Conflict with \n in ethernet codes and GSM
Hi All,
Im a newbie in Arduino. Need your advise on how i can fix my problem in my code. I have a \n function in both Ethernet and GSM codes that seems to conflict with each other. When i try to add this GSM \n line to my sketch, my page is not working:
incoming = mySerial.readStringUntil('\n');
I am not familiar with GSM coding, so I am not sure what the solution will be. Can you help me figure out the solution to this? Here's my sketch.
//For ethernet
#include <SPI.h>
#include <Ethernet.h>
//For relay
#include <Wire.h>
#include <Relay.h>
//For Temp
#include <OneWire.h>
#include <DallasTemperature.h>
//For GSM
#include <SoftwareSerial.h>
#include <EEPROM.h>
//For GSM---------------------------------------------------------------------------------
SoftwareSerial mySerial(2, 3);
String allowedNumber; // To store the allowed phone number from the SIM's phonebook
int passFlag = 0;
int passFlag1 = 0;
int passFlag2 = 0;
int passFlag3 = 0;
//Millis timeout---------------------------------------------------------------------------
//Batt pin---------------------------------------------------------------------------------
#define SIGNAL_PIN A0   //battery level monitoring using 4.7K & 2.2K ohm resistor
//Temp Pin---------------------------------------------------------------------------------
#define ONE_WIRE_BUS 4
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
float temp;
//Batt computation-------------------------------------------------------------------------
float adc_voltage = 0.0;
float in_voltage = 0.0;
float R1 = 30000.0;
float R2 = 7500.0;
float ref_voltage = 5.0;
int adc_value = 0;
//Ethernet---------------------------------------------------------------------------------
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1, 12);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
// Relay state and pin---------------------------------------------------------------------
String relay1State1 = "OFF";
String relay2State2 = "OFF";
const int  TempCon= 6;
const int ChgRlyCon = 7;
// Client variables------------------------------------------------------------------------
char linebuf[160];
int charcount=0;
boolean authentificated=false;
void dashboardPage(EthernetClient &client) {
  client.println(F("HTTP/1.1 200 OK"));
  client.println(F("Content-Type: text/html"));
  client.println(F("Connnection: close"));
  client.println();
  client.println(F("<!DOCTYPE HTML><html><style>body {background-image: url(\"https://geloautomationworks.files.wordpress.com/2023/09/bg-2.png\");  background-size: 100vw 100vh; background-repeat: no-repeat;  text-align: center; font-family: \"Trebuchet MS\", Arial;}</style>"));
  client.println(F("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">"));
  client.println(F("<script>"));
  client.println(F("setInterval(function()"));
  client.println(F("{"));
  client.println(F("getReadingsVals();"));
  client.println(F("}, 3000);"));
  client.println(F("function getReadingsVals()"));
  client.println(F("var xhttp = new XMLHttpRequest();"));
  client.println(F("xhttp.onreadystatechange = function()"));
  client.println(F("if(this.readyState == 4 && this.status == 200)"));
  client.println(F("document.getElementById(\"ReadingsVals\").innerHTML = this.responseText;"));
  client.println(F("}"));
  client.println(F("};"));
  client.println(F("xhttp.open(\"GET\", \"readReadings\", true);"));
  client.println(F("xhttp.send();"));
  client.println(F("document.getElementById(\"BatteryVals\").innerHTML = this.responseText;"));
  client.println(F("xhttp.open(\"GET\", \"readBattery\", true);"));
  client.println(F("</script>"));
  client.println(F("</head>"));
  client.println(F("<body>"));
  client.println(F("<h1>Automated Remote Monitoring and Control of Power and Temperature</h1>"));
  client.println(F("<h1>applying IoT</h>"));
  client.println(F("<br>"));
  client.println(F("</br>"));
  client.println(F("<h3>SERVER TEMPERATURE</h3>"));
  client.println(F("<span id =\"ReadingsVals\">"));
  client.println(F(""));
  client.println(F("</span>"));
  client.println(F("<a href=\"/ACON\"><button>ON</button></a>&nbsp;&nbsp"));
  client.println(F("<a href=\"/ACOFF\"><button>OFF</button></a>"));
  client.println(F("<h3>SERVER BATTERY LEVEL</h3>"));
  client.println(F("<span id =\"BatteryVals\">"));
  // Generates buttons to control the relay
client.println(F("<a href=\"/DCON\"><button>ON</button></a>&nbsp;&nbsp"));
client.println(F("<a href=\"/DCOFF\"><button>OFF</button></a></center>"));
client.println(F("<center><a href=\"/\">Refresh</a>"));
client.println(F("</body></html>"));
void SendAuthentificationpage(EthernetClient &client)
  client.println(F("HTTP/1.1 401 Authorization Required"));
  client.println(F("WWW-Authenticate: Basic realm=\"Secure Area\""));
  client.println("Connnection: close");
  client.println();
  client.println(F("<!DOCTYPE HTML>"));
  client.println(F("<HTML>  <HEAD>   <TITLE>Error</TITLE>"));
  client.println(F(" </HEAD> <BODY><H1>401 Unauthorized.</H1></BODY> </HTML>"));
void AJAX_request(EthernetClient  &client)
client.println(F("<font face =\"radioland\", size = \"15\", color= \"black\">"));
client.println(temp);
client.println(F("°C"));
client.println(F("</font>"));
  if(relay1State1 == "ON"){
  client.println(F("Aircon is <font color=\"green\"’>ON</font>"));
  else if(relay1State1 == "OFF") {
  client.println(F("Aircon is <font color=\"red\">OFF</font>"));
void BATT_request(EthernetClient  &client)
client.println(in_voltage);
client.println(F("V"));
if(relay2State2 == "ON") {
client.println(F("Battery is <font color=\"green\">CHARGING</font>"));
else if(relay2State2 == "OFF") {
client.println(F("Battery is <font color=\"red\">NOT CHARGING</font>"));
    // For GSM
  mySerial.begin(9600);
  Serial.println("Setup starts.");
  mySerial.println("AT"); // Initialize the module
  mySerial.println("AT+CMGF=1"); // Set SMS mode to text
  mySerial.println("AT+CNMI=1,2,0,0,0"); // Configure how SMS notifications are handled
  mySerial.println("AT+CSMP=49,167,0,0");
  // Clear SIM800L's buffer.
  while (mySerial.available()) mySerial.read();
  allowedNumber = getPhoneNumberFromPhonebook();
  Serial.println("Setup ends.");
  //For ethernet
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  //For relay pins
  pinMode(ChgRlyCon, OUTPUT);
  digitalWrite(ChgRlyCon, LOW);
  pinMode(TempCon, OUTPUT);
  digitalWrite(TempCon, LOW);
//----GSM------------------------------------------------------------------------------------
   if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
  // listen for incoming clients
//----TEMP SENSOR---------------------------------------------------------------------------
  sensors.requestTemperatures(); // Send the command to get temperatures
  temp = sensors.getTempCByIndex(0);
//----BATT SENSOR---------------------------------------------------------------------------
// Why "byIndex"?
  // You can have more than one IC on the same bus.
  // 0 refers to the first IC on the wire
  // Read the Analog Input
  adc_value = analogRead(SIGNAL_PIN);
  // Determine voltage at ADC input
  adc_voltage  = (adc_value * ref_voltage) / 1024.0;
  // Calculate voltage at divider input
  in_voltage = adc_voltage / (R2 / (R1 + R2)) ;
//----FOR GSM--------------------------------------------------------------------------------------
String phoneNumber = "";
String command = "";
String incoming = "";
  if (mySerial.available()) {
    Serial.print("Init read: "); Serial.println(line);
    if (incoming.startsWith("+CMT:")) { // Check if a new SMS is received
      phoneNumber = extractPhoneNumber(incoming);   // Extract the phone number.
      command = mySerial.readStringUntil('\n');  // This will read the actual message.
     Serial.print("Sender: "); Serial.println(phoneNumber);
     Serial.print("Command: "); Serial.println(command);
     if (allowedNumber == phoneNumber) {
        command.trim();
     Serial.print("Authorized! ");
      if (command.equalsIgnoreCase("AC ON")) {
      digitalWrite(TempCon, HIGH);
      relay1State1 = "ON";
      sendSMS("AC has been turned on via text");
        else if (command.equalsIgnoreCase("AC OFF")) {
          sendSMS("AC has been turned ooff via text");
         else if (command.equalsIgnoreCase("DC ON")) {
          digitalWrite(ChgRlyCon, HIGH);
         relay2State2 = "ON";
          sendSMS("Charging of battery has been turned on via text");
        else if (command.equalsIgnoreCase("DC OFF")) {
          sendSMS("Charging of battery has been turned off via text");
        else {
        sendSMS("Unknown command: " + command);
//----BASIC AUTHENTICATION------------------------------------------------------------------
  if (client) {
    memset(linebuf, 0, sizeof(linebuf));
    charcount = 0;
    authentificated = false;
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        linebuf[charcount] = c;
        if (charcount < sizeof(linebuf) - 1) charcount++;
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the HTTP request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // decide what to do
          if (strstr(linebuf, "Authorization: Basic") > 0 && strstr(linebuf, "YWRtaW46RGF5d2Fsa2VyQDAwMg==") > 0)
            authentificated = true;
          if (strstr(linebuf, "readReadings") > 0) {
             AJAX_request(client);
          else if (strstr(linebuf, "readBattery") > 0) {
             BATT_request(client);
          else if (authentificated) {
            dashboardPage(client);
          if (strstr(linebuf, "GET /ACON") > 0 && authentificated) {
            relay1State1="ON";
            sendSMS("AC HAS BEEN TURNED ON BY ADMIN");
          else if (strstr(linebuf, "GET /ACOFF") > 0 && authentificated) {
            relay1State1="OFF";
            sendSMS("AC HAS BEEN TURNED OFF BY ADMIN");
          else if (strstr(linebuf, "GET /DCON") > 0 && authentificated) {
            relay2State2="ON";
            sendSMS("CHARGING THE BATTERY HAS BEEN CONNECTED BY ADMIN");
          else if (strstr(linebuf, "GET /DCOFF") > 0 && authentificated) {
            relay2State2="OFF";
            sendSMS("CHARGING THE BATTERY HAS BEEN DISCONNECTED BY ADMIN");
          else {
            SendAuthentificationpage(client);
        if (c == '\n') {
          // you're starting a new line
        } else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
//----TEMP CONDITION------------------------------------------------------------------------
  if( temp >= 35){
    if(passFlag == 0){
      sendSMS("AIRCON HAS BEEN TURNED ON");
      passFlag = 1;
      passFlag1 = 0;
  if (temp <= 29){
    if(passFlag1 == 0){
      sendSMS("AIRCON HAS BEEN TURNED OFF");
      passFlag1 = 1;
      passFlag = 0;
//----BATT CONDITION------------------------------------------------------------------------
  //--------------------------- bms 0, batt lt 13.4v--------------
  if(in_voltage >= 15){
    if(passFlag2 == 0){
      sendSMS("CHARGING THE BATTERY HAS BEEN DISCONNECTED");
      passFlag2 = 1;
      passFlag3 = 0;
  //--------------------------- bms 0, batt is charged at 13.4V -------
  if(in_voltage <= 6){
    if(passFlag3 == 0){
      sendSMS("CHARGING THE BATTERY HAS BEEN CONNECTED");
      passFlag3 = 1;
      passFlag2 = 0;
String getPhoneNumberFromPhonebook() {
  String response = "";
  mySerial.println("AT+CPBR=1"); // Read the first entry in phonebook
    response = mySerial.readStringUntil('\n');
  response.trim();
  if (response.startsWith("+CPBR:")) {
    response = extractPhoneNumber(response);
    return response;
  else {
    return "No Valid contact."; // Return empty string if phonebook entry not found
void sendSMS(String message) {
  mySerial.print("AT+CMGS=\"");
  mySerial.print(allowedNumber);
  mySerial.println("\"");
  mySerial.print(message);
  mySerial.write(26); // Send Ctrl+Z character to indicate the end of the message
String extractPhoneNumber(String line) {
  int firstQuote = line.indexOf('"');
  int secondQuote = line.indexOf('"', firstQuote + 1);
  String phoneNumber = line.substring(firstQuote + 1, secondQuote);
  // Replace "+63" with "0"
  phoneNumber.replace("+63", "0");
  return phoneNumber;
Thank you.
Needs to be mySerial.setTimeout(5)
In what way(s), exactly, is it "not working"?
What happens if you make it '\r' instead of '\n' ... ?
Hi all,
I think i see the conflict in my code. When i try to add this function to my code, the webpage will stop working.
This is one of the function on my GSM that once it receives an AC ON text from the sender, the Digital pin will turn on. Do you have any idea why this line is conflicting with my whole code?
Here's my code
//For ethernet
#include <SPI.h>
//For relay
#include <Wire.h>
#include <Relay.h>
//For Temp
//For GSM
#include <EEPROM.h>
int passFlag = 0;
int passFlag1 = 0;
int passFlag2 = 0;
int passFlag3 = 0;
float temp;
float R1 = 30000.0;
float R2 = 7500.0;
int adc_value = 0;
byte mac[] = {
char linebuf[160];
int charcount=0;
  client.println();
  client.println();
    // For GSM
  //For ethernet
  server.begin();
  //For relay pins
// Why "byIndex"?
        command.trim();
        else {
  if (client) {
    charcount = 0;
        Serial.write(c);
            relay1State1="ON";
            relay1State1="OFF";
            relay2State2="ON";
            relay2State2="OFF";
          else {
        if (c == '\n') {
    delay(1);
    client.stop();
  if( temp >= 35){
    if(passFlag == 0){
      passFlag = 1;
      passFlag1 = 0;
  if (temp <= 29){
    if(passFlag1 == 0){
      passFlag1 = 1;
      passFlag = 0;
    if(passFlag2 == 0){
      passFlag2 = 1;
      passFlag3 = 0;
    if(passFlag3 == 0){
      passFlag3 = 1;
      passFlag2 = 0;
  response.trim();
    return response;
  else {
  return phoneNumber;
Thank you.
Are you running out of memory? what board are you using? There are a lot of String objects throughout your code and their use can fragment memory.
