Comparing function to string inside while loop
Hi, I'm new to Arduino and programming in general so sorry if this is a stupid question.
Using the Keypad library, I'm trying to compare a function that fetches the status of a key to one of the strings that the function returns, inside a while loop and it returns an error message. Being a new programmer, I'm not sure what I am doing wrong. Any insight is greatly appreciated. Thanks in advance.
Here is the line: while(KeyState getState()==PRESSED) {}
Here is the error message:
Arduino: 1.6.9 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/DMac/Documents/Arduino/Keypad/KeypadSketch/KeypadSketch.ino: In function 'void loop()':
KeypadSketch:30: error: expected primary-expression before 'getState'
KeypadSketch:30: error: expected ')' before 'getState'
KeypadSketch:30: error: 'getState' was not declared in this scope
KeypadSketch:30: error: expected ';' before ')' token
KeypadSketch:35: error: expected primary-expression before 'getState'
KeypadSketch:35: error: expected ')' before 'getState'
KeypadSketch:35: error: 'getState' was not declared in this scope
KeypadSketch:35: error: expected ';' before ')' token
KeypadSketch:40: error: expected primary-expression before 'getState'
KeypadSketch:40: error: expected ')' before 'getState'
KeypadSketch:40: error: 'getState' was not declared in this scope
KeypadSketch:40: error: expected ';' before ')' token
KeypadSketch:45: error: expected primary-expression before '{' token
   if(myPassword=={5,2,5,3})
KeypadSketch:45: error: expected ')' before '{' token
exit status 1
option enabled in File -> Preferences.
If you need it, here is the whole program:
//http://playground.arduino.cc/Code/Keypad
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {8, 7, 6, 9}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
void loop(){
 int myPassword[4];
  char waitForKey();
  myPassword[0] = customKeypad.getKey();
  tone(10,941,250);
  Serial.println(myPassword[0]);
    char waitForKey();
    myPassword[1] = customKeypad.getKey();
    tone(10,941,250);
    Serial.println(myPassword[1]);
  char waitForKey();
  myPassword[2] = customKeypad.getKey();
  tone(10,941,250);
  Serial.println(myPassword[2]);
    char waitForKey();
    myPassword[3] = customKeypad.getKey();
    tone(10,941,250);
    Serial.println(myPassword[3]);
  { tone(10,1500,250);
  delay(25);
  tone(10,1750,250);
   delay(25);
  tone(10,2000,250);
   delay(25);
    /*relay*/ }
    else {
   tone(10,300,250);
   delay(25);
   tone(10,300,250);
   delay(25);
   tone(10,300,250);
   delay(25);
while( getState()==PRESSED) {}
You're not trying to compare a function, you're trying to compare the function's return value
You declare the object "customKeypad".
To call a function of that object, you should do : customKeypad.getState()
I'm not sure if this will work, since the return value of .getState() is an enumerator. That means it is almost an integer, so I think it will work.
  while(customKeypad.getState()==PRESSED)
An object is the data and functions in a single package. The goal of an object is that it is seperated from other things. Therefor the compiler must know every time which object is used. Just a getState() will not work, and the declaration with 'KeyState' should not be used like that.
Where did you get the library from ?
If you look at all the examples here : GitHub - Chris--A/Keypad: A version of the keypad library found in Wiring. This is just a copy made compatible with the Arduino IDE library manager.
then you found the use of .getStat().
Perhaps you might need to declare an extra variable for the key state.
Koepel:
Thank you!! I appreciate the help
char waitForKey();
Don't do that either
