspberry pi and Arduino via GPIO
Hi, I want to create a communication between Raspberry pi and arduino by using GPIO pin, but I have problem with my code. So RPi act as a sender and arduino will be the receivier, for example : if RPi pin number 4 is HIGH/LOW, consequently so does the Arduino's pin 4, also arduino will print '1' if it is high or '0' if it is low.
const int piPin1 = 4;
const int piPin2 = 6;
int PiState = 0;
pinMode(piPin1, INPUT);
pinMode(piPin2, INPUT);
PiState = digitalRead(PiState);
if (PiState == 4 - '0') {
digitalWrite(piPin1 , !digitalRead(piPin1));
if(PiState == 6 - '0') {
digitalWrite(piPin2, !digitalRead(piPin2));
return 0;
Here's the code that I'm curently working on.
Also I've 2 channel relay shield attatched on my arduino , how do I connect them to RPi by using cable jumper.
Any help or advice would be greatly appreciated.
Thankyou
The result of a digitalRead() call is either HIGH or LOW and not a numeric character as your code
assumes .
stowite:
assumes .
So it should be
if (PiState == HIGH) {
else if{
It is not obvious to me what you are trying to do. If your intent is to toggle either piPin1 or piPin2, depending on the state of the piState pin, as rapidly as possible then that code should do the job.
yes I need to toogle either piPin1 and piPin2 or toggle both of them
i change the code into
const int piPin2 = 5;
int PiState = 0;
  digitalRead(piPin1);
  digitalRead(piPin2);
 if (PiState == LOW){
 return 0;
Im totally new into microcontroller , some advice or help would be appriciated
I don't understand your latest code. This
is nonsense since will read into PiState from pin 0 or pin 1 since PiState is always 0 or 1! It needs to read from the pin that is connected to the PI.
This
is nonsense since it checks for PiState being HIGH, reads piPin1 and discards the value read then reads piPin2 and discards the value read. Similarly the other block of code.
Thankyou for your advice
PiState = digitalRead(piPin1);
  digitalWrite(piPin1, HIGH);
 else {
  digitalWrite(piPin1 , LOW);
 PiState = digitalRead(piPin2);
  digitalWrite(piPin2, HIGH);
 else {
  digitalWrite(piPin2 , LOW);
I've update my code, tell me if i still missing something
Delta_G:
You're reading and writing to the same pin. Is that pin an input or an output? It's hard for me to see how it is going to be both in this code.
the pin is an input, I'm terribly sorry for my code also I'm sorry that I've made another post at pins - Arduino & RPi communication via GPIO - Arduino Stack Exchange and talking nonsense all the time
so It's a digitalRead, impretty much confuse , my programming skill is below average
