Communication of Arduino with mqtt broker on raspberry via Ethernet
Hey,
I can't set my arduino as cilent on mosquitto broker.
I am trying to connect arduino to mosquitto on raspberry via ethernet cable.
I set raspberry static ip eth0 address 192.168.4.1 . Arduio pings on raspberry but i can't connect to mqqtt server.
I set in mosquitto configure allow_anonymous true but still does not work. Do you guys have any advice? I will be very grateful.
here is code
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
byte mac[]    = {  0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
IPAddress ip(192, 168, 4, 100);
IPAddress server(192, 168, 4, 1); //my raspberry eth0 ip adress
// Callback function header
void callback(char* topic, byte* payload, unsigned int length);
EthernetClient ethClient;
PubSubClient client(server, 1883, callback, ethClient);
void callback(char* topic, byte* payload, unsigned int length) {
  //turn the LED ON if the payload is '1' and publish to the MQTT server a confirmation message
  if (payload[0] == '1') {
    client.publish("outTopic", "value 1");
  //turn the LED OFF if the payload is '0' and publish to the MQTT server a confirmation message
  if (payload[0] == '0') {
    client.publish("outTopic", "value 0");
} // void callback
  Ethernet.begin(mac, ip);
  if (client.connect("arduinoClient")) {
    Serial.println("connected to mqtt");
    client.publish("outTopic", "hello there");
    client.subscribe("inTopic");
  client.loop();
From networking - Mosquitto: Starting in local only mode - Stack Overflow
Mosquitto on Debian, to allow external connections add the following two lines to /etc/mosquitto/mosquitto.conf
listener 1883
thanks for your reply. I have already done it but it still does not work.
Is there something more on your mind what can i do?
Use a MQTT client on another computer or mobile phone to prove that the Ras Pi allows external connections.
