I'm using Ardunio IDE 2.0.0-beta.7 on Windows 10. When I compile basic examples, I have no errors. When I compile a multiple tab sketch, I receive "Compilation Error :2 UNKNOWN: exit status 1". The board library is for the ESP32 Dev kit.
I tried unstalling and reinstalling the Arduino IDE beta. Didn't help
Is there a solution?
pert
May 31, 2021, 3:56pm
2
Hi @Dan2017 . Thanks for giving the beta phase Arduino IDE 2.x a try!
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
Select File > Preferences from the Arduino IDE's menus.
Check the box next to "Show verbose output during: [] compilation" .
Click the OK button.
Select Sketch > Verify/Compile from the Arduino IDE's menus.
Wait for the compilation to end.
Right click on the black "Output" pane at the bottom of the Arduino IDE 2.x window.
From the context menu, click Copy All .
Open a forum reply here by clicking the Reply button.
Click the </> icon on the post composer toolbar. This will add the forum's code block markup (``` ) to your reply to make sure the error messages are correctly formatted.
Press Ctrl +V . This will paste the compilation output into the code block.
Move the cursor outside of the code tags before you add any additional text to your reply.
Click the Reply button to post the output.
Using board 'esp32' from platform in folder: C:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4
Using core 'esp32' from platform in folder: C:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4
Detecting libraries used...
"C:\Users\davis\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "C:\Users\davis\AppData\Local\Temp\arduino-sketch-B29C806AC49F5D902D32D495E5618338\sketch\02.020_ESP32_IoT_Gadget_ArduinoIDE.ino.cpp" -o nul
Alternatives for FS.h: [FS@1.0]
ResolveLibrary(FS.h)
-> candidates: [FS@1.0]
"C:\Users\davis\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\FS\src" "C:\Users\davis\AppData\Local\Temp\arduino-sketch-B29C806AC49F5D902D32D495E5618338\sketch\02.020_ESP32_IoT_Gadget_ArduinoIDE.ino.cpp" -o nul
Alternatives for Adafruit_Sensor.h: [Adafruit_Unified_Sensor@1.1.4]
ResolveLibrary(Adafruit_Sensor.h)
-> candidates: [Adafruit_Unified_Sensor@1.1.4]
"C:\Users\davis\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\FS\src" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "C:\Users\davis\AppData\Local\Temp\arduino-sketch-B29C806AC49F5D902D32D495E5618338\sketch\02.020_ESP32_IoT_Gadget_ArduinoIDE.ino.cpp" -o nul
Alternatives for Adafruit_BME280.h: [Adafruit_BME280_Library@2.1.4]
ResolveLibrary(Adafruit_BME280.h)
-> candidates: [Adafruit_BME280_Library@2.1.4]
"C:\Users\davis\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\FS\src" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_BME280_Library" "C:\Users\davis\AppData\Local\Temp\arduino-sketch-B29C806AC49F5D902D32D495E5618338\sketch\02.020_ESP32_IoT_Gadget_ArduinoIDE.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\Users\davis\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\FS\src" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_BME280_Library" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\SPI\src" "C:\Users\davis\AppData\Local\Temp\arduino-sketch-B29C806AC49F5D902D32D495E5618338\sketch\02.020_ESP32_IoT_Gadget_ArduinoIDE.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0.1]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0.1]
"C:\Users\davis\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\FS\src" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_BME280_Library" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\SPI\src" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\Wire\src" "C:\Users\davis\AppData\Local\Temp\arduino-sketch-B29C806AC49F5D902D32D495E5618338\sketch\02.020_ESP32_IoT_Gadget_ArduinoIDE.ino.cpp" -o nul
Alternatives for TFT_eSPI.h: [TFT_eSPI@2.3.70]
ResolveLibrary(TFT_eSPI.h)
-> candidates: [TFT_eSPI@2.3.70]
"C:\Users\davis\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\FS\src" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_BME280_Library" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\SPI\src" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\Wire\src" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\TFT_eSPI" "C:\Users\davis\AppData\Local\Temp\arduino-sketch-B29C806AC49F5D902D32D495E5618338\sketch\02.020_ESP32_IoT_Gadget_ArduinoIDE.ino.cpp" -o nul
Alternatives for SPIFFS.h: [SPIFFS@1.0]
ResolveLibrary(SPIFFS.h)
-> candidates: [SPIFFS@1.0]
"C:\Users\davis\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\FS\src" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_BME280_Library" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\SPI\src" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\Wire\src" "-Ic:\Users\davis\OneDrive\Documents\Arduino\libraries\TFT_eSPI" "-IC:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\SPIFFS\src" "C:\Users\davis\AppData\Local\Temp\arduino-sketch-B29C806AC49F5D902D32D495E5618338\sketch\02.020_ESP32_IoT_Gadget_ArduinoIDE.ino.cpp" -o nul
Alternatives for TaskScheduler.h: []
ResolveLibrary(TaskScheduler.h)
-> candidates: []
Using library FS at version 1.0 in folder: C:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\FS
Using library Adafruit_Unified_Sensor at version 1.1.4 in folder: c:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_Unified_Sensor
Using library Adafruit_BME280_Library at version 2.1.4 in folder: c:\Users\davis\OneDrive\Documents\Arduino\libraries\Adafruit_BME280_Library
Using library SPI at version 1.0 in folder: C:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\SPI
Using library Wire at version 1.0.1 in folder: C:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\Wire
Using library TFT_eSPI at version 2.3.70 in folder: c:\Users\davis\OneDrive\Documents\Arduino\libraries\TFT_eSPI
Using library SPIFFS at version 1.0 in folder: C:\Users\davis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\SPIFFS
Compilation error: Error: 2 UNKNOWN: exit status 1
pert
May 31, 2021, 9:41pm
4
OK, that was very helpful.
It may not look like it, but this is the cause of the error:
-> candidates: []
This is telling you, in a cryptic manner, that your program had an #include directive for the file TaskScheduler.h and the IDE was not able to find any library that provides a file of that name.
So you'll need to install the library. I see there is a library of that name in the Arduino Library Manager. If that's the one your sketch was written for, then it can be installed easily:
Select Sketch > Include Library > Manage Libraries... from the Arduino IDE's menus.
In the "Filter your search" field, type the library name.
You should now see "TaskScheduler by Anatoli Arkhipenko" listed in the library search results. Click on it.
Click the INSTALL button. The library will now be installed.
You may now get a dialog asking you:
Would you like to install also all the missing dependencies?
If so, click the Install all button.
Wait for the installation to finish.
Click the Close button.
I'll add some information about the, in my opinion, poor user experience currently provided by the IDE in this common situation where a library dependency of the sketch has not been installed.
In the classic IDE, you would have also gotten a more intuitive and familiar error message like this:
fatal error: TaskScheduler.h: No such file or directory
#include <TaskScheduler.h>
compilation terminated.
exit status 1
This issue is being tracked here:
opened 08:22PM - 20 Mar 21 UTC
closed 02:53PM - 20 Oct 21 UTC
conclusion: resolved
topic: code
type: imperfection
The STDERR output from arduino-cli is not shown in the Output panel during compi… lation, even when the "Verbose" setting is enabled in the IDE preferences.
This has the effect of suppressing useful troubleshooting information. For instance:
```bash
% arduino-cli compile -b arduino:samd:mkrwifi1010
In file included from /Users/alranel/Documents/Arduino/OplaWidgets/OplaWidgets.ino:2:0:
/Users/alranel/Documents/Arduino/libraries/OplaUI/src/Arduino_OplaUI.h:5:10: fatal error: widget_direct.h: No such file or directory
#include "widget_direct.h"
Multiple libraries were found for "SD.h"
Used: /Users/alranel/Documents/Arduino/libraries/SD
Not used: /Applications/Arduino.app/Contents/Java/libraries/SD
Error during build: exit status 1
When suppressing STDERR from the same command, it becomes pretty useless:
```bash
% arduino-cli compile -b arduino:samd:mkrwifi1010 2> /dev/null
This is how it is displayed in the IDE, leaving user with no clue about the compilation error (it ends with "Compilation error: Error: 2 UNKNOWN: exit status 1").
I don't know if including STDERR in the output panel in the IDE is the proper solution. For sure it's a workaround. Maybe the correct solution is to have arduino-cli print that kind of output to STDOUT instead? Proper STDOUT/STDERR semantics should be designed.
### Version
2.0.0 beta4
I am having the same problem. Here is the compilation output
Using board 'uno' from platform in folder: /home/peterm/.arduino15/packages/arduino/hardware/avr/1.8.3
Using core 'arduino' from platform in folder: /home/peterm/.arduino15/packages/arduino/hardware/avr/1.8.3
Detecting libraries used...
/home/peterm/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/peterm/.arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino -I/home/peterm/.arduino15/packages/arduino/hardware/avr/1.8.3/variants/standard /tmp/arduino-sketch-5CC6420A27FEB15F82F29C2843E4A4FF/sketch/Servo-sweep.ino.cpp -o /dev/null
Alternatives for Servo.h: []
ResolveLibrary(Servo.h)
-> candidates: []
I have deleted the .Arduino15 folders when I first had difficulties. I tried to remove everything associated with the old version, except the libraries Folder. I am a bit stuck because I think I am beyond the point of going back. This sweep program is one of the demo programs available.
Thanks for any help.
I am working on Kubuntu Linux vn 20.04
.arduino15 folders have been recreated I notice.
pert
June 22, 2021, 7:04pm
6
Hi @peterm7 . It's the same issue as above. This error happens when you don't have the library installed. In this case the Servo library is missing.
This might be a little confusing because we are accustomed to the Servo library always being installed due to it coming bundled with the classic Arduino IDE installation. But the beta development phase Arduino IDE 2.x does not currently come with any bundled libraries, so you must install any library required by your sketch.
Fortunately, Library Manager makes this very easy. You can install the Servo library by following these instructions:
Wait for the update to finish.
In the "Filter your search" field, type servo.
Scroll down through the list of libraries until you see "Servo by Michael Margolis, Arduino". Click on it.
You may now get a dialog asking:
You should now be able to compile your sketch without getting this error.
Thanks for that legitimate way of doing it. I ended up doing a search for 'Arduino Servo Library' and finding it on Github. I downloaded it and extracted it to a folder in my libraries folder, and then the program found it and compiled successfully. I used 'Servo-Master' and it was by M. Margolis, so I guess I got lucky and got the right one. I'll follow your instructions when i test some of my other programs.
Interesting that you say that libraries are not installed by default in v2, but were in v1.5. I have a folder for libraries and I added this servo one to it just because it was my folder for libraries.
Thanks,
Peter M.
system
Closed
October 20, 2021, 9:11pm
8
