Compiling error
New to the forum. Using IDE2.3.4. Getting compile errors. What's wrong?
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\Wipf Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\Wipf Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\Wipf Paul\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Wipf Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Wipf Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\Wipf Paul\AppData\Local\arduino\sketches\D1350CE3B3721E2722D442030EF5A4E3\sketch\Blink.ino.cpp -o nul
Generating function prototypes...
C:\Users\Wipf Paul\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Wipf Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Wipf Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\Wipf Paul\AppData\Local\arduino\sketches\D1350CE3B3721E2722D442030EF5A4E3\sketch\Blink.ino.cpp -o C:\Users\Wipf Paul\AppData\Local\Temp\2937650189\sketch_merged.cpp
C:\Users\Wipf Paul\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Wipf Paul\AppData\Local\Temp\2937650189\sketch_merged.cpp
Compiling sketch...
"C:\Users\Wipf Paul\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Wipf Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino" "-IC:\Users\Wipf Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard" "C:\Users\Wipf Paul\AppData\Local\arduino\sketches\D1350CE3B3721E2722D442030EF5A4E3\sketch\Blink.ino.cpp" -o "C:\Users\Wipf Paul\AppData\Local\arduino\sketches\D1350CE3B3721E2722D442030EF5A4E3\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\Wipf Paul\AppData\Local\arduino\cores\arduino_avr_uno_1c48a65beb083746d6f8f31a406efd6c\core.a
Linking everything together...
"C:\Users\Wipf Paul\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\Wipf Paul\AppData\Local\arduino\sketches\D1350CE3B3721E2722D442030EF5A4E3/Blink.ino.elf" "C:\Users\Wipf Paul\AppData\Local\arduino\sketches\D1350CE3B3721E2722D442030EF5A4E3\sketch\Blink.ino.cpp.o" "C:\Users\Wipf Paul\AppData\Local\arduino\sketches\D1350CE3B3721E2722D442030EF5A4E3/..\..\cores\arduino_avr_uno_1c48a65beb083746d6f8f31a406efd6c\core.a" "-LC:\Users\Wipf Paul\AppData\Local\arduino\sketches\D1350CE3B3721E2722D442030EF5A4E3" -lm
collect2.exe: fatal error: CreateProcess: No such file or directory
compilation terminated.
exit status 1
Compilation error: exit status 1
hey,
can you please send your arduino you use and your code?
Using Arduino Uno3 and blink example.
try this:
  • In the Arduino IDE, go to Tools > Board and select Arduino Uno.
  • Then, go to Tools > Port and select the correct COM port where your Arduino Uno is connected.
IDE shows UNO and port3.
can you send a screenshot of what's coming when you click on tools?
My first attempt to solve this woulkd be to clear the cache; you can do so by deleting the directory C:\Users\yourUsername\AppData\Local\arduino.
@hypergamer7391
Note that the error message in the opening post shows that @irrigatortech is using an Uno.
Also note that this is a linker/compiler error so COM ports are not involved.
Delete old file C:\Users\Wipf Paul\AppData\Local\Arduino15, and everything is fine. Thanks all.
