Compilation error: 'dtostrf' was not declared in this scope
it is on avr lib, but not with samd lib ?
Not an expert for samd but I found this via Google:
#include <avr/dtostrf.h>
Sources:
dtostrf function not working in Arduino Zero - Hardware / Arduino Zero - Arduino Forum
Test sketch from (https://github.com/esp8266/Arduino/issues/6695)
float f=1234.567;
char s[20]="";
dtostrf(f,8,3,s);
Serial.println(f);
Serial.println(s);
Good luck!
Check whether the samd library sprintf() supports float variables. Try this example, which works on ESP32 and ARM Cortex like nRF52840:
while (!Serial) yield();
Serial.println("sprintf float test");
float x=1.234;
char buf[40];
sprintf(buf,"x = %6.4f, cos(x) = %6.4f",x, cos(x));
Serial.println(buf);
That's worth a try!
In the meanwhile I found this
https://github.com/107-systems/107-Arduino-Debug/blob/main/src/dtostrf.c
dtostrf - Emulation for dtostrf function from avr-libc
Copyright (c) 2016 Arduino LLC. All rights reserved.
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#if defined(ARDUINO_ARCH_SAMD)
#include <stdio.h>
char *dtostrf (double val, signed char width, unsigned char prec, char *sout)
asm(".global _printf_float");
char fmt[20];
sprintf(fmt, "%%%d.%df", width, prec);
sprintf(sout, fmt, val);
return sout;
#endif /* defined(ARDUINO_ARCH_SAMD) */
thank you, it works fine !
