Hi I am trying to upload the code for the IR remote for my robot car project, and keep getting a compilation error. I have checked previous forums and various troubleshooting which suggested that it could be an issue with the libraries in the IDE, I have updated the correct library and deleted the old one and still have the same error, any help would be appreciated.
the programme code is:
//www.elegoo.com
#include <IRremote.h>
////////// IR REMOTE CODES //////////
#define F 16736925 // FORWARD
#define B 16754775 // BACK
#define L 16720605 // LEFT
#define R 16761405 // RIGHT
#define S 16712445 // STOP
#define UNKNOWN_F 5316027 // FORWARD
#define UNKNOWN_B 2747854299 // BACK
#define UNKNOWN_L 1386468383 // LEFT
#define UNKNOWN_R 553536955 // RIGHT
#define UNKNOWN_S 3622325019 // STOP
#define RECV_PIN 12
/*define channel enable output pins*/
#define ENA 5 // Left wheel speed
#define ENB 6 // Right wheel speed
/*define logic control output pins*/
#define IN1 7 // Left wheel forward
#define IN2 8 // Left wheel reverse
#define IN3 9 // Right wheel reverse
#define IN4 11 // Right wheel forward
#define carSpeed 150 // initial speed of car >=0 to <=255
IRrecv irrecv(RECV_PIN);
decode_results results;
unsigned long val;
unsigned long preMillis;
BEGIN DEFINE FUNCTIONS
void forward() {
digitalWrite(ENA, HIGH);
digitalWrite(ENB, HIGH);
digitalWrite(IN1, HIGH);
digitalWrite(IN2, LOW);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
Serial.println("go forward!");
void back() {
digitalWrite(IN1, LOW);
digitalWrite(IN2, HIGH);
digitalWrite(IN3, HIGH);
digitalWrite(IN4, LOW);
Serial.println("go back!");
void left() {
analogWrite(ENA, carSpeed);
analogWrite(ENB, carSpeed);
Serial.println("go left!");
void right() {
Serial.println("go right!");
void stop() {
digitalWrite(ENA, LOW);
digitalWrite(ENB, LOW);
Serial.println("STOP!");
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
stop();
irrecv.enableIRIn();
if (irrecv.decode(&results)) {
preMillis = millis();
val = results.value;
Serial.println(val);
irrecv.resume();
switch (val) {
case F:
case UNKNOWN_F: forward(); break;
case B:
case UNKNOWN_B: back(); break;
case L:
case UNKNOWN_L: left(); break;
case R:
case UNKNOWN_R: right(); break;
case S:
case UNKNOWN_S: stop(); break;
default: break;
else {
if (millis() - preMillis > 500) {
stop();
the error that this generates is:
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Archiving built core (caching) in: C:\Users\Sean\AppData\Local\Temp\arduino_cache_933322\core\core_arduino_avr_uno_d59d277d3c3890a80f233d5911011076.a
c:/users/sean/appdata/local/arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/../lib/gcc/avr/4.9.2/../../../../avr/lib/avr5/crtatmega328p.o:(.init9+0x0): undefined reference to `main'
C:\Users\Sean\AppData\Local\Temp\ccIaAibN.ltrans0.ltrans.o: In function `__vector_7':
C:\Users\Sean\Documents\Arduino\libraries\IRremote/IRremote.cpp:132: undefined reference to `digitalRead'
C:\Users\Sean\Documents\Arduino\libraries\IRremote/IRremote.cpp:194: undefined reference to `digitalWrite'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
