Compilation error: exit status 1
In file included from c:\Users\pgnan\OneDrive\Documents\Arduino\libraries\libraries\Adafruit_ADXL345/Adafruit_ADXL345_U.h:36,
                 from C:\Users\pgnan\OneDrive\Desktop\5 PROJECTS\esp32_car_manoj\esp32_car_manoj.ino:13:
c:\Users\pgnan\OneDrive\Documents\Arduino\libraries\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:10:36: error: 'TwoWire' has not been declared
   Adafruit_I2CDevice(uint8_t addr, TwoWire *theWire = &Wire);
c:\Users\pgnan\OneDrive\Documents\Arduino\libraries\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:30:3: error: 'TwoWire' does not name a type; did you mean 'TwoWire_h'?
   TwoWire *_wire;
   TwoWire_h
c:\Users\pgnan\OneDrive\Documents\Arduino\libraries\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:10:56: error: 'Wire' was not declared in this scope
c:\Users\pgnan\OneDrive\Documents\Arduino\libraries\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:10:56: note: suggested alternative: 'WiFi'
                                                        WiFi
exit status 1
#define BLYNK_TEMPLATE_ID "TMPL3a8ZSDJWe"
#define BLYNK_TEMPLATE_NAME "ESP32 IOT EV CAR"
#define BLYNK_AUTH_TOKEN "93FbW2otNFylcf2D0kDVgsIuukwLamyJ"
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <BlynkSimpleEsp32.h>
#include <DHT.h>
#include <MQ135.h> // Include MQ135 library
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
#include <UniversalTelegramBot.h>
char auth[] = "93FbW2otNFylcf2D0kDVgsIuukwLamyJ";
char ssid[] = "IOT";
char pass[] = "1230987654321";
int IN1 = 13;
int IN2 = 12;
int IN3 = 14;
int IN4 = 27;
#define echoPin 5    // attach pin GPIO 18 ON ESP32 to pin Echo of HC-SR04
#define trigPin 4     // attach pin GPIO 5 ON ESP32 to pin Trig of HC-SR04
#define DHTPIN 33      // Pin where the DHT11 is connected
#define DHTTYPE DHT11 // DHT 11
#define MQ135PIN 32   // Pin where the MQ135 is connected
#define FIRE_PIN 18   // Pin where the fire detection sensor is connected
#define CRASH_PIN 15  // Pin where the crash switch is connected
#define ADXL345_ADDRESS (0x53) // I2C address for the ADXL345 accelerometer
#define BOT_TOKEN "7177790916:AAEJPS__PSGZfSAt0YYTQ3VCUghy9rl55BM"
#define CHAT_ID "5131145538"
long duration; // variable for the duration of sound wave travel
float distance; // variable for the distance measurement
#define BOT_MTBS 1000 // mean time between scan messages
unsigned long bot_lasttime; // last time messages' scan has been done
float temperatureC;
float temperatureF;
float humidity;
String orientation; // Declaring orientation as a global variable
WiFiClientSecure secured_client;
UniversalTelegramBot bot(BOT_TOKEN, secured_client);
DHT dht(DHTPIN, DHTTYPE);
MQ135 gasSensor = MQ135(MQ135PIN); // Use MQ135 library
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345); // Some unique ID for accelerometer
  Serial.begin(115200); /* Set the baudrate to 115200 */
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  pinMode(IN3, OUTPUT);
  pinMode(IN4, OUTPUT);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(FIRE_PIN, INPUT);
  pinMode(CRASH_PIN, INPUT_PULLUP); // Internal pull-up resistor for the switch
  dht.begin();
  // Initialize accelerometer
  if (!accel.begin(ADXL345_ADDRESS)) {
    Serial.println("Could not find a valid ADXL345 sensor, check wiring!");
    while (1);
  Blynk.begin(auth, ssid, pass, "blynk.cloud", 8080);
  secured_client.setCACert(TELEGRAM_CERTIFICATE_ROOT); // Add root certificate for api.telegram.org
BLYNK_WRITE(V1) { // Forward button
  int buttonState = param.asInt();
  if (buttonState == 1) {
    // Move Forward
    digitalWrite(IN2, HIGH);
    digitalWrite(IN4, HIGH);
    // Stop
    digitalWrite(IN1, LOW);
    digitalWrite(IN2, LOW);
    digitalWrite(IN3, LOW);
    digitalWrite(IN4, LOW);
  delay(50);
BLYNK_WRITE(V2) { // Backward button
    // Move Backward
    digitalWrite(IN1, HIGH);
    digitalWrite(IN3, HIGH);
    // Stop
  delay(50);
BLYNK_WRITE(V3) { // Left button
    // Turn Left
    // Stop turning
  delay(50);
BLYNK_WRITE(V4) { // Right button
    // Turn Right
    // Stop turning
  delay(50);
  Blynk.run();
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = duration * 0.034 / 2;
  Serial.print("Distance: ");
  Serial.println(distance);
  Blynk.virtualWrite(V5, distance); // Send distance data to Blynk
  delay(50);
  if (distance <= 10) {
    Serial.println("Object is behind Robot");
    Serial.println("Object is not behind Robot");
  // Read temperature and humidity from DHT sensor
  float temperature = dht.readTemperature();
  float humidityValue = dht.readHumidity(); // Read humidity separately
  if (!isnan(temperature) && !isnan(humidityValue)) {
    Serial.print("Temperature: ");
    Serial.println(temperature);
    Serial.print("Humidity: ");
    Serial.println(humidityValue);
    // Update global variables
    temperatureC = temperature;
    temperatureF = temperature * 9 / 5 + 32;
    humidity = humidityValue;
    // Send data to Blynk
    Blynk.virtualWrite(V6, temperatureC);
    Blynk.virtualWrite(V7, temperatureF);
    Blynk.virtualWrite(V8, humidity);
    Serial.println("Failed to read from DHT sensor!");
  float gasValue = gasSensor.getPPM(); // Use MQ135 library method to get PPM value
  Serial.print("Gas Value: ");
  Serial.println(gasValue);
  int fireStatus = digitalRead(FIRE_PIN);
  Serial.print("Fire Status: ");
  //Serial.println(fireStatus);
  if (fireStatus == HIGH) {
    Serial.println("Fire Detected");
    Serial.println("No Fire Detected");
  int crashStatus = digitalRead(CRASH_PIN);
  //Serial.print("Crash Status: ");
  //Serial.println(crashStatus);
  if (crashStatus == LOW) {
    Serial.println("Crash Detected");
    Serial.println("No Crash Detected");
  // Read data from the ADXL345 accelerometer
  sensors_event_t event;
  accel.getEvent(&event);
  // Calculate the angle using the accelerometer data
  float angleX = atan2(event.acceleration.x, event.acceleration.z) * RAD_TO_DEG;
  float angleY = atan2(event.acceleration.y, event.acceleration.z) * RAD_TO_DEG;
  // Determine orientation as text
  if (angleX > 45 && angleX < 135)
    orientation = "Back";
  else if (angleX < -45 && angleX > -135)
    orientation = "Front";
  else if (angleY > 45 && angleY < 135)
    orientation = "Right";
  else if (angleY < -45 && angleY > -135)
    orientation = "Left";
  else if (angleX >= 135 || angleX <= -135 || angleY >= 135 || angleY <= -135)
    orientation = "Flip";
    orientation = "Normal";
  Serial.print("Orientation: ");
  Serial.println(orientation);
  // Check if it's time to scan for new messages from the Telegram bot
  if (millis() - bot_lasttime > BOT_MTBS) {
    int numNewMessages = bot.getUpdates(bot.last_message_received + 1);
    while (numNewMessages) {
      Serial.println("got response");
      handleNewMessages(numNewMessages);
    bot_lasttime = millis();
void handleNewMessages(int numNewMessages) {
  Serial.print("handleNewMessages ");
  Serial.println(numNewMessages);
  for (int i = 0; i < numNewMessages; i++) {
    String chat_id = String(bot.messages[i].chat_id);
    if (chat_id != CHAT_ID ) {
      bot.sendMessage(chat_id, "Unauthorized user", "");
      String text = bot.messages[i].text;
      if (text == "/data") {
        // Respond with all sensor readings
        String msg = "sensor readings.\n";
        msg += "Temperature in Celsius: " + String(temperatureC) + "°C\n";
        msg += "Temperature in Fahrenheit: " + String(temperatureF) + "°F\n";
        msg += "Humidity: " + String(humidity) + "%\n";
        msg += "Gas value: " + String(gasSensor.getPPM()) + "\n";
        msg += "Fire status: " + String(fireStatus == HIGH ? "Detected" : "Not Detected") + "\n";
        msg += "Crash status: " + String(crashStatus == LOW ? "Detected" : "Not Detected") + "\n";
        msg += "Distance: " + String(distance) + "cm\n";
       msg += "Orientation: " + orientation + "\n";
       bot.sendMessage(chat_id, msg, "");
      if (text == "/tempC") {
        String msg = "Temperature is ";
        msg += msg.concat(temperatureC);
        msg += "C";
      if (text == "/tempF") {
        msg += msg.concat(temperatureF);
        msg += "F";
      if (text == "/humidity") {
        String msg = "Humidity is ";
        msg += msg.concat(humidity);
        msg += "%";
      if (text == "/gas") {
        String msg = "Gas value is ";
        msg += msg.concat(gasSensor.getPPM());
      if (text == "/fire") {
          bot.sendMessage(chat_id, "Fire Detected", "");
          bot.sendMessage(chat_id, "No Fire Detected", "");
      if (text == "/crash") {
          bot.sendMessage(chat_id, "Crash Detected", "");
          bot.sendMessage(chat_id, "No Crash Detected", "");
      if (text == "/distance") {
        String msg = "Distance is ";
        msg += msg.concat(distance);
        msg += "cm";
      if (text == "/orientation") {
        bot.sendMessage(chat_id, "Orientation is " + orientation, "");
      if (text == "/start") {
        String welcome = "sensor readings.\n";
        welcome += "/data : all sensor data \n";
        welcome += "/tempC : Temperature in Celsius \n";
        welcome += "/tempF : Temperature in Fahrenheit\n";
        welcome += "/humidity : Humidity\n";
        welcome += "/gas : Gas value\n";
        welcome += "/fire : Fire status\n";
        welcome += "/crash : Crash status\n";
        welcome += "/distance : Distance\n";
        welcome += "/orientation : Orientation\n";
        bot.sendMessage(chat_id, welcome, "Markdown");
For which board are you compiling?
Is the Adafruit library compatible with the board that you are compiling for.
There is a known bug with placing an Arduino folders on the OneDrive dir - one of the issues that the compiler do not resolve libraries on the One drive.
Try to move your Arduino installation outside the OneDrrive folder tree
Esp32 dev module
