Compilation fails with "multiple definition of ..." errors
Continuing the discussion from Arduino 2.2.1 reports ping timeout:
Hello @ptillisch, I also experienced the ping timeout after integrating these two libraries #include <Firebase_ESP_Client.h> #include <ESP_Mail_Client.h>. Actually the two libraries works perfectly ok on different sketches before merging them.
Then after trying many approaches which turned out to be abortive, I updated the ESP32 board to the latest version i.e. 3.0.2. But this time, I got different error messages.
Here's the Compilation error: exit status 1 on the output on the screen
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1718: multiple definition of `BSSL_SSL_Client::mUpdateEngine()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1718: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::available()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:208: multiple definition of `BSSL_SSL_Client::available()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:208: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mRunUntil(unsigned int, unsigned long)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1607: multiple definition of `BSSL_SSL_Client::mRunUntil(unsigned int, unsigned long)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1607: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::write(unsigned char const*, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:275: multiple definition of `BSSL_SSL_Client::write(unsigned char const*, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:275: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::flush()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:501: multiple definition of `BSSL_SSL_Client::flush()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:501: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::availableForWrite()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:542: multiple definition of `BSSL_SSL_Client::availableForWrite()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:542: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mPrintClientError(int, int, char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1875: multiple definition of `BSSL_SSL_Client::mPrintClientError(int, int, char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1875: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mPrintSSLError(unsigned int, int, char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1906: multiple definition of `BSSL_SSL_Client::mPrintSSLError(unsigned int, int, char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1906: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mPrintSSLState(unsigned int, int, char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1915: multiple definition of `BSSL_SSL_Client::mPrintSSLState(unsigned int, int, char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1915: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mIsSecurePort(unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1940: multiple definition of `BSSL_SSL_Client::mIsSecurePort(unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1940: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mBSSLX509InsecureInit(bssl::br_x509_insecure_context*, int, unsigned char const*, int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1952: multiple definition of `BSSL_SSL_Client::mBSSLX509InsecureInit(bssl::br_x509_insecure_context*, int, unsigned char const*, int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1952: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mClearAuthenticationSettings()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1970: multiple definition of `BSSL_SSL_Client::mClearAuthenticationSettings()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1970: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::setInsecure()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:422: multiple definition of `BSSL_SSL_Client::setInsecure()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:422: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::setKnownKey(bssl::PublicKey const*, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:573: multiple definition of `BSSL_SSL_Client::setKnownKey(bssl::PublicKey const*, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:573: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::setFingerprint(unsigned char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:581: multiple definition of `BSSL_SSL_Client::setFingerprint(unsigned char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:581: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::setFingerprint(char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:590: multiple definition of `BSSL_SSL_Client::setFingerprint(char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:590: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::allowSelfSignedCerts()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:639: multiple definition of `BSSL_SSL_Client::allowSelfSignedCerts()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:639: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::setTrustAnchors(bssl::X509List const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:646: multiple definition of `BSSL_SSL_Client::setTrustAnchors(bssl::X509List const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:646: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mStreamLoad(Stream&, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:2125: multiple definition of `BSSL_SSL_Client::mStreamLoad(Stream&, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:2125: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::freeImpl(void*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:2180: multiple definition of `BSSL_SSL_Client::freeImpl(void*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:2180: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::getReservedLen(unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:2190: multiple definition of `BSSL_SSL_Client::getReservedLen(unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:2190: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mallocImpl(unsigned int, bool)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:2143: multiple definition of `BSSL_SSL_Client::mallocImpl(unsigned int, bool)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:2143: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::setCiphers(unsigned short const*, int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:933: multiple definition of `BSSL_SSL_Client::setCiphers(unsigned short const*, int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:933: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::setCiphersLessSecure()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:953: multiple definition of `BSSL_SSL_Client::setCiphersLessSecure()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:953: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::setCiphers(std::vector<unsigned short, std::allocator<unsigned short> > const&)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:948: multiple definition of `BSSL_SSL_Client::setCiphers(std::vector<unsigned short, std::allocator<unsigned short> > const&)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:948: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::loadCACert(Stream&, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1037: multiple definition of `BSSL_SSL_Client::loadCACert(Stream&, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1037: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::loadCertificate(Stream&, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1050: multiple definition of `BSSL_SSL_Client::loadCertificate(Stream&, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1050: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::loadPrivateKey(Stream&, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1063: multiple definition of `BSSL_SSL_Client::loadPrivateKey(Stream&, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1063: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mProbeMaxFragmentLength(Client*, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1137: multiple definition of `BSSL_SSL_Client::mProbeMaxFragmentLength(Client*, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1137: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mProbeMaxFragmentLength(char const*, IPAddress, unsigned short, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1359: multiple definition of `BSSL_SSL_Client::mProbeMaxFragmentLength(char const*, IPAddress, unsigned short, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1359: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::probeMaxFragmentLength(IPAddress, unsigned short, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:980: multiple definition of `BSSL_SSL_Client::probeMaxFragmentLength(IPAddress, unsigned short, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:980: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::probeMaxFragmentLength(char const*, unsigned short, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:985: multiple definition of `BSSL_SSL_Client::probeMaxFragmentLength(char const*, unsigned short, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:985: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::probeMaxFragmentLength(String const&, unsigned short, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:990: multiple definition of `BSSL_SSL_Client::probeMaxFragmentLength(String const&, unsigned short, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:990: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mClear()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1984: multiple definition of `BSSL_SSL_Client::mClear()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1984: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::BSSL_SSL_Client(Client*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:84: multiple definition of `BSSL_SSL_Client::BSSL_SSL_Client(Client*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:84: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mFreeSSL()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:2106: multiple definition of `BSSL_SSL_Client::mFreeSSL()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:2106: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::stop()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:463: multiple definition of `BSSL_SSL_Client::stop()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:463: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::~BSSL_SSL_Client()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:98: multiple definition of `BSSL_SSL_Client::~BSSL_SSL_Client()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:98: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mConnectBasicClient(char const*, IPAddress, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1392: multiple definition of `BSSL_SSL_Client::mConnectBasicClient(char const*, IPAddress, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1392: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mInstallClientX509Validator()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:2016: multiple definition of `BSSL_SSL_Client::mInstallClientX509Validator()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:2016: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::mConnectSSL(char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:1441: multiple definition of `BSSL_SSL_Client::mConnectSSL(char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:1441: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::connectSSL(IPAddress, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:433: multiple definition of `BSSL_SSL_Client::connectSSL(IPAddress, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:433: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::connect(IPAddress, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:128: multiple definition of `BSSL_SSL_Client::connect(IPAddress, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:128: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::connectSSL(char const*, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:448: multiple definition of `BSSL_SSL_Client::connectSSL(char const*, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:448: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o): in function `BSSL_SSL_Client::connect(char const*, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_SSL_Client.cpp:139: multiple definition of `BSSL_SSL_Client::connect(char const*, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_SSL_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_SSL_Client.cpp:139: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::read()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:153: multiple definition of `BSSL_TCP_Client::read()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:153: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::write(unsigned char)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:225: multiple definition of `BSSL_TCP_Client::write(unsigned char)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:225: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::flush()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:284: multiple definition of `BSSL_TCP_Client::flush()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:284: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setClient(Client*, bool)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:80: multiple definition of `BSSL_TCP_Client::setClient(Client*, bool)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:80: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setDebugLevel(int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:86: multiple definition of `BSSL_TCP_Client::setDebugLevel(int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:86: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::validate(char const*, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:138: multiple definition of `BSSL_TCP_Client::validate(char const*, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:138: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::validate(IPAddress, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:143: multiple definition of `BSSL_TCP_Client::validate(IPAddress, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:143: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::send(char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:169: multiple definition of `BSSL_TCP_Client::send(char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:169: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::print(char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:174: multiple definition of `BSSL_TCP_Client::print(char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:174: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::print(String const&)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:179: multiple definition of `BSSL_TCP_Client::print(String const&)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:179: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::print(int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:184: multiple definition of `BSSL_TCP_Client::print(int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:184: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::println(char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:193: multiple definition of `BSSL_TCP_Client::println(char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:193: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::println(String const&)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:204: multiple definition of `BSSL_TCP_Client::println(String const&)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:204: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::println(int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:209: multiple definition of `BSSL_TCP_Client::println(int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:209: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::write_P(char const*, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:229: multiple definition of `BSSL_TCP_Client::write_P(char const*, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:229: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::write(char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:231: multiple definition of `BSSL_TCP_Client::write(char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:231: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::write(Stream&)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:233: multiple definition of `BSSL_TCP_Client::write(Stream&)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:233: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setInsecure()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:241: multiple definition of `BSSL_TCP_Client::setInsecure()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:241: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::enableSSL(bool)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:247: multiple definition of `BSSL_TCP_Client::enableSSL(bool)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:247: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::connectSSL()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:252: multiple definition of `BSSL_TCP_Client::connectSSL()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:252: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::connectSSL(String, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:261: multiple definition of `BSSL_TCP_Client::connectSSL(String, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:261: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setTimeout(unsigned long)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:269: multiple definition of `BSSL_TCP_Client::setTimeout(unsigned long)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:269: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::getTimeout()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:275: multiple definition of `BSSL_TCP_Client::getTimeout()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:275: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setHandshakeTimeout(unsigned long)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:278: multiple definition of `BSSL_TCP_Client::setHandshakeTimeout(unsigned long)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:278: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setBufferSizes(int, int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:293: multiple definition of `BSSL_TCP_Client::setBufferSizes(int, int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:293: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setSession(BearSSL_Session*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:299: multiple definition of `BSSL_TCP_Client::setSession(BearSSL_Session*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:299: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setKnownKey(bssl::PublicKey const*, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:302: multiple definition of `BSSL_TCP_Client::setKnownKey(bssl::PublicKey const*, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:302: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setFingerprint(unsigned char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:307: multiple definition of `BSSL_TCP_Client::setFingerprint(unsigned char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:307: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setFingerprint(char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:312: multiple definition of `BSSL_TCP_Client::setFingerprint(char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:312: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::allowSelfSignedCerts()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:317: multiple definition of `BSSL_TCP_Client::allowSelfSignedCerts()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:317: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setTrustAnchors(bssl::X509List const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:322: multiple definition of `BSSL_TCP_Client::setTrustAnchors(bssl::X509List const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:322: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setX509Time(long long)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:327: multiple definition of `BSSL_TCP_Client::setX509Time(long long)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:327: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setClientRSACert(bssl::X509List const*, bssl::PrivateKey const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:332: multiple definition of `BSSL_TCP_Client::setClientRSACert(bssl::X509List const*, bssl::PrivateKey const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:332: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setClientECCert(bssl::X509List const*, bssl::PrivateKey const*, unsigned int, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:337: multiple definition of `BSSL_TCP_Client::setClientECCert(bssl::X509List const*, bssl::PrivateKey const*, unsigned int, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:337: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::getMFLNStatus()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:341: multiple definition of `BSSL_TCP_Client::getMFLNStatus()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:341: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::getLastSSLError(char*, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:344: multiple definition of `BSSL_TCP_Client::getLastSSLError(char*, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:344: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setCertStore(bssl::CertStoreBase*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:350: multiple definition of `BSSL_TCP_Client::setCertStore(bssl::CertStoreBase*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:350: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setCiphers(unsigned short const*, int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:356: multiple definition of `BSSL_TCP_Client::setCiphers(unsigned short const*, int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:356: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setCiphers(std::vector<unsigned short, std::allocator<unsigned short> > const&)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:361: multiple definition of `BSSL_TCP_Client::setCiphers(std::vector<unsigned short, std::allocator<unsigned short> > const&)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:361: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setCiphersLessSecure()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:366: multiple definition of `BSSL_TCP_Client::setCiphersLessSecure()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:366: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setSSLVersion(unsigned long, unsigned long)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:371: multiple definition of `BSSL_TCP_Client::setSSLVersion(unsigned long, unsigned long)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:371: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::probeMaxFragmentLength(IPAddress, unsigned short, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:375: multiple definition of `BSSL_TCP_Client::probeMaxFragmentLength(IPAddress, unsigned short, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:375: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::probeMaxFragmentLength(char const*, unsigned short, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:377: multiple definition of `BSSL_TCP_Client::probeMaxFragmentLength(char const*, unsigned short, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:377: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::probeMaxFragmentLength(String const&, unsigned short, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:379: multiple definition of `BSSL_TCP_Client::probeMaxFragmentLength(String const&, unsigned short, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:379: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::hasPeekBufferAPI() const':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:382: multiple definition of `BSSL_TCP_Client::hasPeekBufferAPI() const'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:382: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::peekAvailable()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:385: multiple definition of `BSSL_TCP_Client::peekAvailable()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:385: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::peekBuffer()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:389: multiple definition of `BSSL_TCP_Client::peekBuffer()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:389: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::peekConsume(unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:392: multiple definition of `BSSL_TCP_Client::peekConsume(unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:392: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setCACert(char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:395: multiple definition of `BSSL_TCP_Client::setCACert(char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:395: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setCertificate(char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:399: multiple definition of `BSSL_TCP_Client::setCertificate(char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:399: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::setPrivateKey(char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:401: multiple definition of `BSSL_TCP_Client::setPrivateKey(char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:401: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::loadCertificate(Stream&, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:415: multiple definition of `BSSL_TCP_Client::loadCertificate(Stream&, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:415: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::loadPrivateKey(Stream&, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:417: multiple definition of `BSSL_TCP_Client::loadPrivateKey(Stream&, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:417: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::connect(IPAddress, unsigned short, char const*, char const*, char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:419: multiple definition of `BSSL_TCP_Client::connect(IPAddress, unsigned short, char const*, char const*, char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:419: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::connect(char const*, unsigned short, char const*, char const*, char const*)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:421: multiple definition of `BSSL_TCP_Client::connect(char const*, unsigned short, char const*, char const*, char const*)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:421: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::operator=(BSSL_TCP_Client const&)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:424: multiple definition of `BSSL_TCP_Client::operator=(BSSL_TCP_Client const&)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:424: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::mStreamLoad(Stream&, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:438: multiple definition of `BSSL_TCP_Client::mStreamLoad(Stream&, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:438: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::loadCACert(Stream&, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:404: multiple definition of `BSSL_TCP_Client::loadCACert(Stream&, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:404: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::operator==(BSSL_TCP_Client const&)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:455: multiple definition of `BSSL_TCP_Client::operator==(BSSL_TCP_Client const&)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:455: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::BSSL_TCP_Client()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:66: multiple definition of `BSSL_TCP_Client::BSSL_TCP_Client()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:66: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::connect(IPAddress, unsigned short, long)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:96: multiple definition of `BSSL_TCP_Client::connect(IPAddress, unsigned short, long)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:96: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::connect(IPAddress, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:91: multiple definition of `BSSL_TCP_Client::connect(IPAddress, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:91: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::connect(char const*, unsigned short, long)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:116: multiple definition of `BSSL_TCP_Client::connect(char const*, unsigned short, long)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:116: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::connect(char const*, unsigned short)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:111: multiple definition of `BSSL_TCP_Client::connect(char const*, unsigned short)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:111: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::connected()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:133: multiple definition of `BSSL_TCP_Client::connected()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:133: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::available()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:148: multiple definition of `BSSL_TCP_Client::available()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:148: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::read(unsigned char*, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:162: multiple definition of `BSSL_TCP_Client::read(unsigned char*, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:162: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::write(unsigned char const*, unsigned int)':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:218: multiple definition of `BSSL_TCP_Client::write(unsigned char const*, unsigned int)'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:218: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::peek()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:236: multiple definition of `BSSL_TCP_Client::peek()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:236: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::stop()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:264: multiple definition of `BSSL_TCP_Client::stop()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:264: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::~BSSL_TCP_Client()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:73: multiple definition of `BSSL_TCP_Client::~BSSL_TCP_Client()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:73: first defined here
c:/users/dell/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\ESP_Mail_Client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o): in function `BSSL_TCP_Client::availableForWrite()':
c:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client\src\SSLClient\client/BSSL_TCP_Client.cpp:297: multiple definition of `BSSL_TCP_Client::availableForWrite()'; C:\Users\Dell\AppData\Local\Temp\arduino\sketches\59294B48863C5950C038244F378DDD6E\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:297: first defined here
collect2.exe: error: ld returned 1 exit status
Using library WiFi at version 2.0.0 in folder: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi
Using library Networking at version 1.0.0 in folder: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network
Using library Firebase Arduino Client Library for ESP8266 and ESP32 at version 4.4.14 in folder: C:\Users\Dell\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32
Using library LittleFS at version 2.0.0 in folder: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\LittleFS
Using library FS at version 2.0.0 in folder: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\FS
Using library SD at version 2.0.0 in folder: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\SD
Using library SPI at version 2.0.0 in folder: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\SPI
Using library Update at version 2.0.0 in folder: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Update
Using library ESP Mail Client at version 3.4.15 in folder: C:\Users\Dell\Documents\Arduino\libraries\ESP_Mail_Client
Using library WiFiManager at version 2.0.16-rc.2 in folder: C:\Users\Dell\Documents\Arduino\libraries\WiFiManager
Using library WebServer at version 2.0.0 in folder: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WebServer
Using library DNSServer at version 2.0.0 in folder: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\DNSServer
Using library ESP32 Async UDP at version 2.0.0 in folder: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\AsyncUDP
exit status 1
Compilation error: exit status 1
It'll be nice if you can help check this problem. Thank you
Hi @electricalman. There is guidance from the author of the libraries for solving this conflict between the libraries here:
It seems the first thing you should do is update the "ESP Mail Client" library from the outdated version 3.4.15 you have installed now:
https://github.com/mobizt/ESP-Mail-Client/issues/322#issuecomment-1972351132
Please update both libraries.
You can use the Arduino IDE Library Manager to do that. I gave the fix a try with the latest version (3.4.19) and it worked as expected for me.
After that, you will need to modify one of the libraries:
https://github.com/mobizt/ESP-Mail-Client/issues/322#issuecomment-1974255793
If you include Firebase library before Email library.
#include <Firebase_ESP_Client.h>
#include <ESP_Mail_Client.h>
You have to delete folder SSLClient in ESP_Mail_Client/src/client.
In other hand, if you include Email library before Firebase library.
You have to delete folder SSLClient in Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32/src/client.
If you don't know where to find that SSLClient folder, let us know and we'll provide instructions.
After doing that, try compiling your sketch again. Hopefully this time it will compile without any errors and work as expected.
Note that the modification you made to the library will be lost if a new release of the library comes out in the future and you use Arduino Library Manager to update. It might be that the library author will have fixed the incompatibility by then. If not, you can simply repeat the modification process after updating the library.
Thanks for the tips. But I'm encountering brand new error now.
Global variables use 51892 bytes (15%) of dynamic memory, leaving 275788 bytes for local variables. Maximum is 327680 bytes.
Sketch too big; see https://support.arduino.cc/hc/en-us/articles/360013825179 for tips on reducing it.
text section exceeds available space in board
Compilation error: text section exceeds available space in board
Here's my whole code
#include <Arduino.h>
#if defined(ESP32)
  #include <WiFi.h>
#elif defined(ESP8266)
  #include <ESP8266WiFi.h>
#endif
#include <WiFiManager.h>
// Provide the token generation process info.
#include "addons/TokenHelper.h"
// Provide the RTDB payload printing info and other helper functions.
#include "addons/RTDBHelper.h"
// Insert Firebase project API Key
#define API_KEY "*************"
// Insert RTDB URLefine the RTDB URL */
#define DATABASE_URL "*************"
// Insert Authorized Email and Corresponding Password
#define USER_EMAIL "*************"
#define USER_PASSWORD "*************"
/** The smtp host name e.g. smtp.gmail.com for GMail or smtp.office365.com for Outlook or smtp.mail.yahoo.com */
#define SMTP_HOST "smtp.gmail.com"
#define SMTP_PORT 465
/* The sign in credentials */
#define AUTHOR_EMAIL "*************"
#define AUTHOR_PASSWORD "*************"
/* Recipient's email*/
#define RECIPIENT_EMAIL "*************"
/* Declare the global used SMTPSession object for SMTP transport */
SMTPSession smtp;
/* Callback function to get the Email sending status */
void smtpCallback(SMTP_Status status);
// Define Firebase Data object
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
// Variable to save USER UID
String uid;
// Variables to save database paths
String databasePath;
String tempPath;
String tdsPath;
String pHPath;
float temperature;
float pH;
float tds;
// Timer variable to send reads
unsigned long sendDataPrevMillis = 0;
unsigned long myTimer = 60000;
void sendData(String path, float value){
  if (Firebase.RTDB.setFloat(&fbdo, path.c_str(), value)){
    Serial.print("Writing value: ");
    Serial.print (value);
    Serial.print(" on the following path: ");
    Serial.println(path);
    Serial.println("PASSED");
    Serial.println("PATH: " + fbdo.dataPath());
    Serial.println("TYPE: " + fbdo.dataType());
  else {
    Serial.println("FAILED");
    Serial.println("REASON: " + fbdo.errorReason());
  WiFiManager wm;
  bool res;
  // res = wm.autoConnect(); // auto generated AP name from chipid
  // res = wm.autoConnect("AutoConnectAP"); // anonymous ap
  res = wm.autoConnect("AutoConnectAP","password"); // password protected ap
  if(!res) {
    Serial.println("Failed to connect");
    // ESP.restart();
  else {
    //if you get here you have connected to the WiFi
    Serial.println("Yes! Connected:)");
  Serial.print("Connected with IP: ");
  // Assign the api key (required)
  config.api_key = API_KEY;
  // Assign the user sign in credentials
  auth.user.email = USER_EMAIL;
  auth.user.password = USER_PASSWORD;
  // Assign the RTDB URL (required)
  config.database_url = DATABASE_URL;
  Firebase.reconnectWiFi(true);
  fbdo.setResponseSize(4096);
  // Assign the callback function for the long running token generation task */
  config.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
  // Assign the maximum retry of token generation
  config.max_token_generation_retry = 5;
  // Initialize the library with the Firebase authen and config
  Firebase.begin(&config, &auth);
  // Getting the user UID might take a few seconds
  Serial.println("Getting User UID");
  while ((auth.token.uid) == "") {
    Serial.print('.');
  // Print user UID
  uid = auth.token.uid.c_str();
  Serial.print("User UID: ");
  Serial.println(uid);
  // Update database path
  databasePath = "/UsersData/" + uid;
  // Update database path for sensor readings
  tempPath = databasePath + "/temperature"; // --> UsersData/<user_uid>/temperature
  tdsPath = databasePath + "/humidity"; // --> UsersData/<user_uid>/humidity
  pHPath = databasePath + "/pressure"; // --> UsersData/<user_uid>/pressure
    /*  Set the network reconnection option */
  MailClient.networkReconnect(true);
  /** Enable the debug via Serial port
   * 0 for no debugging
   * 1 for basic level debugging
   * Debug port can be changed via ESP_MAIL_DEFAULT_DEBUG_PORT in ESP_Mail_FS.h
  smtp.debug(1);
  /* Set the callback function to get the sending results */
  smtp.callback(smtpCallback);
  /* Declare the Session_Config for user defined session credentials */
  Session_Config emailconfig;
  /* Set the session config */
  emailconfig.server.host_name = SMTP_HOST;
  emailconfig.server.port = SMTP_PORT;
  emailconfig.login.email = AUTHOR_EMAIL;
  emailconfig.login.password = AUTHOR_PASSWORD;
  emailconfig.login.user_domain = "";
  Set the NTP config time
  For times east of the Prime Meridian use 0-12
  For times west of the Prime Meridian add 12 to the offset.
  Ex. American/Denver GMT would be -6. 6 + 12 = 18
  See https://en.wikipedia.org/wiki/Time_zone for a list of the GMT/UTC timezone offsets
  emailconfig.time.ntp_server = F("pool.ntp.org,time.nist.gov");
  emailconfig.time.gmt_offset = 1;
  emailconfig.time.day_light_offset = 0;
  /* Declare the message class */
  SMTP_Message message;
  /* Set the message headers */
  message.sender.name = F("ESP32 CAM");
  message.sender.email = AUTHOR_EMAIL;
  message.subject = F("ESP Test Email");
  message.addRecipient(F("My Boss"), RECIPIENT_EMAIL);
  /*Send HTML message*/
  /*String htmlMsg = "<div style=\"color:#2f4468;\"><h1>Hello World!</h1><p>- Sent from ESP board</p></div>";
  message.html.content = htmlMsg.c_str();
  message.text.charSet = "us-ascii";
  message.html.transfer_encoding = Content_Transfer_Encoding::enc_7bit;*/
  //Send raw text message
  String textMsg = "Hello Boss, here is you IP address: " + WiFi.localIP().toString();
  message.text.content = textMsg.c_str();
  message.text.transfer_encoding = Content_Transfer_Encoding::enc_7bit;
  message.priority = esp_mail_smtp_priority::esp_mail_smtp_priority_low;
  message.response.notify = esp_mail_smtp_notify_success | esp_mail_smtp_notify_failure | esp_mail_smtp_notify_delay;
  /* Connect to the server */
  if (!smtp.connect(&emailconfig)){
    ESP_MAIL_PRINTF("Connection error, Status Code: %d, Error Code: %d, Reason: %s", smtp.statusCode(), smtp.errorCode(), smtp.errorReason().c_str());
    return;
  if (!smtp.isLoggedIn()){
    Serial.println("\nNot yet logged in.");
  else{
    if (smtp.isAuthenticated())
      Serial.println("\nSuccessfully logged in.");
      Serial.println("\nConnected with no Auth.");
  /* Start sending Email and close the session */
  if (!MailClient.sendMail(&smtp, &message))
    ESP_MAIL_PRINTF("Error, Status Code: %d, Error Code: %d, Reason: %s", smtp.statusCode(), smtp.errorCode(), smtp.errorReason().c_str());
  if (Firebase.ready() && (millis() - sendDataPrevMillis > myTimer || sendDataPrevMillis == 0)){
    sendDataPrevMillis = millis();
    // Write a random pH value on the database path test/ph
    temperature = random(0, 1401) / 100.0; // Random pH value between 0.00 and 14.00
    sendData(tempPath, temperature);
    // Write a random temperature value on the database path test/temperature
    pH = random(0, 10001) / 100.0; // Random temperature value between 0.00 and 100.00
    sendData(pHPath, pH);
    // Write a random TDS value on the database path test/tds
    tds= random(0, 20001) / 100.0; // Random TDS value between 0.00 and 200.00
    sendData(tdsPath, tds);
void smtpCallback(SMTP_Status status){
  /* Print the current status */
  Serial.println(status.info());
  /* Print the sending result */
  if (status.success()){
    // ESP_MAIL_PRINTF used in the examples is for format printing via debug Serial port
    // that works for all supported Arduino platform SDKs e.g. AVR, SAMD, ESP32 and ESP8266.
    // In ESP8266 and ESP32, you can use Serial.printf directly.
    Serial.println("----------------");
    ESP_MAIL_PRINTF("Message sent success: %d\n", status.completedCount());
    ESP_MAIL_PRINTF("Message sent failed: %d\n", status.failedCount());
    Serial.println("----------------\n");
    for (size_t i = 0; i < smtp.sendingResult.size(); i++)
      /* Get the result item */
      SMTP_Result result = smtp.sendingResult.getItem(i);
      // In case, ESP32, ESP8266 and SAMD device, the timestamp get from result.timestamp should be valid if
      // your device time was synched with NTP server.
      // Other devices may show invalid timestamp as the device time was not set i.e. it will show Jan 1, 1970.
      // You can call smtp.setSystemTime(xxx) to set device time manually. Where xxx is timestamp (seconds since Jan 1, 1970)
      ESP_MAIL_PRINTF("Message No: %d\n", i + 1);
      ESP_MAIL_PRINTF("Status: %s\n", result.completed ? "success" : "failed");
      ESP_MAIL_PRINTF("Date/Time: %s\n", MailClient.Time.getDateTimeString(result.timestamp, "%B %d, %Y %H:%M:%S").c_str());
      ESP_MAIL_PRINTF("Recipient: %s\n", result.recipients.c_str());
      ESP_MAIL_PRINTF("Subject: %s\n", result.subject.c_str());
    // You need to clear sending result as the memory usage will grow up.
    smtp.sendingResult.clear();
Please any help to get this fix.
This is actually progress even if it doesn't seem like it.
Please tell us which board you have selected from the Tools > Board menu in Arduino IDE.
DOIT ESP32 DEVKIT
While my hardware is ESP32 Wroom 32U
The ESP32 microcontroller uses an external flash memory chip instead of internal flash as is the case with other microcontrollers. The sketch program is stored on that flash chip. The "DOIT ESP32 DEVKIT V1" board has a 4 MB flash chip. However, not all that memory is available for storage of the sketch program. Instead, the total memory is split into multiple smaller partitions, and only one of the partitions used to store the sketch program.
The "DOIT ESP32 DEVKIT V1" board allocates a 1.2 MB partition for storage of the sketch program. The error you encountered indicates that your sketch is larger than 1.2 MB.
One solution would be to use a different partition scheme that allocates more space for the sketch program storage. The reason why only 1.2 MB out of 4 MB are available for the sketch storage are that space is reserved in order to allow for the flash memory required by other features. If you don't use those features, then you can use a different partition scheme that makes the flash currently unnecessarily reserved for the unused feature available for storage of the sketch.
One of these features is filesystem storage (AKA "SPIFFS" or "littlfs"). This storage can be used to store non-program data such as the HTML of a website that will be served by the ESP32 board. A 1.5 MB partition is reserved for filesystem storage.
The other feature is OTA ("over-the-air"), which allows you to upload sketches to the ESP32 board through the Wi-Fi network instead of through a USB connection. When you do an OTA upload, the uploaded sketch program must be stored in a dedicated partition, which will then be used to run the program after the successful completion of the upload. For this reason, the same amount of space must be reserved for the additional OTA partition as for the partition used for storage of the sketch program.
Unfortunately the "DOIT ESP32 DEVKIT V1" board developers did not provide an easy way for the user to configure it to use a different partition scheme. However, the developers of the "esp32" boards platform provide a general purpose "ESP32 Dev Module" board definition which can be used with any board based on an ESP32 microcontroller. That board definition gives you lots of configuration options.
So if you don't need to use filesystem storage for your project, you can select Tools > Board > esp32 > ESP32 Dev Module, then Tools > Partition Scheme > No FS 4MB (2MB APP x2) from the Arduino IDE menus. You will then have 2 MB available for storage of your sketch program.
If you don't need OTA upload capability, you can select Tools > Board > esp32 > ESP32 Dev Module, then Tools > Partition Scheme > Huge APP (3MB No OTA/1MB SPIFFS) from the Arduino IDE menus. Or if you need more space for filesystem storage, you can instead select Tools > Partition Scheme > No OTA (2MB APP/2MB SPIFFS).
I got my code complied successfully. It's a good thing to go through documentations.
Thanks so much.
You are welcome. I'm glad it is working now.
Regards,
Per
