I have been looking through the topics and have tried to fix my sketch, but I can't find what I am missing. Here is the sketch:
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SdFat_Adafruit_Fork.h> // SD card & FAT filesystem library
#include <Adafruit_SPIFlash.h> // SPI / QSPI flash library
#include <Adafruit_ImageReader.h> // Image-reading functions
#define USE_SD_CARD
#define SD_CS 4 // SD card chip select
#define TFT_CS 10 // TFT select pin
#define TFT_DC 8 // TFT data/command pin
#define TFT_RST 9 // Or set to -1 and connect TFT RST to Arduino reset pin
#if defined(USE_SD_CARD)
SdFat SD; // SD card filesystem
Adafruit_ImageReader reader(SD); // Image-reader object, pass in SD filesys
#else
// SPI or QSPI flash filesystem (i.e. CIRCUITPY drive)
#if defined(__SAMD51__) || defined(NRF52840_XXAA)
Adafruit_FlashTransport_QSPI flashTransport(PIN_QSPI_SCK, PIN_QSPI_CS,
PIN_QSPI_IO0, PIN_QSPI_IO1, PIN_QSPI_IO2, PIN_QSPI_IO3);
#else
#if (SPI_INTERFACES_COUNT == 1)
Adafruit_FlashTransport_SPI flashTransport(SS, &SPI);
#else
Adafruit_FlashTransport_SPI flashTransport(SS1, &SPI1);
#endif
#endif
Adafruit_SPIFlash flash(&flashTransport);
FatVolume filesys;
Adafruit_ImageReader reader(filesys); // Image-reader, pass in flash filesys
#endif
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
Adafruit_Image img; // An image loaded into RAM
int32_t width = 0, // BMP image dimensions
height = 0;
void setup(void) {
ImageReturnCode stat; // Status from image-reading functions
#if !defined(ESP32)
while (!Serial)
; // Wait for Serial Monitor before continuing
#endif
tft.initR(INITR_MINI160x80); // Initialize screen
Serial.println(F("TFT initialized."));
Serial.print(F("Initializing filesystem..."));
// SD card is pretty straightforward, a single call...
if (!SD.begin(SD_CS, SD_SCK_MHZ(10))) { // Breakouts require 10 MHz limit due to longer wires
Serial.println(F("SD begin() failed"));
for (;;)
; // Fatal error, do not continue
#else
// SPI or QSPI flash requires two steps, one to access the bare flash
// memory itself, then the second to access the filesystem within...
if (!flash.begin()) {
Serial.println(F("flash begin() failed"));
for (;;)
if (!filesys.begin(&flash)) {
Serial.println(F("filesys begin() failed"));
for (;;)
#endif
Serial.println(F("OK!"));
tft.fillScreen(ST77XX_BLACK);
tft.setRotation(1);
tft.invertDisplay(1);
reader.drawBMP("/1.bmp", tft, 0, 0);
tft.setRotation(1);
int voltage = analogRead(A0); // read the voltage input from analog pin A0
int imageIndex = map(voltage, 0, 1023, 0, 219); // map the voltage value to an image index (assuming there are 5 images on the SD card)
File imageFile = SD.open("image" + String(imageIndex) + ".bmp"); // open the image file on the SD card
tft.drawBitmap(0, 0, imageFile); // draw the image on the ST7735 display
imageFile.close(); // close the image file
delay(10); // wait for 1 second before displaying the next image
I have tried a variety of {} combinations around the loop with no success. The error is coming up referencing the void loop line.
