I don’t know why I get this error.
/Users/dannyswarzman/Documents/Arduino/Test/Test.ino:24:5: error: request for member 'PP' in 'm', which is of non-class type 'MM()'
24 | m.PP();
exit status 1
Compilation error: request for member 'PP' in 'm', which is of non-class type 'MM()'
class MM
public:
MM(){}
void PP();
void MM::PP()
{Serial.println("MM");}
MM m();
#include <arduino.h>
while(!Serial)
delay(10);
Serial.println("Begin");
if(m)
Serial.println ("m is");
Serial.println("m isn't");
m.PP();
The error message is for the last line of setup().
sonofcy
October 25, 2025, 11:17pm
2
Show the verbose error log in code tags, there is often more information
When declaring the global m, omit the paranetheses.
#include <arduino.h> will fail on case sensitive OSes, and in any case is included too late to be able to use Serial in class MM.
Declaring m as a global variable means it's not a pointer. So testing if it's not NULL is not correct.
class MM {
public:
MM() {}
void PP();
void MM::PP() {
{ Serial.println("MM"); }
MM m;
while( !Serial )
delay(10);
m.PP();
or, if you're commited to the idea of testing m being non NULL, make it a pointer.
class MM {
public:
MM() {}
void PP();
void MM::PP() {
MM *m = new MM;
while( !Serial )
delay(10);
if( m )
Serial.println("m is");
m->PP();
