Powershell output:
PS C:\Users\khalilm\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.2.1
Checking for frontend application configuration customizations. Module path: C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.2.1" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.34.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2023-08-31T14:35:44.802Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.2.1","cliVersion":"0.34.0","buildDate":"2023-08-31T14:35:44.802Z"}
Starting backend process. PID: 6444
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/khalilm/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-02-12T14:25:26.116Z root INFO Backend Object.initialize: 4.2 ms [Finished 0.468 s after backend start]
2024-02-12T14:25:26.116Z root INFO Backend Object.configure: 3.5 ms [Finished 0.468 s after backend start]
2024-02-12T14:25:26.117Z root INFO Backend a.onStart: 1.4 ms [Finished 0.468 s after backend start]
2024-02-12T14:25:26.117Z root INFO Backend a.configure: 0.4 ms [Finished 0.494 s after backend start]
2024-02-12T14:25:26.118Z root INFO Backend u.onStart: 0.3 ms [Finished 0.494 s after backend start]
2024-02-12T14:25:26.119Z root INFO Backend d.configure: 0.1 ms [Finished 0.494 s after backend start]
2024-02-12T14:25:26.120Z root INFO Backend d.initialize: 26.1 ms [Finished 0.494 s after backend start]
2024-02-12T14:25:26.120Z root INFO Backend c.onStart: 0.2 ms [Finished 0.495 s after backend start]
2024-02-12T14:25:26.120Z root INFO Backend s.configure: 1.5 ms [Finished 0.496 s after backend start]
2024-02-12T14:25:26.122Z config INFO >>> Initializing CLI configuration...
2024-02-12T14:25:26.122Z root INFO Backend c.initialize: 0.4 ms [Finished 0.496 s after backend start]
2024-02-12T14:25:26.123Z root INFO Backend P.onStart: 0.7 ms [Finished 0.497 s after backend start]
2024-02-12T14:25:26.123Z config INFO Loading CLI configuration from c:\Users\khalilm\.arduinoIDE\arduino-cli.yaml...
2024-02-12T14:25:26.124Z daemon INFO Starting daemon from C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-02-12T14:25:26.124Z root INFO Backend s.initialize: 0.3 ms [Finished 0.498 s after backend start]
2024-02-12T14:25:26.124Z root INFO Backend w.onStart: 1.1 ms [Finished 0.499 s after backend start]
2024-02-12T14:25:26.124Z root INFO Backend r.configure: 2.0 ms [Finished 0.499 s after backend start]
2024-02-12T14:25:26.124Z discovery-log INFO start
2024-02-12T14:25:26.125Z discovery-log INFO start new deferred
2024-02-12T14:25:26.125Z root INFO Backend d.initialize: 0.3 ms [Finished 0.499 s after backend start]
2024-02-12T14:25:26.125Z root INFO Backend y.onStart: 1.9 ms [Finished 0.501 s after backend start]
2024-02-12T14:25:26.125Z root INFO Backend r.configure: 2.0 ms [Finished 0.502 s after backend start]
2024-02-12T14:25:26.125Z root INFO Backend s.onStart: 0.5 ms [Finished 0.503 s after backend start]
2024-02-12T14:25:26.125Z root INFO Backend h.configure: 0.5 ms [Finished 0.503 s after backend start]
2024-02-12T14:25:26.125Z root INFO Backend a.configure: 0.3 ms [Finished 0.504 s after backend start]
2024-02-12T14:25:26.125Z root INFO Backend s.configure: 0.1 ms [Finished 0.504 s after backend start]
2024-02-12T14:25:26.125Z root INFO Backend l.configure: 0.1 ms [Finished 0.504 s after backend start]
2024-02-12T14:25:26.128Z root INFO Theia app listening on http://localhost:50240.
2024-02-12T14:25:26.128Z root INFO Finished starting backend application: 3.4 ms [Finished 0.507 s after backend start]
2024-02-12T14:25:26.129Z root WARN The local plugin referenced by local-dir:/c%3A/Users/khalilm/.arduinoIDE/extensions does not exist.
2024-02-12T14:25:26.130Z root WARN The local plugin referenced by local-dir:/c%3A/Users/khalilm/.arduinoIDE/plugins does not exist.
2024-02-12T14:25:26.130Z root WARN The local plugin referenced by local-dir:C:\Users\khalilm\.arduinoIDE\plugins does not exist.
2024-02-12T14:25:26.157Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\khalilm\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\staging","user":"h:\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"network":{"proxy":"http://192.168.0.203/","user_agent_ext":"daemon"},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-02-12T14:25:26.158Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-02-12T14:25:26.160Z config INFO Loaded the CLI configuration.
2024-02-12T14:25:26.179Z root INFO Resolve plugins list: 56.0 ms [Finished 0.558 s after backend start]
2024-02-12T14:25:26.453Z daemon INFO time="2024-02-12T15:25:26+01:00" level=info msg="Using config file: c:\\Users\\khalilm\\.arduinoIDE\\arduino-cli.yaml"
time="2024-02-12T15:25:26+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2024-02-12T15:25:26+01:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:50242
{"IP":"127.0.0.1","Port":"50242"}
2024-02-12T14:25:26.453Z daemon INFO Daemon is running.
2024-02-12T14:25:26.534Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/khalilm/AppData/Local/Arduino15","sketchDirUri":"file:///h%3A/Documents/Arduino","additionalUrls":[],"network":{"protocol":"http","hostname":"192.168.0.203","password":"","username":"","port":""},"locale":"en"}
2024-02-12T14:25:26.534Z config INFO Validating the CLI configuration...
2024-02-12T14:25:26.536Z daemon INFO time="2024-02-12T15:25:26+01:00" level=info msg="Checking signature" index="c:\\Users\\khalilm\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\khalilm\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-02-12T14:25:26.738Z config INFO The CLI config is valid.
2024-02-12T14:25:26.738Z config INFO <<< Initialized the CLI configuration.
2024-02-12T14:25:26.743Z daemon INFO time="2024-02-12T15:25:26+01:00" level=info msg="Loading hardware from: c:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages"
time="2024-02-12T15:25:26+01:00" level=info msg="Loading package arduino from: C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2024-02-12T15:25:26+01:00" level=info msg="Missing signature file" index="C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2024-02-12T15:25:26+01:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-02-12T15:25:26+01:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-02-12T15:25:26+01:00" level=info msg="Loading tools from dir: C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-02-12T15:25:26+01:00" level=info msg="Loading package builtin from: C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-02-12T15:25:26+01:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-02-12T15:25:26+01:00" level=info msg="Loading tools from dir: C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.6"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.3"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.12.0"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2024-02-12T15:25:26+01:00" level=info msg="Loading package esp32 from: C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.6"
time="2024-02-12T15:25:26+01:00" level=info msg="Missing signature file" index="C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-alpha3\\installed.json"
2024-02-12T14:25:26.807Z daemon INFO time="2024-02-12T15:25:26+01:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded platform" platform="esp32:esp32@3.0.0-alpha3"
time="2024-02-12T15:25:26+01:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-02-12T15:25:26+01:00" level=info msg="Loading tools from dir: C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:esp-rv32@2302"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:esp32-arduino-libs@idf-release_v5.1-3662303f31"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.2.1"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.6"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20220706"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20230921"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@gcc8_4_0-esp-2021r2-patch5"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@12.1_20221002"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@12.1_20221002"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-12.2.0_20230208"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@gcc8_4_0-esp-2021r2-patch5"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-12.2.0_20230208"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2021r2-patch5"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-12.2.0_20230208"
time="2024-02-12T15:25:26+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@gcc8_4_0-esp-2021r2-patch5"
time="2024-02-12T15:25:26+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
time="2024-02-12T15:25:26+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-alpha3\\libraries" location=platform
time="2024-02-12T15:25:26+01:00" level=info msg="Loading libraries index file" index="c:\\Users\\khalilm\\AppData\\Local\\Arduino15\\library_index.json"
2024-02-12T14:25:27.004Z daemon INFO time="2024-02-12T15:25:26+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\khalilm\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-02-12T15:25:26+01:00" level=info msg="Adding libraries dir" dir="h:\\Documents\\Arduino\\libraries" location=user
2024-02-12T14:25:27.132Z root INFO Deploy plugins list: 56.0 ms [Finished 1.511 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-02-12T14:25:27.878Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 135.0 ms [Finished 1.637 s after frontend start]
2024-02-12T14:25:27.879Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-02-12T14:25:28.497Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 550.4 ms [Finished 2.286 s after frontend start]
2024-02-12T14:25:28.630Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 131.7 ms [Finished 2.418 s after frontend start]
2024-02-12T14:25:28.657Z root INFO Start frontend contributions: 988.7 ms [Finished 2.426 s after frontend start]
2024-02-12T14:25:28.657Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-02-12T14:25:28.676Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-02-12T14:25:28.676Z root INFO >>> Restoring the layout state...
2024-02-12T14:25:28.678Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-02-12T14:25:28.678Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/ESP32-S3-SOFTWARE-PROBE/Ethernet_OTW_Update_ESP32/Ethernet_OTW_Update_ESP32.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":15,\"column\":16},\"position\":{\"lineNumber\":15,\"column\":16}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":126,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":true}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":0}},"pinned":[false,false],"size":121,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"code-editor-opener:file:///d%3A/ESP32-S3-SOFTWARE-PROBE/Ethernet_OTW_Update_ESP32/Ethernet_OTW_Update_ESP32.ino:0"}
2024-02-12T14:25:28.680Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-02-12T14:25:28.727Z root INFO [f110e6af-07aa-4655-8857-7a22b2b7fb4e] Waiting for backend deployment: 91.5 ms [Finished 2.511 s after frontend start]
2024-02-12T14:25:29.171Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980) starting instance
2024-02-12T14:25:29.647Z root INFO [f110e6af-07aa-4655-8857-7a22b2b7fb4e] Sync of 23 plugins: 924.0 ms [Finished 3.436 s after frontend start]
2024-02-12T14:26:50.878Z daemon INFO time="2024-02-12T15:26:50+01:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from h:\\Documents\\Arduino\\libraries\\Ethernet: invalid library: no header files found"
2024-02-12T14:26:50.882Z discovery-log INFO start request start watch
2024-02-12T14:26:50.882Z discovery-log INFO start requested start watch
2024-02-12T14:26:50.883Z discovery-log INFO start resolved watching
2024-02-12T14:26:50.885Z daemon INFO time="2024-02-12T15:26:50+01:00" level=info msg="starting discovery builtin:serial-discovery process"
2024-02-12T14:26:50.885Z daemon INFO time="2024-02-12T15:26:50+01:00" level=info msg="starting discovery builtin:mdns-discovery process"
2024-02-12T14:26:50.887Z daemon INFO time="2024-02-12T15:26:50+01:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2024-02-12T15:26:50+01:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:mdns-discovery"
time="2024-02-12T15:26:50+01:00" level=info msg="started discovery builtin:serial-discovery process"
2024-02-12T14:26:50.888Z daemon INFO time="2024-02-12T15:26:50+01:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:serial-discovery"
2024-02-12T14:26:50.896Z daemon INFO time="2024-02-12T15:26:50+01:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
2024-02-12T14:26:50.897Z daemon INFO time="2024-02-12T15:26:50+01:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
time="2024-02-12T15:26:50+01:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
time="2024-02-12T15:26:50+01:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
time="2024-02-12T15:26:50+01:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
time="2024-02-12T15:26:50+01:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2024-02-12T14:26:50.905Z daemon INFO time="2024-02-12T15:26:50+01:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM8"
2024-02-12T14:26:50.909Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM8","label":"COM8","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0xEA60"],["serialNumber","D8D9DC959C19EC11BA500DB5F01C6278"],["vid","0x10C4"]],"hardwareId":"D8D9DC959C19EC11BA500DB5F01C6278"}},"error":""}
2024-02-12T14:26:51.007Z root INFO <<< The layout has been successfully restored.
2024-02-12T14:26:51.122Z root INFO Initialize the workbench layout: 82342.8 ms [Finished 84.796 s after frontend start]
2024-02-12T14:26:51.125Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-02-12T14:26:51.125Z root INFO [f110e6af-07aa-4655-8857-7a22b2b7fb4e] Loading plugin contributions
2024-02-12T14:26:51.126Z root INFO [f110e6af-07aa-4655-8857-7a22b2b7fb4e] Load contributions of 23 plugins: 112.9 ms [Finished 84.910 s after frontend start]
2024-02-12T14:26:51.132Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-02-12T14:26:51.133Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-02-12T14:26:51.865Z root ERROR [hosted-plugin: 980] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2024-02-12T14:26:51.865Z root ERROR [hosted-plugin: 980] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2024-02-12T14:26:51.909Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): PluginManagerExtImpl/init()
2024-02-12T14:26:51.912Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(vscode-arduino-api@0.1.2 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:51.961Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(cortex-debug@1.5.1 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:51.962Z root INFO [hosted-plugin: 980] Debugger contribution has been registered: cortex-debug
2024-02-12T14:26:51.964Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(vscode-arduino-tools@0.0.2-beta.8 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:51.965Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(cpp@1.52.1 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:51.966Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(json@1.46.1 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:51.969Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(json-language-features@1.46.1 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:51.970Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:51.971Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(vscode-language-pack-cs@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:51.972Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(vscode-language-pack-de@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:51.978Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(vscode-language-pack-es@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(980): initializing(vscode-language-pack-fr@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(980): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(980): initializing(vscode-language-pack-it@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(980): initializing(vscode-language-pack-ja@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(980): initializing(vscode-language-pack-ko@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(980): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(980): initializing(vscode-language-pack-pl@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:51.979Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(vscode-language-pack-pt-BR@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(980): initializing(vscode-language-pack-ru@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(980): initializing(vscode-language-pack-tr@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(980): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:51.981Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(vscode-language-pack-zh-hans@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:51.982Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): initializing(vscode-language-pack-zh-hant@1.78.0 with C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-02-12T14:26:52.010Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): PluginManagerExtImpl/loadPlugin(C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2024-02-12T14:26:52.033Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): PluginManagerExtImpl/loadPlugin(C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2024-02-12T14:26:52.096Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): PluginManagerExtImpl/loadPlugin(C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
2024-02-12T14:26:52.534Z root INFO Frontend application start: 84693.6 ms [Finished 86.912 s after backend start]
2024-02-12T14:26:52.547Z root INFO Replace loading indicator with ready workbench UI (animation): 1006.7 ms [Finished 85.920 s after frontend start]
2024-02-12T14:26:52.556Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-02-12T14:26:52.556Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2024-02-12T14:26:52.557Z root INFO [f110e6af-07aa-4655-8857-7a22b2b7fb4e] Starting plugins.
Checking for update
2024-02-12T14:26:52.676Z daemon INFO time="2024-02-12T15:26:52+01:00" level=info msg="Updating libraries index"
time="2024-02-12T15:26:52+01:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-02-12T14:26:52.677Z daemon INFO time="2024-02-12T15:26:52+01:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-02-12T14:26:52.680Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-02-12T14:26:52.681Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-02-12T14:26:52.682Z daemon INFO time="2024-02-12T15:26:52+01:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-02-12T14:26:52.683Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": Bad Request
at t.callErrorFromStatus (C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:726940)
at Object.onReceiveStatus (C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:754480)
at Object.onReceiveStatus (C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:747504)
at C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:833048
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at a.makeServerStreamRequest (C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:754247)
at a.updateLibrariesIndex (C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:818456)
at C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:587296
at C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:587489
at new Promise (<anonymous>)
at _.doUpdateIndex (C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:587468)
at _.updateLibraryIndex (C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:587268)
at _.updateIndex (C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:586542)
at E.updateIndex (C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:589376)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-02-12T14:26:52.687Z root INFO [hosted-plugin: 980] PLUGIN_HOST(980): PluginManagerExtImpl/loadPlugin(C:\Users\khalilm\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2024-02-12T14:26:52.721Z root INFO [hosted-plugin: 980] Debug configuration provider has been registered: cortex-debug, trigger: 1
2024-02-12T14:26:52.727Z root INFO [hosted-plugin: 980] GDB server console created
2024-02-12T14:26:52.737Z root INFO [f110e6af-07aa-4655-8857-7a22b2b7fb4e] Start of 23 plugins: 1608.3 ms [Finished 86.524 s after frontend start]
Found version 2.3.0 (url: arduino-ide_2.3.0_Windows_64bit.exe)
2024-02-12T14:26:54.687Z root WARN Widget was activated, but did not accept focus after 2000ms: serial-monitor
2024-02-12T14:26:59.131Z root ERROR ---- !!!SLOW!!! DURATION: search took 6565.689 ms. Args: [{"type":"Updatable"}] ----
[9856:0212/152725.679:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL is disabled, ANGLE is
