Connect Arduino Uno Wifi to IBM Bluemix
Hello guys, i have a something problem how to connected arduino wifi uno to ibm bluemix via mqtt?can you help me, please write the arduino code. Thank you
an example of the code i write below:
I am confused here to change the header of the include <esp8266.h> into <<UnoWiFiDevEd.h> for arduino uno wifi
#include <ArduinoJson.h>
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
 * IBM IoT Foundation managed Device
 * Author: Ant Elder
 * License: Apache License v2
//#include <ESP8266WiFi.h>
//#include <PubSubClient.h> // https://github.com/knolleary/pubsubclient/releases/tag/v2.3
//#include <ArduinoJson.h> // https://github.com/bblanchon/ArduinoJson/releases/tag/v5.0.7
//-------- Customise these values -----------
const char* ssid = "CUSTOMISE";
const char* password = "CUSTOMISE";
#define ORG "CUSTOMISE"
#define DEVICE_TYPE "ESP8266"
#define DEVICE_ID "test1"
#define TOKEN "CUSTOMISE"
//-------- Customise the above values --------
char server[] = ORG ".messaging.internetofthings.ibmcloud.com";
char authMethod[] = "use-token-auth";
char token[] = TOKEN;
char clientId[] = "d:" ORG ":" DEVICE_TYPE ":" DEVICE_ID;
const char publishTopic[] = "iot-2/evt/status/fmt/json";
const char responseTopic[] = "iotdm-1/response";
const char manageTopic[] = "iotdevice-1/mgmt/manage";
const char updateTopic[] = "iotdm-1/device/update";
const char rebootTopic[] = "iotdm-1/mgmt/initiate/device/reboot";
WiFiClient wifiClient;
void callback(char* topic, byte* payload, unsigned int payloadLength);
PubSubClient client(server, 1883, callback, wifiClient);
void handleUpdate(byte* payload);
int publishInterval = 30000; // 30 seconds
long lastPublishMillis;
void wifiConnect() {
 Serial.print("Connecting to "); Serial.print(ssid);
 WiFi.begin(ssid, password);
 Serial.print(".");
 Serial.print("nWiFi connected, IP address: "); Serial.println(WiFi.localIP());
void mqttConnect() {
 if (!!!client.connected()) {
 Serial.print("Reconnecting MQTT client to "); Serial.println(server);
 while (!!!client.connect(clientId, authMethod, token)) {
 Serial.print(".");
void initManagedDevice() {
 if (client.subscribe("iotdm-1/response")) {
 Serial.println("subscribe to responses OK");
 Serial.println("subscribe to responses FAILED");
 if (client.subscribe(rebootTopic)) {
 Serial.println("subscribe to reboot OK");
 Serial.println("subscribe to reboot FAILED");
 if (client.subscribe("iotdm-1/device/update")) {
 Serial.println("subscribe to update OK");
 Serial.println("subscribe to update FAILED");
 StaticJsonBuffer<300> jsonBuffer;
 JsonObject& root = jsonBuffer.createObject();
 JsonObject& d = root.createNestedObject("d");
 JsonObject& metadata = d.createNestedObject("metadata");
 metadata["publishInterval"] = publishInterval;
 JsonObject& supports = d.createNestedObject("supports");
 supports["deviceActions"] = true;
 char buff[300];
 root.printTo(buff, sizeof(buff));
 Serial.println("publishing device metadata:"); Serial.println(buff);
 if (client.publish(manageTopic, buff)) {
 Serial.println("device Publish ok");
 Serial.print("device Publish failed:");
void publishData() {
 String payload = "{\"d\":{\"counter\":";
 payload += millis() / 1000;
 payload += "}}";
 Serial.print("Sending payload: "); Serial.println(payload);
 if (client.publish(publishTopic, (char*) payload.c_str())) {
 Serial.println("Publish OK");
 Serial.println("Publish FAILED");
void callback(char* topic, byte* payload, unsigned int payloadLength) {
 Serial.print("callback invoked for topic: "); Serial.println(topic);
 if (strcmp (responseTopic, topic) == 0) {
 return; // just print of response for now
 if (strcmp (rebootTopic, topic) == 0) {
 Serial.println("Rebooting...");
 ESP.restart();
 if (strcmp (updateTopic, topic) == 0) {
 handleUpdate(payload);
void handleUpdate(byte* payload) {
 JsonObject& root = jsonBuffer.parseObject((char*)payload);
 if (!root.success()) {
 Serial.println("handleUpdate: payload parse FAILED");
 return;
 Serial.println("handleUpdate payload:"); root.prettyPrintTo(Serial); Serial.println();
 JsonObject& d = root["d"];
 JsonArray& fields = d["fields"];
 for(JsonArray::iterator it=fields.begin(); it!=fields.end(); ++it) {
 JsonObject& field = *it;
 const char* fieldName = field["field"];
 if (strcmp (fieldName, "metadata") == 0) {
 JsonObject& fieldValue = field["value"];
 if (fieldValue.containsKey("publishInterval")) {
 publishInterval = fieldValue["publishInterval"];
 Serial.print("publishInterval:"); Serial.println(publishInterval);
 Serial.begin(115200); Serial.println();
 wifiConnect();
 mqttConnect();
 initManagedDevice();
 if (millis() - lastPublishMillis > publishInterval) {
 publishData();
 lastPublishMillis = millis();
 if (!client.loop()) {
 mqttConnect();
[/quote]
What have you tried? Share your code (IBM has some basic info here for example, possibly somewhat obsolete as the platform is changing but concepts should still apply)
ok I attached an example coding from arduino uno + esp8266, how does it apply if the arduino uno wifi?
please help me.
This script works for me -- I have an Uno with an ATWINC1500 WiFi board, a TMP36 temperature sensor, and an LED. The sketch as it stands writes to the IBM "quickstart" service which requires no registration, so I can see the data at https://quickstart.internetofthings.ibmcloud.com/#/device/PDH-AU1/sensor/ . The commented-out lines work with the signup-required trial account that lets you do a lot more with the data.
#include <SPI.h>
#include <WiFi101.h>
#define TMP36_PIN          0 // Analog pin
#define RED_LED_PIN        2 // Digital pin
#define MY_SSID            "XXXXXXXXXX"
#define MY_WEP_PASSWORD    "XXXXXXXXXX"
#define MY_WEP_KEY_INDEX   0
#define BROKER             "XXXXX.messaging.internetofthings.ibmcloud.com"
#define ID                 "use-token-auth"
#define MY_AUTH_TOKEN      "XXXXXXXX"
#define TOPIC              "iot-2/evt/greeting/fmt/txt"
#define MY_CLIENT_ID       "d:XXXXXX:ArduinoUnoWiFi:PDH-AU1"
#define BROKER             "quickstart.messaging.internetofthings.ibmcloud.com"
#define ID                 ""
#define MY_AUTH_TOKEN      ""
#define TOPIC              "iot-2/evt/status/fmt/json"
#define MY_CLIENT_ID       "d:quickstart:ArduinoUnoWiFi:PDH-AU1"
char message[128];
#define DELAY_BT_READINGS  60 // Delay time in seconds between messages
WiFiClient client; int port = 1883;
PubSubClient clientPS(client);
int connects = 0;
long startTime, lastConnectTime;
  while (!Serial) {
    ; // Wait for serial port to connect. Needed for native USB port only
  WiFi.setPins(8,7,4);
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("No WiFi shield");
    while (true);
  pinMode (RED_LED_PIN, OUTPUT);
  clientPS.setServer(BROKER, port);
  startTime = millis();
  digitalWrite(RED_LED_PIN, HIGH);
  while (!clientPS.connected()) {
    connect_to_MQTT();
  int t = getTempInF();
  int rssi = WiFi.RSSI();
  long uptimeMinutes = (millis() - startTime) / (1000L * 60L);
  long connectUptime = (millis() - lastConnectTime) / (1000L * 60L);
  buildMessage (t, rssi, connects, uptimeMinutes, connectUptime);
  Serial.print ("Publish: "); Serial.println (message);
  Serial.print ("  Len: "); Serial.println (strlen(message));
  clientPS.publish(TOPIC, message);
  Serial.println("  Success");
  digitalWrite(RED_LED_PIN, LOW);
  Serial.println ("Delay");
  for (int i = 0; i < DELAY_BT_READINGS; ++i) {
    delay (1000);
    if (i%5 == 0) {
      boolean st = clientPS.loop();
      if (st != 1) { // Something is wrong with the connection
        Serial.print("  Status: "); Serial.println(st);
void buildMessage(int temp, int rssi, int connects, long uptime, long connectUptime) {
  char tempBuf[5];
  strcpy (message, "{\"d\":{ \"temperature\":");
   itoa(temp, tempBuf, 10);
   strcat (message, tempBuf);
  strcat (message, ", \"RSSI\":");
   itoa(rssi, tempBuf, 10);
  strcat (message, ", \"connects\":");
   itoa (connects, tempBuf, 10);
  strcat (message, ", \"uptimeMinutes\":");
   ltoa (uptime, tempBuf, 10);
  strcat (message, ", \"connectUptime\":");
   ltoa(connectUptime, tempBuf, 10);
  strcat (message, "}}");
void connect_to_MQTT() {
  ++connects;
  connect_to_WiFi();
  if (!clientPS.connected()) {
    Serial.println("Connect to broker");
    boolean connected = (strlen(ID) > 0)? clientPS.connect(MY_CLIENT_ID, ID, MY_AUTH_TOKEN) :
                                          clientPS.connect(MY_CLIENT_ID);
    if (connected) {
      Serial.print("  Failed, rc="); Serial.print(clientPS.state());
        Serial.println (" ; delay 5 seconds");
      delay(5000);
  lastConnectTime = millis();
void connect_to_WiFi () {
    Serial.println("Connect to WiFi");
    WiFi.begin(MY_SSID, MY_WEP_KEY_INDEX, MY_WEP_PASSWORD);
    Serial.println("  Delay");
    delay(5000);
int getTempInF () {
  float aRef = 5.0;
  float voltage = analogRead(TMP36_PIN) * aRef / 1024.;
  float degreesC = (voltage - 0.5) * 100.0;
  float degreesF = degreesC * (9.0/5.0) + 32.0;
  int t = (int)(degreesF + .5);
  return (t);
