Compilation doesn't work avrdude: Found CMSIS-DAP compliant device, using EDBG protocol
I use the arduino wifi rev 2 and I encounter the following problem when compiling. I did some digging, but I didn’t find a solution, so if anyone could help me, it would be cool.
thank you in advance
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\stagiaire\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : usb
     Using Programmer              : xplainedmini_updi
     Overriding Baud Rate          : 115200
AVR Part : ATmega4809
Chip Erase delay : 0 us
PAGEL : P00
BS2 : P00
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 0
StabDelay : 0
CmdexeDelay : 0
SyncLoops : 0
ByteDelay : 0
PollIndex : 0
PollValue : 0x00
Memory Detail :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
       prodsig        0     0     0    0 no         61   61      0     0     0 0x00 0x00
       fuses          0     0     0    0 no          9    0      0     0     0 0x00 0x00
       fuse0          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse1          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse2          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse4          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse5          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse6          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse7          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse8          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       lock           0     0     0    0 no          1    0      0     0     0 0x00 0x00
       data           0     0     0    0 no          0    0      0     0     0 0x00 0x00
       usersig        0     0     0    0 no         64   64      0     0     0 0x00 0x00
       flash          0     0     0    0 no      49152  128      0     0     0 0x00 0x00
       eeprom         0     0     0    0 no        256   64      0     0     0 0x00 0x00
     Programmer Type : JTAGICE3_UPDI
     Description     : Atmel AVR XplainedMini in UPDI mode
     ICE hardware version: 0
     ICE firmware version: 1.19 (rel. 57)
     Serial number   : 5A450AE7161F245E644F
     Vtarget         : 5.00 V
     JTAG clock megaAVR/program: 0 kHz
     JTAG clock megaAVR/debug:   0 kHz
     JTAG clock Xmega: 0 kHz
     PDI clock Xmega : 0 kHz
avrdude: Partial Family_ID returned: "mega"
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e9651 (probably m4809)
avrdude: erasing chip
avrdude: reading input file "C:\Users\stagiaire\AppData\Local\Temp\arduino-sketch-F49894E4672427D48260E4E3405B49DC/Blink.ino.hex"
avrdude: writing flash (6566 bytes):
Writing | ################################################## | 100% 1.80s
avrdude: 6566 bytes of flash written
avrdude: reading input file "0x01"
avrdude: writing fuse2 (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of fuse2 written
avrdude: reading input file "0xC9"
avrdude: writing fuse5 (1 bytes):
avrdude: 1 bytes of fuse5 written
avrdude: reading input file "0x02"
avrdude: writing fuse8 (1 bytes):
avrdude: 1 bytes of fuse8 written
avrdude: reading input file "C:\Users\stagiaire\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7/bootloaders/atmega4809_uart_bl.hex"
avrdude: writing flash (280 bytes):
Writing | ################################################## | 100% 0.12s
avrdude: 280 bytes of flash written
avrdude done. Thank you.
HI @simth6. You have posted the output from a successful compilation and upload. Congratulations! There is no problem at all, so you can get back to working with your Uno WiFi Rev2
