Complete noob... LDR and servo
Hi, for the past few days I've been trying to create a small project with my arduino. I want to use a servo controlled by a LDR (those resistance that change value by the amount of light). I want the servo to be at 150 degrees when there's no light or just a little light and then switch to 120 degrees when there's plenty of light.
I've based my setup on the servo controlled by a potentiometer in the tutorial section. The code of the example is the following:
// Controlling a servo position using a potentiometer (variable resistor)
// by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int potpin = 0;  // analog pin used to connect the potentiometer
int val;    // variable to read the value from the analog pin
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  myservo.write(val);                  // sets the servo position according to the scaled value
  delay(15);                           // waits for the servo to get there
I've taken a few example on many sites and I've produced a buggy code that doesn't do what I want:
#include <SoftwareServo.h>
SoftwareServo myservo;  // create servo object to control a servo
int potPin = 0;  // analog pin used to connect the LDR
int ledPin = 13; //Blinking led
int limit = 800;  //Threshold limit if the LDR output a value between 0 and 1023
  myservo.attach(2);  // attaches the servo on pin 2 to the servo object
  pinMode(ledPin, OUTPUT);
  pinMode(potPin, INPUT);
  int val = analogRead(potPin);              // read the value of the LDR and store it into val
  if (val < limit) {
      myservo.write(150);            //write 150 degrees to the servo if val is smaller than 800
  } else if (val >= limit) {
       digitalWrite(ledPin, HIGH);
       digitalWrite(ledPin, LOW);
       myservo.write(120);             //If val is bigger than 800 blink led 2 times and switch servo to 120 degrees
  delay(3000);                           // waits 3 seconds before restarting
  SoftwareServo::refresh();          //Don't know why it's here but I was told it had to be
When I upload it the servo start from 0 degrees and increment of about 20 degrees its rotation every 3 seconds...
What am I doing wrong...
as far as i know, you must call the function refresh() of the servo-libraray at least every 50ms. So change the delay(1000) to a loop like
for (i=0; i<20;i++) {
myservo.refresh();
delay(50);
Hope this works
Mike
