Pins 3,5, and 6 are considered OUTPUT pins but in this circuit they are taking in voltage? What I initially thought was that we would connect the 3 LED leads to the pins (like above), and connect the anode to the ground. Can the pins not create a voltage and output current?
Could someone please explain to me where I'm going wrong? Thank you in advance.
In this context a pin configured to be an output will be driven to the voltage level set by the sketch. That could mean that it sources current (when it's set high and the pin is connected via a load to ground) or sinks current (when it's driven low and connected via a load to a higher voltage).
If it's configured to be an input then it doesn't drive the pin voltage level but just enables the sketch to read what voltage the pin has been pulled to by whatever is connected to it.
remedemic:
how are the pins controlling the level of the LEDs if they are simply directing the current to ground?
The series resistors are what are 'controlling' the amount of current for each led, the digital output pin set to LOW just allows the path for current flow. When set to HIGH the led/resistors have the same voltage on both ends so no current can flow.
Im sorry I was referring to the PWM that is controlling the level of the LEDs. If the pins are acting as a path to ground, how is the PWM controlling the level of the LEDs?
And also, why are we using pins to send the current to ground? Why not just send connect the the LED to the ground after feeding in voltage through the 3 seperate LEDs? Is it because this is a common anode RGB LED? If it were a common cathod RGB LED, could I do it the way I described?
Thank you again, I appreciate it. I apologize, I'm a bit confused at the moment.
remedemic:
The pwm output lets one change the duty cycle of the HIGH and LOW output switching such that the led will appear to have less 'effective' current as the duty cycle is reduced from 100% towards 0%. It's really your eye that is 'averaging' the light level, the instantaneous current is still either 0 ma or the current set by the resistor depending on the output state of the pwm pin at any instant of time.
Yes, common anode or common cathode package configuration dictates what level has to be used for the common side of the leds.
