compiles but wont upload after new if...else statement
Hi All,
I hope this is the right form for this. Anyways I am using a cc3000 on an Arduino Mega 2560. I haven't had issues with it in the past.
The sketch simply connects to wifi(with success) while printing a value from A0 into serial, and if you go to it's webpage it SHOULD says whether or not the plant needs water(I am using a basic soil humidity sensor).
All was working until I added the compare (below), now it verifies but its timeouts on upload.
Please help
if (moist != 1)
client.fastrprintln(F("The plant is dry"));
client.fastrprintln(F("The plant is Wet, Thank You!!!"));
Complie.txt (45 KB)
mostiure.ino (10.9 KB)
How old is your board?
Try to limit your overuse of the exclamation mark.
Thank you!, I took out the exclamation mark and all is good. I have a Mega 2560 R3, I think I got in 2013 or so.
The problem is a bug in the old bootloader. !!! causes the bootloader to enter "monitor mode".
Is it a bug? or a feature?
It's a bug in a feature ("monitor mode") which nobody ever uses. I think the intent was that 3 exclamation points would put it into monitor mode, but they forgot to ignore "!!!" if it was in data being written to the flash, as opposed to as a command.
If you connect to ISP programmer and "burn bootloader", you can replace the old bootloader with the new bootloader in which this bug is fixed.
