I know how to compere string in normal Serial monitor
I want to know how to compere when I'm connecting another device to the Arduino
this is the code that working
pinMode(13, OUTPUT);
Serial.begin(9600); // Initialize serial port
serialReader();
void serialReader(){
int makeSerialStringPosition;
int inByte;
char serialReadString[50];
const int terminatingChar = 13; //Terminate lines with CR
inByte = Serial.read();
makeSerialStringPosition=0;
if (inByte > 0 && inByte != terminatingChar) { //If we see data (inByte > 0) and that data isn't a carriage return
delay(100); //Allow serial data time to collect (I think. All I know is it doesn't work without this.)
while (inByte != terminatingChar && Serial.available() > 0){ // As long as EOL not found and there's more to read, keep reading
serialReadString[makeSerialStringPosition] = inByte; // Save the data in a character array
makeSerialStringPosition++; //Increment position in array
//if (inByte > 0) Serial.println(inByte); // Debug line that prints the charcodes one per line for everything recieved over serial
inByte = Serial.read(); // Read next byte
if (inByte == terminatingChar) //If we terminated properly
serialReadString[makeSerialStringPosition] = 0; //Null terminate the serialReadString (Overwrites last position char (terminating char) with 0
Serial.println(serialReadString);
if (strcmp(serialReadString, "LEDOn") == 0) digitalWrite(13, HIGH);
if (strcmp(serialReadString, "LEDOff") == 0) digitalWrite(13, LOW);
and this is my try to get the same from far away device using serial connection
I have change all "Serial.print\read" to "mySerial.print\read" , just not the last one
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
Serial.begin(19200);
delay(1500);
Serial.println("Ready to work!");
mySerial.begin(19200);
mySerial.println("AT");//just to see that it's working
serialReader();
int inByte;
inByte = mySerial.read();
while (inByte != terminatingChar && mySerial.available() > 0){ // As long as EOL not found and there's more to read, keep reading
inByte = mySerial.read(); // Read next byte
Before Serial.read() you should check Serial.available() for -every- character.
The half-fast way is to check and get 1 character then delay() while the rest "should come in". LOL, how many ways can that go wrong?
Normally I check Serial.available() right in loop(), usually as the last priority if there's other tasks I have going on since Serial is so glacial-slow compared to Arduino. But I code as if I need to be checking something 10,000x a second as well as having user I/O.
try what you said (if I understand you correct)
and I know I see in the Serailmonitor 1 no mater what I send
delay(1500);
serialReader();
int inByte;
while (mySerial.available() )
if (strcmp(serialReadString, "on") == 0) digitalWrite(13, HIGH);
if (strcmp(serialReadString, "off") == 0) digitalWrite(13, LOW);
This compiles but I can't test it. It should be close to or working.
I could do more but this should be confusing enough.
Basically, this will go through loop() 1,000's if not 1,000,000 times just to read "off". Of you want to know then add a counter and print that, it should open your eyes and mind.
The flow is
wait for data
read data and either append it to the string or end the string
2A) if end the string, print, lex and modify led state then re-init buffer index
goto 1
char serialReadString[50]; // now global, allocated once and stays
byte maxStringLen = 49; // allow for terminating NULL
byte makeSerialStringPosition = 0;
byte inByte;
const byte terminatingChar = 13; //Terminate lines with CR
if ( mySerial.available())
if ((inByte != terminatingChar) && (makeSerialStringPosition < maxStringLen))
serialReadString[makeSerialStringPosition++] = inByte; // position is post-incremented
else // end the string if read terminatingChar --or-- the buffer array is full
makeSerialStringPosition = 0; // init for next input
That's a whole lot of code and wasted processor time for something fairly simple:
const byte MAX_CHARS = 10; // maximum number of characters we can receive before overflow occurs
const char TERMINATING_CHAR = '\n'; // let's us know when the string is complete
char buffer[MAX_CHARS+1]; // storage for our characters (+ 1 for null-terminator)
byte index = 0; // keeps track of where to put the next character
Serial.println("begin");
if (Serial.available() > 0) // if there is something in the buffer to read
char inByte = Serial.read(); // read it
if (inByte == TERMINATING_CHAR) // the string is complete
// DO SOMETHING WITH THE STRING HERE
buffer[0] = '\0'; // clear the buffer
index = 0;
else if (index < MAX_CHARS) // make sure we aren't overflowing the buffer
buffer[index] = inByte; // store character in our buffer
index++; // move index to next spot
buffer[index] = '\0'; // and null terminate for string processing
// OVERFLOW OCCURRED, DO SOMETHING ABOUT IT
Arrch:
It would be a good idea to check there was space in the array (including an allowance for the following null terminator) before appending the new character.
PeterH:
I agree, but the above was a simple example that demonstrates the base logic behind it. What happens when an overflow occurs has been left to the designer to decide. I suppose I can edit my example to include an overflow check.
