This code is not producing expected results. I'm dividing by ten and expecting count of 10's and remainder.
for (int K = 0; K<= 87; K++) {
Software submitted post before finishing:
Use the code tag in the reply editor to properly post your code and try again, please.
If I hit a tab the post is submitted
Q=K/10; //generate number of 10's
P=Q%10; //display remainder
K=10 gives Q=1; P=10- - I want Q=1; P=0
K=18 gives Q=1, P=10- - I want Q=1; P=8
My C and C++ textbooks don't address it. So what face palm idea am I missing?
Please use the code tag to add code:
This would surprise me, it's a pretty standard exercise.
Should that not be:
P = K % 10; // Display remainder.
I normally use the code tag, but for three lines of code that resides on a separate computer isolated from the internet I didn't want to transfer it to a stick to trade between machines.
You can edit your posts and put the code in tags now though.
I agree with @jfjlaros, that should be
P=K%10; //display remainder
in this case, you could also
Q = K / 10;
R = K - 10 * Q;
and leave the mod operator out of the picture.
a7
Thanks for the help; problem solved.
The division operator (/) gives Quotient (Q) when the number K is divided by N.
The modulus operator (%) gives Remainder (R) when the number K is divided by N.
For example: Given: K = 87, N = 10
Q = 8
R = 7
Codes:
for(int K = 0; K <= 87; K++)
Serial. print("Quotient (Q): "); Serial.println(K/10);
Serial. print("Quotient (R): "); Serial.println(K%10);
