Compilation error: 'else' without a previous 'if'
I get the above compile error.
I have looked at the forum topics, but cannot see where I am going wrong.
  uint8_t selectedMenuItem = lcd.showMenu(menu, menuLen, 1);
  if (selectedMenuItem == mkLoadLabels)
    lcd.print("Loading Labels");
  //  loadLabels();  <--- IF I UNCOMMENT THIS LINE, I GET THE COMPILE ERROR
  else if (selectedMenuItem == mkRun)
    lcd.print("Start Labeller");
  else if (selectedMenuItem == mkSpeed)
    lcd.print("Speed selected");
  else if (selectedMenuItem == mkSpeed1)
    lcd.print("Slow selected");
  else if (selectedMenuItem == mkSpeed2)
    lcd.print("Medium selected");
  else if (selectedMenuItem == mkSpeed3)
    lcd.print("Fast selected");
  else if (selectedMenuItem == mkBack)
    lcd.print("Exit selected");
  while (lcd.getEncoderState() == eNone);
if (selectedMenuItem == mkLoadLabels) {
    loadLabels();  // <--- IF I UNCOMMENT THIS LINE, I GET THE COMPILE ERROR
Many thanks
Did you understand what the problem was ?
In C++, indentation serves only to improve code readability; unlike Python, it does not define the grouping of statements. The structure of an if/else statement looks like this:
if (condition)
  statement_if_true
  statement_if_false
Here, each branch executes a single statement, so if you want to do
then you are fine as lcd.print("Slow selected"); is a single statement.
But if you want to execute multiple statements as a group within an if or else like
    loadLabels();
it does not work as you have two statements. You need to enclose them in curly braces {}, creating what is known as a compound statement.
{ // this is a compound statement (so just one statement composed of multiple statements)
    loadLabels();
This way, the if or else still contains a single statement—the compound one—while grouping multiple commands together.
Makes sense?
Yes, many thanks
