how to write correctly this condition ?
float temperature;
if (data.temperature >= -15.0 && data.temperature <= 50.0)
{Serial.println ("it is Ok"}
{Serial.println ("Bad value !"}
float temperature;
What's wrong with how you got it wrote?
Tested and working:
// The random() function creates a integer value,
// to get all kind of numbers I use a division.
float temperature = ((float) random(1, 4000) - 2000.0) / (float) random( 1, 100);
Serial.print( "The temperatue is ");
int n = Serial.print( temperature);
for( int i=n; i<8; i++)
Serial.print( " ");
Serial.print( " (");
if( temperature >= -15.0 && temperature <= 50.0)
Serial.print( "it is Ok");
Serial.print( "Bad value !");
Serial.print( ")");
delay( 1000);
Thank's, I have another working solution.
compareValueFloat = data.temperature * 10;
compareValue = round(compareValueFloat);
if (!compareValue >= -150 && !compareValue <= 500)
Serial.printf("Bad Temperature value: %f\r\n", data.temperature);
data.temperature = NULL;
Why is there a exclamation before the compareValue in the condition ?
Sorry, I was wrong.
This is my code, but I'm sure there is a more elegant way to write this code, probably as suggested from @Koepel.
void LoRaInterface::sanityCheck(StructData &data)
if (compareValue >= -150 && compareValue <= 500)
compareValueFloat = data.humidity * 10;
if (compareValue >= 0 && compareValue <= 1000)
Serial.printf("Bad Humidity value: %f\r\n", data.humidity);
data.humidity = NULL;
compareValueFloat = data.voltage * 10;
if (compareValue >= 0 && compareValue <= 60)
Serial.printf("Bad Voltage value: %f\r\n", data.voltage);
data.voltage = NULL;
When writing code, it is better to make it as simple and as straightforward as possible.
To check if a float temperature is between certain values or outside a certain range, you can write that directly in code. The 'C' and 'C++' language is perfect for that.
This is how to put it in code. You may use 'and' and 'or' instead of && and ||
if (data.temperature < -15.0 or data.temperature > 50.0)
data.temperature = 0.0;
Thanks, it work fine. Grazie @Koepel
Are you trying to detect a bad sensor or wrong outside temperature ? What happens if it really gets colder than -15°C or hotter than 50°C (in direct sunlight) ?
I would check for -100 and +500 or so.
This sensor will run on Sicily, Italy, and temperature are never less - 10! ![]()
According to Wikipedia: -15.2°C
and 48.5°C ![]()
Ok, I will change the limits. Thank's
