Compilation error
Hi all, I'm having a problem compiling the code below for a MKF wifi 1010. This code did work and compile, but now I get the following error below. I'm a bit confused as I don't have #include "wifi.h"
in the code? This happens on both my Mac and MacBook, but if I pull the sketch onto my windows 10 pc it works perfectly? I do have ESP32 sketches I'm working on in my cloud account that use this library. Any help or pointers would be appreciated.
In file included from /Users/steves/Library/Arduino15/RemoteSketchbook/ArduinoCloud/bcb5ccf2-2dda-472c-a448-6a408a893a0d/Hornet_detect_current_version/Hornet_detect_current_version.ino:10:0:
/Users/steves/Documents/Arduino/libraries/WiFiNINA/src/WiFiNINA.h:23:10: fatal error: WiFi.h: No such file or directory
#include "WiFi.h"
compilation terminated.
exit status 1
Compilation error: exit status 1
this is the code:
#include "arduino_secrets.h"
/*Hornet_detect
This is the project code for use with an Arduino MKR wifi 1010 and ESP32 CAM to create an Asian Hornet
detector
#include "ArduinoLowPower.h"
#include <WiFiNINA.h>
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;        // your network password (use for WPA, or use as key for WEP)
int wifistatus = WL_IDLE_STATUS;  // the Wifi radio's status
int DaylightPin = 8;         //Interrupt pin taking a high to low from photoresistor
int BandpassControl = 1;     //pin to switch on/off BP filter
int IRDetectControl = 2;     //output pin to control IR detector
int IRDetectOutput = 3;      //Pin to receive HIGH/LOW output from IR detector
int ESP32CAMControl = 4;     //output pin to control CAM module
int Detect115hzPin = 7;      //input for pulse output of BP filter
int HornetFrequency = 0;     // Variable to store frequency of Hornet
int countUp = 0;             // counter for 115hz detector
int durationTotal = 0;       // Variable to store both HIGH and LOW pulse widths
unsigned long durationHigh;  // Pulse HIGH variable
unsigned long durationLow;   // Pulse LOW variable
  // initialize serial communication at 9600 bits per second
  while (!Serial)
    ;                                  //program won't run until the serial port is connected
  pinMode(DaylightPin, INPUT_PULLUP);  // configures interrupt pin 8 as input for photoresistor output
  pinMode(BandpassControl, OUTPUT);    //sets pin 1 to an output to turn on BP filter & Mic
    //pinmode(115hzDetect,INPUT);  // sets pin 7 as input for reading the pulse length of the signal from the BP filter
  pinMode(IRDetectControl, OUTPUT);  // sets pin 2 to output pin to control the IR sensor
  pinMode(IRDetectOutput, INPUT);    //sets pin 3 as input for the IR module detect signal
  pinMode(ESP32CAMControl, OUTPUT);  //sets pin 4 as deepsleep/wake control for CAM module
  pinMode(Detect115hzPin, INPUT);    // Sets pin 7 as 115hz pulse input
                                     //This interrupt is waiting for a change from HIGH to LOW from photoresistor, then calls Wakeup:
  LowPower.attachInterruptWakeup(DaylightPin, Wakeup, FALLING);
void loop() {  // Need some code here to detect whether it is daylight or not.  If night then goto
               // BoardSleep and if dayligjht goto TurnOnWifi
  Serial.println("Starting program");
  if (digitalRead(DaylightPin) == LOW) {  // LOW from Photoresistor = Daylight
    Serial.println("Turning on BP filter");
    delay(3000);
    digitalWrite(BandpassControl, HIGH);  //Turn on BP filter via MOSFET
    goto Detect115hz;
  } else
BoardSleep:
  if (wifistatus == WL_CONNECTED) {
    WiFi.disconnect();
    Serial.println("Disconnecting WiFi");
    delay(2000);
TurnOffModules:
  Serial.println("Turning off WiFi module");
  delay(2000);
  WiFi.end();                          //Turn off WiFi module
  digitalWrite(IRDetectControl, LOW);  //Turn off IR detector
  Serial.println("Turning off IR detector");
  delay(2000);
  digitalWrite(ESP32CAMControl, LOW);  //ESP32 CAM module deepsleep
  Serial.println("Putting ESP32 CAM into deepsleep");
  delay(2000);
  digitalWrite(BandpassControl, LOW);  // Turns off BP filter + Mic
  Serial.println("Turning off BP filter");
  delay(2000);
  // put board to sleep
  Serial.println("Board asleep");
  LowPower.deepSleep();
  // turn on BP filter and Microphone on wake up then goto Detect115hz
  delay(2000);
Detect115hz:
  // Hornet tone detection code.  If hornet tone is detected the first time for more than 2 seconds
  // then turn on all modules and connect wifi.  When Wifi & modules are switched on then go direct to
  // IRDetect
  Serial.println("Waiting for Hornets...");
  countUp = 1;
  //delay(1000);
Detect115hzStart:
  if (countUp == 10) {
    goto TurnOnWiFi;
  } else
    durationHigh = pulseIn(Detect115hzPin, HIGH);
  durationLow = pulseIn(Detect115hzPin, LOW);
  durationTotal = durationHigh + durationLow;
  HornetFrequency = 1000000 / durationTotal;
  //if (durationTotal == 0) {
  if (HornetFrequency < 104 || HornetFrequency > 126) {
    countUp = 1;
    goto Detect115hzStart;
  } else
    //HornetFrequency = 1000000 / durationTotal;
    if (HornetFrequency > 104 && HornetFrequency < 126) {
      Serial.print(HornetFrequency);
      Serial.print("  ");
      Serial.println(countUp);
      delay(200);
      countUp++;
      //Serial.println(countUp);
    } else
TurnOnWiFi:
    goto IRDetect;
  } else
    //Serial.println("Turning on wifi module");
    //while (wifistatus != WL_CONNECTED) { // attempt to connect to Wifi network
  delay(2000);
  Serial.print("Attempting to connect to network: ");
  Serial.println(ssid);
  while (wifistatus != WL_CONNECTED) {    //Loop until connected to Wifi network
    wifistatus = WiFi.begin(ssid, pass);  // Connect to WPA/WPA2 network:
      Serial.println("WiFi Connected");
    } else
      Serial.println("WiFi not connected");
    //delay(10000);
  delay(2000);
  Serial.println("Turning on IR detector");
  digitalWrite(IRDetectControl, HIGH);  //Turn on IR detector
  delay(2000);
  Serial.println("Turning on CAM module");
  digitalWrite(ESP32CAMControl, HIGH);  //Turn on CAM module
  delay(2000);
IRDetect:  //Hornet LOS detect to activate Trigger for CAM module only when there is a stable 2 second
           //115hz hornet tone and a IR detection signal.
  Serial.println("Waiting for IR detection");
StartIRDetect:
  if (digitalRead(IRDetectOutput) == HIGH) {
    goto Trigger;
  } else
    goto StartIRDetect;
Trigger:  //This will be where the CAM module is triggered to take a picture
  Serial.println("Trap triggered!");
  if (digitalRead(DaylightPin) == HIGH) {  // Would normally be HIGH with low light and
                                           // LOW with day light but is LOW for test purposes
    delay(2000);
    goto BoardSleep;
  } else
  digitalWrite(BandpassControl, HIGH);  // Turns on BP filter + Mic
  goto Detect115hz;                     //Detect115hzStart;
// This function will be called once on device wakeup
// Remeber this function(s) executes in interrupt context not in the main loop
void Wakeup() {
  Serial.println("Board awake");
The error probably says this file (WiFiNINA.h) contains a line #include<WiFi.h> but WiFi.h is not in your IDE "libraries" folder(s). Add WiFi.h to your IDE.
